| DIY (Do-It-Yourself) Guides For all DIYs. |
#85 | |
/dev/null
Drives: Uphill
![]() You are correct, the radio antenna on the roof of the GT86 has nothing to do with the GPS. In North America some cars receive radio broadcasts from satellites and need special antennae for this purpose. |
#86 |
Perpetually Sideways
Drives: '14 DGM BRZ, '94 Volvo 940 Turbo
I did this swap close to a year ago and did not have this issue. Did you use the subaru part or is it a third party antenna? If it is indeed the oem, might a loose connection be the cause?
| The Following User Says Thank You to carczar87 For This Useful Post: | BigTuna (01-17-2017) |
#87 | |
Drives: 2013 WRB BRZ
I'll take a look at the connection at some point and report back.
#88 |
Drives: 14 BRZ Limited
I just wanted to share that I got my OEM shark fin from a wrecked car from LKQ. It was significantly cheaper than OEM. I recommend anyone looking to do this mod call your local LKQ to see if they can source one for you. I did put an FR-S antenna on to my BRZ and, as was noted in the OP, I lost XM connectivity but it did still work just fine otherwise. Won't matter eventually when I get a Joying HU but still thought I'd share.
| The Following User Says Thank You to g0lds For This Useful Post: | Allen Poe (03-29-2018) |
#89 |
Drives: '13 BRZ Limited WR Blue
I'm having a hard time getting the connector clip out. Anyone have any tips? What did you use to raise the lip holding the connector in place?
'13 BRZ Limited 6MT | Perrin Catback | AEM CAI
![]() Last edited by brz_enthusiast; 04-14-2017 at 02:11 PM. |
#90 | |
AT Pleb
Drives: 2014 FR-S Monogram (Firestorm Red)
Knowledge is knowing that a tomato is a fruit. Wisdom is not putting it in a fruit salad. |
#91 |
Drives: 2013 BRZ Limited
Thank you kbye for making such a comprehensive, detailed tutorial with great info and pictures!
I just put a 2015+ OEM Shark Fin antenna on my 2013 thanks to your help.
#92 |
I tightened mine so its snug against the roof but it wiggles from side to side a bit.
#93 |
Did yours wiggle at all? I put a 2015 on my 2013 as well and it wiggles from side to side. It is tightened snug against the roof
#94 | |
At first it just wasn't sitting right, so it took a little fanagling. It was cuz of that wire. When I first put it into place it'd look fine on the outside until I went back inside to tighten it. Then I'd look at it on the outside again and it didn't look right. The sharkfin's base wasn't perfectly flush with the roof. After a couple tries, fanagling with that wire while tightening, I got it into place and it looked right. Then I tightened it really tight and it's been solid ever since. I did it by myself but if it seems like you're having the same problem then it might make it easier to have 2nd person to hold it in place on the outside while you tighten it on the inside. It's a fussy little thing.
| ***NEW***Beatsonic Version 2 Sharkfin Antenna | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 03-27-2016 05:32 PM |
| WTB: sharkfin antenna/clear side markers | _frs | Want-To-Buy Requests | 0 | 10-27-2014 05:02 PM |
| Nav w/Sharkfin Antenna | Ryan5x | Electronics | Audio | NAV | Infotainment | 1 | 06-25-2014 04:37 PM |
| Pic Request: Red Beatsonic Sharkfin Antenna on Raven FRS | Lemar58 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 03-21-2013 12:26 AM |
| grazio & co. sharkfin antenna | ategs1992 | BRZ First-Gen (2012+) General Topics | 1 | 12-09-2012 07:11 PM |
