Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 04-23-2015, 03:14 PM   #1583
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by chanomatik View Post
Someone else installed the STI clutch in their ride and I asked the same question. Here's their nice response in the last couple of posts!
http://www.ft86club.com/forums/showthread.php?t=38632
Hey chanomatik did you replace the throwout bearings too or just the clutch?
I ordered a new rubber gasket, washer and pin for where the shifter meets the shifter linkage figuring that needs to be disconnected in order to drop the gearbox?
krayzie is offline   Reply With Quote
Old 04-23-2015, 03:46 PM   #1584
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
I don't do heavy mechanical work on my own car. The hardest thing I'll tackle is swapping struts/springs. I had a trusted performance shop do it. I didn't even look at the bill since I prepaid everything, so I don't know exactly all that was replaced. I think most places locally will just replace the throwout bearing at the same time, but I'd have to double-check that for ya.
The Following User Says Thank You to chanomatik For This Useful Post:
krayzie (04-23-2015)
Old 04-23-2015, 06:46 PM   #1585
krayzie
Drive From Home
krayzie's Avatar
Man I just got the throw out bearing too when I went to pickup the misc parts today just in case. I saw the pix of the melted ones on another thread and it's scary!
Old 04-24-2015, 09:52 PM   #1586
krayzie
Drive From Home
krayzie's Avatar
BTW check out these STI driving shoes. Too bad only goes upto 27cm made to order:
http://sti.jp/sticollection/pickup-d...vingShoes.html
Old 04-26-2015, 08:57 AM   #1587
tracerit
Drives: '13 SSM BRZ Limited 6MT
is the tS steering wheel any thicker than the stock?
tracerit is offline   Reply With Quote
Old 04-26-2015, 10:55 AM   #1588
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
No, but the TRD wheel is.
Kostamojen is offline   Reply With Quote
The Following User Says Thank You to Kostamojen For This Useful Post:
tracerit (04-26-2015)
Old 05-06-2015, 02:25 AM   #1589
brzsubarusti13
Drives: 2013 Subaru BRZ
Does anybody know the part numbers to the interior trim pieces? EDIT. found them
brzsubarusti13 is offline   Reply With Quote
Old 05-06-2015, 10:29 PM   #1590
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Ah. I see you'v discovered them! I was going to reply to your PM. Sorry for the delay. Glad you got help!
Old 05-07-2015, 12:37 AM   #1591
brzsubarusti13
Haha i found them on a GT86 website. I couldnt stand how cheap the aussie flat black trim interior parts looked but didnt want to pay top price for Ts black trim pieces on japanparts.com. Now i purchased them for half off on amayama
The Following User Says Thank You to brzsubarusti13 For This Useful Post:
chanomatik (05-31-2015)
Old 05-07-2015, 12:52 AM   #1592
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Haha i found them on a chinese GT86 website. I couldnt stand how cheap the aussie flat black trim interior parts looked but didnt want to pay top price for Ts black trim pieces on japanparts.com. Now i purchased them for half off on amayama
Can I get the part #s from you?
I was gonna do the same thing.
Old 05-07-2015, 01:57 AM   #1593
brzsubarusti13
Sure. Im postive these are them but there is a slight chance i can be wrong. I guess i will know when they arrive. The only part that is non Ts are the black buttons
Subaru 34342CA030 COVER, PLASTIC (DH JP) - 23.26 USD, 1 items
Subaru 92122CA020 COVER, PLASTIC (DH JP) - 17.82 USD, 1 items
Subaru 66076CA040 COVER, PLASTIC (DH JP) - 14.85 USD, 1 items
Subaru 66076CA050 COVER, PLASTIC (DH JP) - 14.85 USD, 1 items
Subaru 94237CA060 COVER, PLASTIC (DH JP) - 13.86 USD, 1 items
Subaru 94237CA070 COVER, PLASTIC (DH JP) - 13.86 USD, 1 items
Subaru 66067CA020 COVER, PLASTIC 2.91, 2 Items
Toyota SU00302487(AT) or SU00302486(MT) SWITCH (BJ JP) - 36.24 USD, 1 items
Andrew025 (05-07-2015)
Old 05-08-2015, 10:04 PM   #1594
krayzie
Drive From Home
krayzie's Avatar
Okay the STI clutch and pressure plate are in, clutch fluid replaced with ATE Typ 200 DOT-4 (left over from the brake job).
Almost stalled it when I first hopped onto the car, but quickly became second nature after driving a few blocks. The clutch pedal is slightly firmer (not heavy by any means) but the engagement is way more accurate. The car now just hooks up and goes (I can't imagine how it would be after installing all of the STI hard rubber mounts and bushings). Heel and toe downshift to 2nd gear has never been this smooth.
I almost find this new setup easier to drive than stock. Feels pretty bad ass actually.
Still on the fence in regards to the mounts and bushings (i.e. increase NVH for daily driving). Will definitely get the STI/Bilstein suspension kit eventually (KW V3 coils money right there ouch).
The Following 4 Users Say Thank You to krayzie For This Useful Post:
chanomatik (05-31-2015), chaoskaze (05-10-2015), cslntuee (05-09-2015), NLSP (05-08-2015)
Old 05-09-2015, 12:01 PM   #1595
cslntuee
Drives: Subaru BRZ Limited
Which STI strut you plan to go (yellow or silver) and why?
Thanks.
cslntuee is offline   Reply With Quote
Old 05-09-2015, 10:01 PM   #1596
krayzie
Drive From Home
krayzie's Avatar
Thanks.
Planning to go with Bilstein yellow since this set is designed to be compatible with the normal car, yet the Showa silver is designed with just the BRZ tS model in mind imho.
I don't want to build a BRZ tS as I know it would be impossible in the absolute sense, I just want to build a BRZ with a factory STI Performance Package of sort.
The Following 2 Users Say Thank You to krayzie For This Useful Post:
chanomatik (05-31-2015), cslntuee (05-10-2015)
it sucks to be broke, sti omg!
Search this Thread:
Advanced Search
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
