Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 05-10-2015, 01:09 PM   #1597
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by krayzie View Post
Planning to go with Bilstein yellow since this set is designed to be compatible with the normal car, yet the Showa silver is designed with just the BRZ tS model in mind imho.
I don't want to build a BRZ tS as I know it would be impossible in the absolute sense, I just want to build a BRZ with a factory STI Performance Package of sort.
I am also looking for the new strut, in order to match the 18" wheel in the
future.
No sure what's STI plan or definition which is pretty confused.
BRZ STI ts use: Showa silver
BRZ Production: Bilstein yellow
BRZ STI ts concept (2015): Bilstein yellow
http://clubrz.jp/article/?p=4593
Subaru BRZ STI Performance:Bilstein yellow
http://www.autoblog.com/2015/04/01/s...new-york-2015/
Another question in my mind is the different between STI Bilstein yellow
and Bilstein B8
http://www.ft86speedfactory.com/bils...-kit-1386.html
and also STI Showa silver and SHOWA tuning evolution.
http://showa-tuning.com/evolution.html
It can save some money, if there is almost no different between the STI one.
Thanks.
cslntuee is offline   Reply With Quote
Old 05-10-2015, 08:17 PM   #1598
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
future.
and Bilstein B8
Thanks.
Most likely the STI ones are custom spec valving in order to match a specific set of their springs. The B8 is probably a compromised spec valving for use with an array of different springs out on the market for this car. While the specs are different, the internals could be the same.
STI being a small shop with a limited run / market for their stuff, the prices will definitely be higher.
If you are doing a complete BRZ tS mechanical conversion then by all means, go with the silver set. With either set of shocks, just make sure you get the matching springs.
BTW the RA Racing spec car also has its own set of springs and shocks combo, but you can only buy that set with a valid VIN, and the cost is even higher than the STI Bilstein set IIRC.
Anyway I just hope STI doesn't pull a Brooklyn Bridge on us lol!
krayzie is offline   Reply With Quote
The Following 2 Users Say Thank You to krayzie For This Useful Post:
chaoskaze (05-10-2015), cslntuee (05-11-2015)
Old 05-10-2015, 11:47 PM   #1599
DSOmegaX
DSOmegaX's Avatar
If anything it looks like sti went with Showa for the tS because the bilsteins were not production ready when the car was out, which is why it was released as a standalone later. Considering sti's history with bilstein, it's the "logical" choice. Not to fault the shows or anything as it was still designed and valves for the tS specifically.
@dsomegax.cars
The Following 2 Users Say Thank You to DSOmegaX For This Useful Post:
cslntuee (05-11-2015), krayzie (05-13-2015)
Old 05-11-2015, 12:57 AM   #1600
cslntuee
It looks like the both STI yellow and silver use the same front and rear
spring. Let me more confused that yellow and silver strut has different
or not.><
http://www.ft86club.com/forums/showp...47&postcount=1
The Following User Says Thank You to cslntuee For This Useful Post:
krayzie (05-11-2015)
Old 05-13-2015, 03:36 PM   #1601
krayzie
Drive From Home
krayzie's Avatar
Has anyone bought and installed all of the available STI bushings and mounts?
http://www.sti.jp/parts/catalogue/brz_zc6/1.html
Old 05-13-2015, 05:54 PM   #1602
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Lots of folks use the engine/transmission mounts.
Kostamojen is offline   Reply With Quote
Old 05-14-2015, 04:09 PM   #1603
DSOmegaX
DSOmegaX's Avatar
Putting in the steering rack bushings today, along with the rear axles
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
Trap63 (05-14-2015)
Old 05-14-2015, 05:06 PM   #1604
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
How much $?
Trap63 is offline   Reply With Quote
Old 05-14-2015, 05:14 PM   #1605
DSOmegaX
DSOmegaX's Avatar
Originally Posted by Trap63 View Post
How much $?
Axles are just over 1000. I bought a whole bunch of items together: rear axles, the draw stiffener, steering rack bushings, cf driveshaft, for around 2500 total
@dsomegax.cars
Trap63 (05-14-2015)
Old 05-14-2015, 05:26 PM   #1606
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
BRZ Ts parts
How does it feel? The axle & flex stiffener.
As for bushing I'm interested in them but don't want more induced road noise& motion into cabin.
Old 05-14-2015, 11:10 PM   #1607
Kostamojen
For both or each?
Old 05-14-2015, 11:31 PM   #1608
DSOmegaX
DSOmegaX's Avatar
Originally Posted by Kostamojen View Post
For both or each?
Both rear. Larger diameter but weighs the same as stock
@dsomegax.cars
Old 05-15-2015, 12:36 AM   #1609
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Don't worry about that for the steering rack bushings. I have them (along with the tS' nuts and bolts), great feel improvement but zero NVH increase.
Old 05-15-2015, 01:39 AM   #1610
DSOmegaX
DSOmegaX's Avatar
Didn't have enough time to get the draw stiffener on. Ended up installing: cf drive shaft, sti rear axles, sti steering rack bushings and the associated bolts.
The cf drive shaft/rear axle combo has done wonders to the acceleration of the car. It improves the responsiveness and immediacy of the throttle. While the majority of the improvement will be attributed to the drive shaft (half the weight), the larger diameter rear axles (same weight as stock), in my opinion, still contribute together with drive shaft as the larger diameter transfers more torque for the same amount of rotation. Overall, the car revs quicker, and what was most surprising to me, a lot smoother. A lot of the harshness and vibration as the car accelerates has been softened or eliminated.
The steering rack bushings have removed the dead center of the steering wheel. It has better weight, feels more solid, and improved the feedback from the road. And as mentioned, did not increase NVH.
@dsomegax.cars
The Following 3 Users Say Thank You to DSOmegaX For This Useful Post:
chaoskaze (05-15-2015), funwheeldrive (05-27-2015), krayzie (05-15-2015)
it sucks to be broke, sti omg!
Search this Thread:
Advanced Search
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
