06-27-2021, 01:04 AM | #13371 |
Drives: '14 BRZ Todoroki/OriginLabo
'14 BRZ Airbag (fits '13-'16) - $260
'14 OEM Taillights - $60 Satin White Pearl hood, doors, & trunk (haven't removed yet) - PM me Last edited by manualmotive; 07-10-2021 at 02:31 AM. |
06-27-2021, 09:38 PM | #13372 |
Drives: 2019 Toyota 86
2019 Toyota 86 Wheels and Tires - $SOLD. Located in South Bay (Redondo Beach)
Taken off of a 2019 86 with about 6,000 miles on it around 4? months ago. Wanted to move to 17x8s with stickier tires. Note that the wheels are wrapped in Bridgestone EL400 tires rather than the usual Primacy HPs. I have no idea why, but as far as I can tell it was done by the factory. Tons of treadlife, I don't remember any curb rash, and the tires are dusty but I will definitely take the time to clean them up before showing. Was thinking of keeping them around to actually qualify for autocross stock class but I need the space. Sorry I don't have the date and username verification, I forgot it when I took the photo and am away for now. Can reupload later if required. Sent from my ONEPLUS A6003 using Tapatalk Last edited by markubiak; 06-28-2021 at 10:48 PM. |
07-01-2021, 06:08 PM | #13373 |
Driver
Drives: 16 Subaru BRZ
Wtb open flash tablet v2
BRZ Build Thread
See you space cowboy... |
07-02-2021, 01:18 AM | #13374 |
FS located in 92551
100$ MAXTON DESIGN RACING SPLITTER WITH WINGS V1.1(all mounting hardware included) https://www.ftspeed.com/part/togt861...1-1-13-fr-s-86 50$ Ikon Motor Sports Front Lip Brand New never Mounted(no mounting hardware or 3M Tape)
2013 Series 10 FRS #553
07-02-2021, 10:25 AM | #13375 |
Drives: Black BRZ/Black S13 Silvia
Anyone got a front bumper with good tabs? Black BRZ. 1st generation.
07-02-2021, 10:04 PM | #13376 |
Drives: 2017 Toyota 86
For sale: 2 245/35/18 Michelin PS4S
For sale: Qty 2 245/35/18 Michelin PS4S tires. I put somewhere around 5-7k miles on them. I purchased them new from the tire rack and installed them right before covid. Excellent condition, no abnormal wear, no patches or repairs. I changed the fronts to 255s for a square set up and a bit more ground clearance which is reason I removed these.
Local pick up only, in the SoCal El Segundo area. I'm in the Torrance area sometimes and could meet there as well. $220 firm for both (less than the price of one). Thanks, Paul |
07-03-2021, 02:25 PM | #13377 |
Drives: Q5 + BRZ + M796
07-04-2021, 06:40 AM | #13378 |
Located in 92691
13-16 BRZ lights, 40k of wear: Headlights SOLD DRLs $140 pair OBO Foglights w/ bezels $50 pair Whiteline KCA416 Camber Bolts (Front Top) $20 SPC 81305 Camber Bolts (Front Bottom) $10 OEM Strut Bars $35 pair w/ bolts Dome light $20 Visors $60 pair OEM Antenna $20 OEM rear sway bar $40 OEM front endlinks $20 OEM rear endlinks $15 Headlight/taillight brackets $15 each Headliner $120 Center console $60 Rear seats $150 Subaru wheel locks $20 OEM rear crash bar $120 Full floor carpet $150 Circuit Sports 5x100->5x114.3 15mm adapters 12x1.25 $75 pair Like new, mounted but never driven, purchased from FRSport. Last edited by manualmotive; 07-09-2021 at 05:41 PM. |
07-07-2021, 12:00 PM | #13379 |
Drives: 2017 Subaru BRZ Limited Performance
Gruppe-S UEL Header & Over-pipe for 2013-2020 Subaru BRZ, Scion FR-S, Toyota 86
$300
Pick up from zip code 90504 12,000 miles. Leak between flange and pipe connection at cylinder 1 - will need to be welded to repair Includes overpipe 60mm UEL Ceramic coated Catless Used for 12,000 miles Leak between flange and pipe connection at cylinder 1 - will need to be welded for repair Includes: - 2x New JDL Header Flanges - 6x New OEM Subaru Header Bolts 902370010 - 1x New GrimmSpeed 020042 2.25/2.5 inch exhaust gasket Fits: 2013-2020 Subaru BRZ 6MT & 6AT 2013-2017 Scion FR-S 6MT & 6AT 2017-2020 Toyota 86 |
07-07-2021, 12:29 PM | #13380 |
Tanabe Concept G Cat-Back Exhaust for 2013-2020 Subaru BRZ Scion FR-S Toyota 86
$300
Pickup in zip code 90504 Used for 20,000 miles T80166R 60mm Mounting Hardware Includes:. - 3x Kartboy 12mm standard length exhaust hangers with 80a urethane - 1x New Tanabe 60mm exhaust flange gasket - 1x Open Box, not used Grimmspeed 020042 2.25/2.5 inch exhaust gasket - 2x New M8 bolts, washers, lock washers, and nuts for use with factory front pipe and the supplied flat gasket - 2x used M8 bolts, springs, and copper lock washers for use with the factory front pipe and factory doughnut gasket not included in this sale - 2x M10x1.25x35mm bolts, lock washers, and nuts for use with aftermarket front pipe and the supplied flat gasket Fits: 2013-2020 Subaru BRZ 6MT & 6AT 2013-2017 Scion FR-S 6MT & 6AT 2017-2020 Toyota 86 Last edited by nick.cfrancis; 07-07-2021 at 12:43 PM. |
07-07-2021, 12:42 PM | #13381 |
Tanabe Front Pipe for 2013-2020 Subaru BRZ, Scion FR-S, Toyota 86
$150
Pick up in zip code 90504 Used for 12,000 miles T50166 60mm Catless Used for 12,000 miles Includes: - 2x New Vibrant 1456 2.25 inch exhaust gaskets - 2x New M10x1.25x30mm flanged bolts and nuts - 2x New M10x1.5x35mm bolts, lock washers, and nuts Fits: 2013-2020 Subaru BRZ 6MT & 6AT 2013-2017 Scion FR-S 6MT & 6AT 2017-2020 Toyota 86 |
07-07-2021, 02:42 PM | #13382 |
Open Flash Tablet V2 (OFT)
$350
Pick up from zip code 90504 Unmarried from BRZ |
07-12-2021, 02:18 PM | #13383 |
selling blitz drop in filter. has about 10k miles, looks pretty good. can be cleaned if you want to put in the effort. $25 located in san diego. have the original box as well.
07-17-2021, 07:11 PM | #13384 |
Drives: '14 Asphalt Monogram
Wedssport TC105N Wheels (LA/SGV)
Selling a set of 4 brand new Wedssport TC105N 17x8 +42 5x100 wheels with valve stems. These are in the box never been mounted before. $1300 OBO https://www.ft86club.com/forums/showthread.php?t=146153 |
Tags |
caliusedpartsstore, downs, lowering springs, rsr, selling, shift knob for sale, side marker, socal, spoiler, trd |
Similar Threads | ||||
Looking for another Local FRS/BRZ! | XR4OUTCAST | Mid-Atlantic | 18 | 11-09-2012 02:20 PM |
Anyone local with aftermarket exhaust yet? | Areddi | Mid-Atlantic | 20 | 09-13-2012 07:40 PM |
Local Classifieds? | Hanakuso | Site Announcements / Questions / Issues | 1 | 08-15-2012 02:09 PM |
BRZ at Local Atlanta dealer! | subatoy | Southeast | 2 | 03-02-2012 03:08 PM |
calling ya local dealer | Slide | AUSTRALIA | 147 | 12-30-2011 01:10 AM |
