Old 06-25-2024, 10:18 PM   #309
86prime
Drives: 18 BRZ tS
Thank goodness for this thread. I just installed MCA traction mod II, STi rear trailing arms, and Whiteline KDT922 bushings, and the car feels great!
86prime is offline   Reply With Quote
The Following 5 Users Say Thank You to 86prime For This Useful Post:
autoracer86 (06-26-2024), kevaughan (11-26-2024), Racecomp Engineering (06-26-2024), RToyo86 (11-26-2024), whataboutbob (06-26-2024)
Old 11-26-2024, 06:55 PM   #310
Kamber
Drives: '22 BRZ | '21 Supra
Does anyone here that did the MCA Traction Mod V2 + STi trailing arms have a list of part numbers handy for any "while-you're-there" replacement hardware/nuts/bolts? Planning on doing these on a new-to-me 2013 FR-S and I'm guessing it could probably use some new hardware since it was a daily for most of its life being converted to a track car. Also, does anyone know if the STi trailing arms compatible with 2nd gen cars as well? Thanks in advanced!
Edit: Found some answers as far as part numbers, details below:
SU00302819 F/bolt-PLT M12 x4
SU00305235 Self Lock Nut M12 x4
SU00300013 Bolt x2 (bolt that holds the bracket cable bracket)
SU00300544 BRKT Cable Guard RH
SU00300545 BRKT Cable Guard LH
TQ Specs
Subframe bolt 145 nm / 106 ft-lbs
Trailing arm bolts 110nm / 81 ft-lbs
19mm MCA bolt 110nm / 81 ft-lbs
Kamber is offline   Reply With Quote
The Following 3 Users Say Thank You to Kamber For This Useful Post:
kevaughan (11-26-2024), norcalpb (11-26-2024), Prodigalson (01-16-2025)
Old 11-26-2024, 08:07 PM   #311
Ohio Enthusiast
Drives: 2018 BRZ
You don't need the parking brake cable guards - the traction mod moving the control arm down makes them rub against the cable. I run without the guards.
Ohio Enthusiast is offline   Reply With Quote
The Following 4 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Kamber (11-27-2024), norcalpb (11-27-2024), RToyo86 (11-27-2024), Tatsu333 (11-27-2024)
Old 11-27-2024, 08:17 PM   #312
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Me too - no guards (as per the install instructions from MCA), though I have thought about putting them back on and just bending them for more clearance...
Tatsu333 is offline   Reply With Quote
Old 11-28-2024, 04:43 PM   #313
Xed32
Drives: '22 brz Sport-Tech
Oooh. Thats what those are....I should remove them. Was wondering what those bent up dangly things were on the trailing arm.
Xed32 is offline   Reply With Quote
Old 11-28-2024, 08:47 PM   #314
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
I bought new ones and ended up removing them as I didn’t love how the cable was pressing against them. Waste of money in the end.
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
norcalpb (11-29-2024)
Old 11-29-2024, 01:26 PM   #315
norcalpb
norcalpb's Avatar
I love how none of us knew we didn’t need that, I say we all combine ours to make a mini statue or something
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
Racecomp Engineering (11-29-2024), Ultramaroon (11-30-2024), whataboutbob (11-29-2024)
Old 11-30-2024, 10:32 AM   #316
StraightOuttaCanadaEh
Wes
Anyone know if these help with winter traction? I have snow tires on, RCE T2 coils, rebound set to softest setting as well, and this shit is like it's on skates with no snow outside. Maybe having more squat in the rear will help
Instagram: @gt86ws
Old 11-30-2024, 11:18 AM   #317
ZDan
ZDan's Avatar
Drives: '23 BRZ
Sounds like a tire issue to me, I don't think any ant-squat geometry will help you if there is so little grip. What specific make/model snow tires?
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Ohio Enthusiast (11-30-2024), Tokay444 (12-02-2024)
Old 11-30-2024, 12:43 PM   #318
Wes
Michelin X-ice Snow (not to be confused with X-ice xi3). They're rated better than the xi3 ... maybe not cold enough? Pavement was dry but it was dark so hard to see if maybe there was frozen dew or something
Instagram: @gt86ws
Old 11-30-2024, 05:17 PM   #319
ZDan
ZDan's Avatar
Drives: '23 BRZ
I’ve had mixed results with dedicated Winter/snow tires. Either they have great snow grip with poor wet/dry grip, or vice versa. Usually go with “Performance Winter” category as in Rhode Island winters are usually not huge amounts of snow.
Old 11-30-2024, 05:45 PM   #320
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
What is your alignment like?
I tried out continental Icecontacts this year and they handle dry roads quite well. The Michelins shouldn't handle terrible
Old 11-30-2024, 10:23 PM   #321
Wes
Camber -3.1 front, -2.0 rear
Toe 0 front, 0.01 rear
I mean I bought the michelins knowing I was gonna sacrifice some snow traction for dry weather handling resembling something sporty. Just wondering if any of that would be due to the car being on aftermarket suspension, and whether the traction mod would help
Instagram: @gt86ws
Old 12-01-2024, 03:47 AM   #322
ZDan
ZDan's Avatar
Drives: '23 BRZ
No amount of suspension mod will give you more grip. Surprising that the Michelins are that bad, but then again the one time I've had traction issues it was down to Michelin tires going "off", to an *alarming* degree. If you are having grip issues with no snow and in dry conditions, your tires suck, bad.
DocWalt (12-01-2024)
Search this Thread:
Advanced Search
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) -- General Topics 48 08-09-2013 06:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 02:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 09:14 PM
