Old 05-24-2024, 01:53 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've never messed up a stock stud either but I always run them on gently.
Highly advise against anti seize or any type of thread lubricant. Has a drastic effect on torque.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
gen3v8 (05-24-2024), humfrz (05-26-2024), Ultramaroon (05-24-2024)
Old 05-24-2024, 07:46 PM   #16
meow
To be clear, I'm on my original wheel studs/nuts. I only became curious after reading all the horror stories. Wheels are removed a few times annually.
The stock acorn nuts are pretty sloppy but, handled accordingly...
gen3v8 (05-24-2024)
Old 05-24-2024, 08:07 PM   #17
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti My19 brzts
Can change the torque up to 40%.Yes I use some copper grease. Makes me wonder what level of destruction others have applied for a failure. I start by hand, use a rattle gun, then finish on the ground with a torque wrench. I do use aftermarket steel wheel nuts that show no signs of failure nor do the wheel studs. I have aluminium nuts that are also fine but not for track use IMO.
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
autoracer86 (05-26-2024), NoHaveMSG (05-24-2024)
Old 05-24-2024, 11:45 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I know a lot of people who have gotten away with it for a long time so take it with a grain of salt. All the tests I have scene show a pretty drastic change in torque.
I think the biggest issue with the stock studs is poor tolerances on the studs and lugs combined with speed from an impact. I run my down on a super low hand tight setting then give it a few whacks when snug then hand torque. They always seem to fail from galling.
Old 05-26-2024, 04:54 AM   #19
gen3v8
gen3v8's Avatar
Yes like the throttle on corner exit when you have power. Squeeze don`t squash the rattle gun trigger. Not that I`m telling you how to operate your machines be they simple or not.
Old 05-26-2024, 03:31 PM   #20
meow
No extra points for speed. I do it all by hand.
humfrz (05-26-2024)
Old 05-26-2024, 05:20 PM   #21
Yep, this tool, applied with "two squeaks and a grunt" has served me well for the past 75 years.
Stephen W. (05-27-2024), Ultramaroon (05-26-2024)
Old 05-26-2024, 05:56 PM   #22
meow
Amen, my friend.
humfrz (05-26-2024), NoHaveMSG (06-02-2024)
Old 05-26-2024, 10:36 PM   #23
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I've converted one rear wheel to ARP studs and plan to do the rest as I get to it. In the meantime I have ARP studs in the car with instructions to anyone who I might have do tire work to replace the entire wheel if one stud breaks.
Qwimby1 is offline   Reply With Quote
Old 06-01-2024, 06:18 PM   #24
e_lunatic
Drives: 2015 Scion FR-S
I never had an issue with the stock lug nuts, however the Toyota dealer that would rotate my tires when i first got it had a hell of a time with them and wound up crossthreading 2 of them leading to breaking 2 of the studs. Stopped taking it to Toyota after that and never had another problem.
I have been running stock studs and aftermarket lugs for about 7 years with zero issues. I also run a small dab of pressure lube on the studs and have never had a torque issue (YMMV).
e_lunatic is offline   Reply With Quote
Old 06-02-2024, 09:15 AM   #25
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Torque test channel recently had one that covered this.
The Following 4 Users Say Thank You to dragoontwo For This Useful Post:
autoracer86 (06-02-2024), blsfrs (06-02-2024), NoHaveMSG (06-02-2024), Ultramaroon (06-02-2024)
Old 06-02-2024, 01:46 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They do a lot of cool videos. It’s nice seeing some of the stuff old timers taught me to be true when he did his mythbusting videos.
bcj (06-02-2024)
Old 06-02-2024, 02:36 PM   #27
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
A buddy of mine used Neverseize on everything from steak to seafood. When he was installing brakes, he put it on the lugs of his Ford Exploder. After about a month, it developed a vibration. He took it to a shop to have his tires rebalanced and guess what.
A. The tires needed balancing.
B. You never use neverseize with seafood.
C. Loose nuts
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
bcj (06-02-2024), NoHaveMSG (06-03-2024), Ultramaroon (06-02-2024)
Old 06-03-2024, 03:40 PM   #28
gen3v8
gen3v8's Avatar
I`m sure if you used a tapered seat with different metals and another product recommended for wheel nuts/studs the results would be completely different. As I have Seen.(Not scene)
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 10:12 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 03:44 PM
Cleaning the red threads on the steering wheel. Frishkorn Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 07-28-2014 01:59 PM
why are there individual threads for every single wheel size and make? VENOM~ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-02-2012 01:32 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 09:21 PM
