Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 07-14-2024, 03:03 AM   #1
se7en_force
Drives: BRZ 2013
Should I find a new ballast or get new headlight assembly?
My electric engineer friend said my ballast is likely out on my passenger side. The low beam is dim and eventually turns off after a couple minutes of driving, and I can turn it back on if I flip the lights off then on again. The fuses are good and the bulb was changed too. I don't know anything about ballasts and if I change one I should probably change the other given my car is 2013 MY so age in components is starting to show. My question is if I should buy new ballasts or new headlights in general, because even my plastic housing is showing some internal cloudiness and what looks like cracks or condensation within. Do new headlights come with new ballasts? I'd rather pay once and cry once than swap ballasts, and find out I could have bought a new kit for not much more. Would also appreciate the part number for the ballast or any suggestions if anyone has them.
se7en_force is offline   Reply With Quote
Old 07-16-2024, 06:23 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Up to you if you want to swap the whole headlight or just the ballast
The only ballasts that you should use for the factory headlights are factory ballasts.
If you want replacement headlights, you could get used factory HID headlights (usually ~$400 for the pair).
Aftermarket headlights vary, but there rarely as good as OEM (both in terms of build quality and light output). Only HID headlights need and come with ballasts. LED have integrated boards or COBs, and Halogen lights don't need any extra electronics.
EndlessAzure is offline   Reply With Quote
Headlight ballast, pair gcranston Exterior Parts (Aero, Lighting, Etc.) 5 08-17-2022 10:26 PM
Headlight washer assembly Deemsim Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 07-12-2021 12:35 AM
WTB: BRZ Headlight wiring, DRL & fog assembly alfakarl Want-To-Buy Requests 0 11-10-2018 12:18 AM
Headlight assembly adjustment ARTBRZ BRZ First-Gen (2012+) -- General Topics 2 08-13-2015 01:19 AM
Headlight assembly adjustment ARTBRZ DIY (Do-It-Yourself) Guides 0 08-12-2015 12:04 AM
