Old 03-06-2022, 11:15 AM   #29
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by JOSEC View Post
2 different Maps.
Map 1, Red Line is gate pressure at 17 PSI. 380WHP I think somewhere around 320 TQ.
Blue is Map 2, 18.5PSI More timing. 420 WHP. 347 TQ.
Both gets on boost 3-3.5K. Lots of response, very linear power.
It’s my track car, so there was more power with more aggressive timing. But wanted to keep it more conservative.
That’s awesome. Most power I’ve seen on pump gas.
What head work was done?
Larger valves?
Cams?
Port work?
Old 03-06-2022, 11:16 AM   #30
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by BrahmaBull1990 View Post
My understanding is you start eating transmissions and axels at those levels. So you change one thing in a huge way, you need to reenforce everything else ancillary to it. I’m just puttering around at 252whp, but also research for the “one day” thoughts.
The gen 2 transmission is supposedly stronger, but I’m not sure if it is a direct bolt-up.
It's a slightly uprated version of the same transmission. It will be a direct swap.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
BrahmaBull1990 (03-06-2022), jrhudson (03-06-2022)
Old 03-06-2022, 02:46 PM   #31
JOSEC
Drives: 2014 Subaru BRZ WRB
Larger valves?
Cams?
Port work?
Larger valves both intake and exhaust. Very slight port work just to clean everything up leading up to the larger valves (Bowl blend, 5 angle valve work, etc). And of course springs and new retainers to able to support increased redline.
But 400 def possible on Pump. You just have to have the supporting mods.
JOSEC is offline   Reply With Quote
The Following User Says Thank You to JOSEC For This Useful Post:
86TOYO2k17 (03-06-2022)
Old 03-06-2022, 02:47 PM   #32
JOSEC
4th gear has reliability issues on the current (1st gen) AZ6. I've personally seen it on friends cars who range from 400WHP-600WHP. They always seem to rip up 4th gear. But I got that all fixed up by the guys at Jacks Transmission.
BrahmaBull1990 (03-11-2022)
Old 03-06-2022, 11:37 PM   #33
jrhudson
Drives: 2016 scion frs
=D
jrhudson is offline   Reply With Quote
Old 03-11-2022, 12:06 AM   #34
Evil Rocky
Drives: FRS
How is the transmission holding up? There was a guy on Facebook who said the second day of regular driving transmission went out and just got jacks stuff. Was debating on getting jacks or saving up more for cd009
I am currently at 400whp on map3 but Ususlly in map 1 & 2 for track which is 306 and 360
Evil Rocky is offline   Reply With Quote
Old 03-11-2022, 04:07 PM   #35
JOSEC
2 years now with the built transmission with no issues. I personally didn't want to mess with cutting and welding brackets so I went with Jacks. WPC will cut down on stress risers on stock gears in addition on what Jack's does to the stocks transmission to make it a little bit more reliable. No problems so far.
Evil Rocky (03-17-2022)
Old 03-11-2022, 09:21 PM   #36
jrhudson
wow, really? maybe a bad trans? but CD009 are known for their strength. its what 2jz peeps that make 1000 hp use for their builds.
Old 03-17-2022, 11:39 PM   #37
Evil Rocky
Drives: FRS
I wanted the jacks stuff since easier to swap in. I have carbon synchros in mine and been okay. I only used the 400whp map twice since don’t need it and don’t want transmission to go right away. It hoping get a good deal
On either a jacks or cd009 mazworx conversion
BRZ engine compression 13.5:1 or 12.5:1? mangler BRZ Second-Gen (2022+) -- General Topics 2 12-05-2021 05:16 PM
Lowering compression Boris_Petrov Forced Induction 3 01-19-2019 05:19 AM
compression+boost? subatoy Forced Induction 74 01-30-2015 04:32 PM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
