Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-18-2013, 04:37 PM | #29 | |
Drives: 13 DGM BRZ Ltd
Cost savings = using what you got instead of tooling for what you want. |
07-18-2013, 05:55 PM | #30 | |
Kouki-Monster
This isn't something a kid does in the driveway. I know kids that have done this in a driveway .. then they bring their car to my shop with cupped tires, issues from incorrect preload settings and complaints about their handling. My coilovers were installed on a hoist and then properly aligned on a good machine so that all specs were to my liking and ride height was perfect side to side. The car feels great.
Rich Anderson
EMPOWER AUTO |
07-18-2013, 06:01 PM | #31 | |
The implication that one is in dire need of having a "pro" bolt on some coilovers, like there's going to be some sort of catastrophe is unreasonable.
The Following User Says Thank You to qoncept For This Useful Post: | djdnz (07-18-2013) |
07-18-2013, 07:43 PM | #32 |
I Love custom Turbo kits
Drives: Limited BRZ
This is my EXACT issue. What do I need to do to remove that pre-load on the endlinks? loosen the sway bar, then re-tighten?
07-18-2013, 07:53 PM | #33 | |
Drives: 2013 MT Asphalt FRS
I WAS that kid with my old car..... NEVER again. One of the many reasons why I don't want aftermarket coilovers/ spring for my car now. |
07-18-2013, 09:29 PM | #34 |
Lowered Lifestyle
Drives: Scion Fr-S
07-19-2013, 12:04 AM | #35 |
Drives: 2006 STi
my car makes this noise toooooo i hate it. any definite solutions for this? Really dont feel like reading all the posts since somehow this thread turned into "coil install difficulty level"... typical FT86club. :/
07-19-2013, 01:10 AM | #36 |
Drives: 2010 BMW M3, 2013 Subaru BRZ
You'll need adjustable sway bar endlinks. OEM ones are probably too long in your case and it can result in just extra tension when turning the steering wheel or sway bar touching your control arms when turning, etc.
The Following User Says Thank You to RAWR BRZ For This Useful Post: | Sportsguy83 (07-19-2013) |
07-19-2013, 02:12 AM | #37 | |
Lowered Lifestyle
Drives: Scion Fr-S
Sent from my HTC One |
07-19-2013, 11:38 AM | #38 | |
1. Measure the height of the center of the passenger side hub with a ruler and write it down. (You could actually do either side - you really only have to adjust one side or the other) 2) You'll need 2 jacks to do this safely. First, jack the car up (with "jack A") at the front center jack point and remove the wheel at the corner you just measured. 3) Put the second jack (jack B) under the control arm (I put mine right under the ball joint) and jack it up until it is bearing the whole load. 4) Lower jack A a little bit to give it some clearance, then jack B as far as you can without taking any load of it. You're trying to get the center of the hub to the same level it is at normal ride height, and jack A is there because the car is kind of precariously sitting on jack B. Keep doing this till you're at the right height. 5) Adjust your endlinks till there is no preload. I unbolted one end and adjusted until the stud could slide in and out of the sway bar without any finagling. This isn't absolutely perfect - your car isn't going to be exactly at ride height without compressing the suspension a bit, but I wouldn't recommend that with the scary jack setup. Good enough.
The Following User Says Thank You to qoncept For This Useful Post: | Sportsguy83 (07-19-2013) |
07-20-2013, 02:18 AM | #39 | |
Similar Threads | ||||
Weird sound over 60mph | FRiSson | Issues | Warranty | Recalls / TSB | 23 | 03-05-2018 12:47 PM |
Prova Steering Wheel Install | RallySport Direct | DIY (Do-It-Yourself) Guides | 38 | 08-05-2014 01:42 PM |
JDM steering wheel off center after install | iketiak | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 06-25-2013 06:16 PM |
GTS rear left popping/clicking sound and fix. | sigmaoctantis | AUSTRALIA | 11 | 05-19-2013 07:58 AM |
This might sound weird | mrha | BRZ First-Gen (2012+) -- General Topics | 10 | 10-06-2012 07:06 AM |
