Member's Car Journals Car journals by our members. |
#15 | ||
Drives: Toyota GT86
Does come at a price though ![]()
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#16 | ||
Drives: 2023 BRZ, 2018 Golf R 6MT
I'm worky, very slowly, on a software package to import the video and do overlays and stuff on my PC. But it's going to take me a very long time, lol. The only nice thing it does right now is to let me compare my RaceChrono data with other people's AIM data. |
#17 |
Drives: Toyota GT86
Very cool getting the live overlay with RaceChrono if you use the built in camera. RaceChrono Seems to be a very popular choice but it’s still not as simple and bullet proof as an Aim setup. But there is a big price gap so maybe not worth the money for some.
Also awesome work being able to compare your data to Aim users! Are you importing your data into race studio to make that happen? Either way good stuff
#18 |
No, I found a library from AIM to pull data out of their files. So I can import both those and RaceChrono CSV v3 into my custom UI.
The Following User Says Thank You to grippgoat For This Useful Post: | autoracer86 (05-22-2024) |
#19 | |
Drives: Toyota GT86
Good luck with your UI sounds like an awesome project. Thanks for sharing ![]()
#20 |
Got the RaceChrono GoPro import figured out. It's actually pretty straightforward, and not so bad when I'm just grabbing 1-2 vids for the part of my best session that I want to overlay. It's automatic sync from the metadata was not bad, just had to manually shift by maybe half a second to get the steering angle gauge to match the actual steering angle.
The Following 2 Users Say Thank You to grippgoat For This Useful Post: | autoracer86 (05-24-2024), villainous_frx (05-25-2024) |
#21 |
Spent some time with DaVinci to do some editing on the video from 2024/05/17.
Not sure it was time well-spent, lol. |
The Following User Says Thank You to grippgoat For This Useful Post: | villainous_frx (05-28-2024) |
#22 |
Started putting together my new trailer.
It's the 48"x40" from Harbor Freight that I saw a lot of people using as a base for their tire trailer. Normally $399, but I had the 20% any single item from Inside Track club. ![]() |
The Following User Says Thank You to grippgoat For This Useful Post: | villainous_frx (08-14-2024) |
#23 |
Quick update: I hemmed and hawed and procrastinated long enough that Curt released a wiring kit for the '24 WRX. I zoomed in and it looked like the plugs were the same as gen 2 BRZ tails, so I ordered one (NAPA had the best price I found and shipping was fast).
I did have to swap some pins around to match the BRZ wiring, but I powered it up with everything just sitting in the trunk, and all the trailer lights seem to be working correctly. I still need to extend some wires and get things out through the grommets at the back of the trunk, which might require bumper removal. Once I've got it all done, I'll post some pics and commentary on moving the pins around. -Mike |
The Following 3 Users Say Thank You to grippgoat For This Useful Post: |
#24 | |
Drives: 18 Brz (Sold) / 22 BRZ
The Following User Says Thank You to Stonehorsw For This Useful Post: | grippgoat (10-01-2024) |
#25 | |
However, I recently did a track day with fresh new XR2 pads (came as spares with the car, lol) and had the same issues that I had with new XR4s. On the same old rotors both times. In hindsight, I don't think the new pads are bedding properly to the old groovy and lipped rotors. I picked up some new ones, and will re-test both options. But won't hit the track again until next year. New PB here Read the video description for more details on car changes and stuff I still owe y'all some content on trailer wiring. |
The Following 2 Users Say Thank You to grippgoat For This Useful Post: | autoracer86 (10-01-2024), Stonehorsw (10-01-2024) |
#26 |
Drives: Toyota GT86
I saw in your YouTube description you made the rear sway bar stiffer by using a different hole on the rear lower control arm. I don't think I knew I could do that or did and forgot haha. Either way thanks for the tip!
#27 | |
Although, given the simple design of the stock arms, it might be possible to drill some additional holes. Actually, I just realized I can do the same with the bottom end of the shock. I should.play with that to get an idea of what a stiffer spring back there might do. |
The Following User Says Thank You to grippgoat For This Useful Post: | autoracer86 (10-05-2024) |
#28 | |
Drives: Toyota GT86
Ansix Auto's 2023 WRB BRZ Streetable Track Build | Ansix Auto | Member's Car Journals | 26 | 08-14-2023 11:04 PM |
FS: 2023 BRZ Track build @1600 miles | X25 | Cars for Sale/Trade | 5 | 03-09-2023 03:03 AM |
Track + Daily BRZ build from China (a lot of pics) | luke8715 | Member's Car Journals | 8 | 01-31-2023 03:32 AM |
