Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-17-2020, 07:36 AM | #15 |
Drives: 2020 Subaru BRZ TS
The Fumoto Valve is also very useful and makes the oil change on these cars hassle free.
The Following 2 Users Say Thank You to SUSPECT_BRZ For This Useful Post: | Flarpswitch (09-05-2020), Magyarman (08-22-2020) |
08-17-2020, 07:57 AM | #16 |
Sarcastic SOB
Personally, I'd call the dealer and tell them that according to the dipstick, they overfilled your oil. Now, either they drain/fill to correct level or tell you it's ok, and ask them to email you that reply so they are responsible.
Using 0W20 oil, overfilling will allow the crank to dip into the oil pan as the car moves, possibly causing the oil to foam up. Not sure otherwise what is the detriment but that is added resistance inside the engine.
The Following User Says Thank You to wbradley For This Useful Post: | Windycitystig (08-17-2020) |
08-17-2020, 01:54 PM | #17 |
Drives: Crapcan
You would have to go quarts over for the level to hit the crank in this engine. Just FYI.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: | Magyarman (08-22-2020), soundman98 (08-17-2020), strat61caster (08-21-2020), thomasmryan (09-01-2020) |
08-17-2020, 02:06 PM | #18 |
Drives: 2016 Scion FR-S
Another thing to keep in mind is 0w20 is so thin, it’s easy for it to move up and down on the dipstick. So I’ve found it’s difficult to get an accurate read. If it’s a little above the highest fill mark I wouldn’t worry. Mine pretty much always reads that way. I usually check after I’ve been driving for a while, turn off the car, and wait 5-10 minutes before checking the level.
I also don’t lose very much oil at all between changes, which is surprising with such thin oil. I use either the Toyota/Subaru 0w20 or Mobil1 Sent from my iPhone using Tapatalk |
The Following User Says Thank You to JesseG For This Useful Post: | indio22 (09-01-2020) |
08-17-2020, 08:47 PM | #19 |
I take that back OP, your first picture makes it look like it’s WAY overfilled. That wouldn’t be a good thing, and I would drain some oil to be safe. And check the oil level again before you drive. Typically my car reads just slightly above the highest fill mark, or right at the line.
08-22-2020, 08:20 PM | #20 | |
Drives: 2014 BRZ
I read through the oil threads in this forum and man, lots of differing opinions on oil brands, lol. I'll try "Mobil 1 Advanced Fuel Economy Full Synthetic Motor Oil 0W-20" from Walmart 5.8qts. Reading various discussion here, seems like most people recommend using a Subaru oil filter rather than aftermarket. But there might be two kinds, blue and black (latter supposedly from Japan). Should I just go to a Subaru dealer and have them give me the correct filter, or is that too pricey? Where do people usually get their filter? I saw this on Amazon for the black version: https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1 |
The Following User Says Thank You to indio22 For This Useful Post: | JesseG (08-30-2020) |
08-22-2020, 10:05 PM | #21 | |
Drives: 2019 BRZ with Performance Package
08-22-2020, 10:16 PM | #22 | |
Drives: 2020 86
https://www.ebay.com/itm/OEM-Subaru-...53.m2749.l2649 |
08-22-2020, 10:22 PM | #23 | |
ProCrastinationConsultant
i believe every single oil that is sold in america must have a label about how it conforms with the SAE and API standards. from the bargain-bin 'walmart' oil, to the premium products like royal purple. scroll down to 'motor oil designations', and API/ILSAC "starburst": https://www.pennzoil.com/en_us/educa...ended-use.html by those standards, the bargain walmart oil offers no difference in performance than the most premium of oils. any choice in oil over the store-brand stuff is purely for your personal comfort. and filters aren't all that different either. while more premium filters do in fact offer some other filtering options, as someone once told me, "even chicken wire can filter 0.1 micron particles if you test it right". change it at the required intervals, live your life. anything beyond that is pedantic for the interest of being pedantic. i personally use castrol synthetic, and purolator boss filters, but it's solely to make myself feel better, and only deny that to myself.
The Following User Says Thank You to soundman98 For This Useful Post: | WildCard600 (08-22-2020) |
08-26-2020, 02:33 PM | #24 | |
Drives: 2014 BRZ
So now I've got to return that dented filter, and I don't want to wait around for another one in the mail. I can go to Subaru dealer and buy a genuine oil filter (probably the blue version people don't seem to recommend). Or go 3rd party filter. I've read that genuine Subaru filter matters - and that it does not. What a pain just to change some oil. I never cared much about oil or filter with my older 4x4s. Just used whatever. |
08-26-2020, 02:41 PM | #25 | |
Drives: 22 BRZ limited
My local dealer stocks the black filter for the BRZ. |
The Following User Says Thank You to dragoontwo For This Useful Post: | indio22 (09-01-2020) |
08-27-2020, 04:49 PM | #26 |
Drives: 2014 BRZ
Thanks for the tip. Called my local dealer and yep they had the black filters - so I picked up two. Also got the little drain plug crush ring. I had been planning to re-use the existing ring. This is first time I recall any of my vehicles having a drain plug crush ring.
08-28-2020, 11:28 AM | #27 |
Meow
Drives: GT86, Volvo 996
Regarding the oil level, my car has been serviced at Toyota Brussels and at the most knowledgeable (and only!) 86 specialist in France, and both of them always fill the car to about the level shown by OP.
I've come to believe this is more or less standard procedure for oil changes on these cars. |
The Following User Says Thank You to alex87f For This Useful Post: | JesseG (08-29-2020) |
08-28-2020, 02:20 PM | #28 |
If you really care, you can buy a cheep pump driven by a drill that has a 1/4 in line for the inlet. You put it down the dip stick hole. It is sold at most auto parts stores for draining inboard boat motors. I think under $20. They are kind of a one time pump. The rubber vanes seem to fail no matter what i flush with.
Similar Threads | ||||
Dipstick leak ? | Geex | Issues | Warranty | Recalls / TSB | 7 | 12-17-2019 03:43 AM |
Dipstick removal | Geex | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 03-06-2019 01:55 PM |
Oil level on dipstick... | Da Brz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 36 | 11-21-2016 06:44 PM |
oil on dipstick but not on hole | ZionsWrath | Engine, Exhaust, Transmission | 2 | 09-08-2014 07:46 PM |
Show me your dipstick.... | Trashed675 | Engine, Exhaust, Transmission | 6 | 01-03-2014 01:09 AM |
