10-30-2015, 12:00 AM | #2647 |
Drives: 86 GTS
10-30-2015, 09:05 AM | #2648 | |
Drives: 2014 GT86
The wheels are Gunmetal Volk TE37SuperLaps 18x9.5 +40 and its lowered ~1.8inches all around. I need to play with the rear ride height because of my LCAs (which you'll want if you go with a low offset or 9.5inches and wider). This color is the Whiteout/Satin White Pearl.. not sure if the names differ from countries? Anyhow, indesign is correct. I prefer Whiteout though Last edited by jlugo711; 10-30-2015 at 09:17 AM. |
10-31-2015, 03:42 PM | #2649 |
Drives: Scion FRS
10-31-2015, 05:04 PM | #2650 | |
Drives: 86 GTS
11-01-2015, 09:29 PM | #2651 |
Drives: 2016 White GT86 | 1993.5 Supra
11-03-2015, 02:21 PM | #2652 | |
Drives: 86 GTS
Ended up buying a white one after looking at your and others in this thread, picking it up on Thursday. I am excited! With your setup, did you need to change the factory suspension on the car? What is LCA? Sent from my iPad using Tapatalk |
The Following User Says Thank You to Here2rock For This Useful Post: | MisterSheep (11-03-2015) |
11-03-2015, 03:05 PM | #2653 |
Killed Scion
Drives: 2013 FR-S Whiteout
LCA stands for Lower Control Arm
On the FRS we use LCA's to adjust rear camber.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
11-03-2015, 04:30 PM | #2654 | |
Drives: 86 GTS
WHITEOUT FR-S Compilation
I understand it performs better with LCA but if you are just going for the looks, what is a safe drop, rim size, tyres without changing the factory drive feel too much? Will it be correct that If you don't drop so much that you don't have to worry about canter so much? Sent from my iPad using Tapatalk |
11-03-2015, 04:40 PM | #2655 | |
Killed Scion
11-04-2015, 12:11 PM | #2656 |
CAMBAM
Drives: '13 Whiteout FRS
Whiteout and Halo are completely different colors and do not match. You can easily tell the difference when they are next to each other. Whiteout is creamy pearl and halo is frosty white
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
The Following User Says Thank You to CAMBAM_6 For This Useful Post: | Here2rock (11-04-2015) |
11-05-2015, 03:06 PM | #2657 |
Drives: 86 GTS
11-06-2015, 12:15 PM | #2658 | |
CAMBAM
There is a side by side picture in the "Halo Compilation" thread but the resolution is like cell phone camera quality so you can't see the difference. Your best bet for seeing the differences is to pull up beside one in person because you have to see it in the sun to really see everything anyways. In the picture your just going to see two white cars unless your using a high end camera.
11-06-2015, 07:08 PM | #2659 |
Drives: 86 GTS
Too right.
11-10-2015, 11:27 AM | #2660 |
Drift Specialist
Drives: 180SX,GT86
Whiteout Mafia
The Following 2 Users Say Thank You to GT86drifter For This Useful Post: | Ammunition (11-10-2015), MisterSheep (11-10-2015) |
Similar Threads | ||||
Skoodges Whiteout (AT)FR-S | skoodge | Member's Car Journals | 80 | 08-28-2013 04:27 PM |
Whiteout FR-S At Kenshaw | rL-gT | CANADA | 17 | 05-26-2012 05:06 PM |
Already Got my First 86 Whiteout Manual FR-S | AustinTCLN | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 05-23-2012 09:43 AM |
Was ordering whiteout a mistake? | Liquidsnake | Scion FR-S / Toyota 86 GT86 General Forum | 63 | 04-29-2012 10:13 AM |
Whiteout FR-S/86 | just86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 04-01-2012 01:16 AM |
