Old 09-06-2024, 12:52 PM   #4453
Tomyyyu
Drives:
Is the front saying the min is 2.8in and max 3.9in? And rear min 5.1in and max 6.1in?
Tomyyyu is offline   Reply With Quote
Old 09-06-2024, 01:05 PM   #4454
Tokay444
Anti stance.
Tokay444's Avatar
Yes.
Old 09-10-2024, 09:47 AM   #4455
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Keep in mind this is with those particular length springs too. Using a different spring length will wildly change those measurements.
cmiovino is offline   Reply With Quote
Old 09-10-2024, 09:48 AM   #4456
Tomyyyu
Drives:
Building out an excel and wanted to collect this info:
Weight of front coilover (each) for T2
Weight of rear coilover (each) for T2
Bump Stop Rate for both Front and Rear bump stops on the T2
Old 10-03-2024, 10:01 AM   #4457
Compelica
Compelica's Avatar
Drives: 86 GT
I'm getting a clunking sound from my HKS GT4 coilovers on pillowball mounts. At first I thought it was due to wear on those bearings, but when I sent it for a rebuild the shop mentioned the bearings were fine, but instead was a fastener/screw(?) that was coming loose.
After the rebuild the clunking stopped, but after 6 months the clunking is back again. Any idea what is causing that clunking, and which fastener that the builder is referring to? The clunking is most obvious when driving slowly over rough roads, but on high speeds it is not that noticeable.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 10-03-2024, 10:55 AM   #4458
Tokay444
Anti stance.
Tokay444's Avatar
Have you tried asking the rebuilder?
Old 10-03-2024, 10:58 AM   #4459
Compelica
Compelica's Avatar
Drives: 86 GT
I have - but it has been some time hence the rebuilder has probably forgotten about it.
Could it be the top hat nut?
Old 10-03-2024, 11:15 AM   #4460
Tokay444
Anti stance.
Tokay444's Avatar
You should definitely start there.
Old 10-03-2024, 12:02 PM   #4461
Racecomp Engineering
And the endlinks. Which isn't part of your coilovers but it's pretty common anyway.
- Andrew
Old 10-03-2024, 12:34 PM   #4462
Compelica
Compelica's Avatar
Drives: 86 GT
- Andrew
Thanks. I'm a novice when it comes to coilovers - what am I supposed to look or check here? Seems there is an Allen key insert and a hexagonal nut, seems like I will have to get the suspension unloaded to check for any free play here?
The clunking is coming from the upper mount area, but I'll check the end links once I can.
I'm reading around on other forums which they mention that top hats have to be tightened with an impact gun but I'm not sure what I'm looking at; any guidance is certainly appreciated.
Old 10-03-2024, 01:12 PM   #4463
Tokay444
Anti stance.
Tokay444's Avatar
The hex is there to hold the shaft stationary while you torque the nut.
Old 10-03-2024, 01:14 PM   #4464
Compelica
Compelica's Avatar
Drives: 86 GT
Probably answering my own question, but looks that I'll have to hold the Allen key insert while tightening the outside nut down.
Manual says to tighten nut down to 49N-m, could do it with an open wrench as my torque wrench is the socketed type which would block the Allen key.
Also to prevent the nut from backing out again, is the nut removable so I can apply blue Loctite to it?
Old 10-03-2024, 01:55 PM   #4465
Tokay444
Anti stance.
Tokay444's Avatar
You can get a crow's foot and run it 90 degrees to your torque wrench so you don't have to math out the difference in torque. I'd use Loctite as a last resort.
Old 11-08-2024, 05:09 AM   #4466
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Here's an odd one regarding KW V3 Clubsport Coilovers:
Is it normal that I'm often hearing hissing sound similiar to let's say bicycle fork operation from rear of the car with this style of coilovers when going through bumps/cracs or speed bumps ?
MrSkubi is offline   Reply With Quote
Search this Thread:
Advanced Search
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
