Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-29-2020, 03:06 AM | #29 |
Drives: White FR-S kosei k4r 17x8
The dipstick is hard to read on this car. What I normally do is drive the car a few miles to normal temps then park on a flat area for 10 - 20 min. Then check the dipstick. There should be a diagonal “dry” line on the dipstick on both sides. That is where the oil level is. Tried to take a picture of mine but didn’t show well in the photo.
The Following User Says Thank You to jiffyjhn For This Useful Post: | indio22 (09-01-2020) |
08-30-2020, 12:07 AM | #30 | |
Drives: 2016 Scion FR-S
Discussions about engine oil make my head hurt, it’s ridiculous. I think any good 0w20 will work just fine. I have a little extra peace of mind with Toyota oil and the black Subaru filter. Mobil1 has never let me down either, I’ve used it in every car I own. Except for my GTI that “required” some Euro spec Castrol oil. Sent from my iPhone using Tapatalk |
08-31-2020, 05:27 PM | #31 | |
Drives: 6MT '15 BRZ | '89 240sx (sold...)
I used a Toyota filter for my most recent oil change and that should be fine too. Couple dollars cheaper, still made by Denso, straight from their parts department.
la cocaina is not good for you ig: sad_fa20 |
The Following User Says Thank You to sukumizu For This Useful Post: | JesseG (09-01-2020) |
08-31-2020, 06:17 PM | #32 |
Drives: 2014 BRZ
Thanks I appreciate all the advice. I changed the BRZ oil over the weekend, using a black OEM Subaru filter and crush ring from my local dealer. I put in 5.8 US Qts of Mobile 1 Extended Performance 5w-20 oil. Showing just slightly above the top hole in the dipstick. I'm fine with that, nowhere near as high as before.
I can't explain why some oil change shops and even dealerships are filling the oil so high. My wife's Kia Soul came back from the dealership 3/4 of a quart overfilled. The Kia takes 4.23 US Qts and maybe the dealership mistakenly installed 5 Qts. I'll go back to changing my own oil. Now I just need to find a gas station in the Chicago area with reasonable cost premium fuel, preferably in the western suburbs. Bites that Chicago area has some of the highest cost premium fuel in the country. |
08-31-2020, 06:31 PM | #33 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | JesseG (09-01-2020) |
08-31-2020, 07:13 PM | #34 | |
To be fair, I know a lot of people who do this to their own personal cars. 5.5 quarts? Just dump the entire thing in there without checking levels.
09-01-2020, 07:54 PM | #35 |
Drives: hyper blue
I would drain it off or just swap in a new filter.
years ago, on a benz wagon at the first service, the dealer tech didn't know the prop shaft on the 4-matic wagons was a different oil pan. the extra quart and a half fouled the cats. |
Similar Threads | ||||
Dipstick leak ? | Geex | Issues | Warranty | Recalls / TSB | 7 | 12-17-2019 03:43 AM |
Dipstick removal | Geex | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 03-06-2019 01:55 PM |
Oil level on dipstick... | Da Brz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 36 | 11-21-2016 06:44 PM |
oil on dipstick but not on hole | ZionsWrath | Engine, Exhaust, Transmission | 2 | 09-08-2014 07:46 PM |
Show me your dipstick.... | Trashed675 | Engine, Exhaust, Transmission | 6 | 01-03-2014 01:09 AM |
