Old 03-09-2020, 12:47 PM   #29
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Wow. This is what you call progress. I don't know what you do for a day job, but since the market is crashing you should do something on the side in line with what you are doing here.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
The Following User Says Thank You to Swift For This Useful Post:
solidsnake11 (03-09-2020)
Old 03-25-2020, 08:11 AM   #30
wnt3d
wnt3d's Avatar
Drives: Toyota GT86
awesome work bud, you've made some serious grounds in what seems like relatively short time. I've started doing a k24 turb swap aswell, but spare time is now non existent with a new born.
For the motor mounting angle, is it still the factory honda 11degrees (or what ever it is to keep the base part of the oil sump horizontal to the floor) or have you tweaked the angle to suit your setup better.
I was considering remaking a new adapter plate to clock the engine completely vertical to allow for more sump clearance due to this. Do you have any pics from underneath showing the sump clearance to cross member and swaybar clearance.
keep up the good work bud
wnt3d is offline   Reply With Quote
The Following User Says Thank You to wnt3d For This Useful Post:
solidsnake11 (03-25-2020)
Old 03-26-2020, 02:43 AM   #31
wnt3d
wnt3d's Avatar
Drives: Toyota GT86
I see. I still need to finalise height of the engine and box, to work out the mounts. Will trim the stock pan and mock it all up. Maybe with the rough height where my motor is sitting now, the minimal pan space looked difficult but I’ll address that when I get to it.
** no idea how to rotate the attach image, uploaded it off my phone
solidsnake11 (03-26-2020)
Old 03-26-2020, 02:41 PM   #32
ozne99
Drives: GBS BRZ Limited
You make me want to do this swap. Looking good!
ozne99 is offline   Reply With Quote
The Following User Says Thank You to ozne99 For This Useful Post:
Old 03-27-2020, 08:38 PM   #33
nashcarr
Drives: 2020 BRZ tS 247/300, 1995 Miata
Originally Posted by solidsnake11 View Post
The sway bar restricts how far you can lower the engine. If you level it out you will gain sway bar clearance but loose hood clearance. The hood insulation sits on the very front of the valve cover the way mine sits.
Oil pan flange is the next thing to hit maybe 1/2 clearance turbo side on mine
I would recommend keeping the lean, my turbo is on the large side and it fits, there is plenty of room for header and down pipe.
In the sway bar picture I would recommend grinding that bolt boss down for a little extra clearance its on the engine.
Some more good info I found by a guess is the white loop on the wiring that is between the turbo and head is for the timing light. Pulley has a tdc 14, 16 and 18 btdc marks
Check out the Miata K Swap (KMiata) Honda valve covers; they have one where the front part is shaved down so the Miata hood closes without having to cut a hole in it like they used to. It MIGHT work for you.
https://kmiata.com/collections/kmiat...er-for-na-hood
nashcarr is offline   Reply With Quote
The Following 2 Users Say Thank You to nashcarr For This Useful Post:
solidsnake11 (03-27-2020), Yoshoobaroo (03-27-2020)
Old 03-28-2020, 11:33 AM   #34
tomm.brz
Drives: brz 2017 hksv2
Please fix the uploading of your pics!! very curious
Old 03-28-2020, 12:35 PM   #35
tomm.brz
don t know, i do not see any of them
Old 03-28-2020, 01:19 PM   #36
fer3d
Drives: Toyota 86 FT
I see the pictures just fine.
Awesome swap BTW!
Enviado desde mi HD1900 mediante Tapatalk
fer3d is offline   Reply With Quote
The Following User Says Thank You to fer3d For This Useful Post:
solidsnake11 (03-28-2020)
Old 03-29-2020, 12:21 AM   #37
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I don't think I mentioned this but the brz brain does work the vtc on the honda.
How about lift?
Old 03-29-2020, 11:57 AM   #38
Irace86.2.0
My K24 has vtc and also vtec, vtec changes from low to high cam lobe, its rpm operated which can be triggered by a simple rpm switch like MSD makes.
Yes, so you are saying that the brain doesn’t control it?
Old 04-04-2020, 07:44 PM   #39
Evil Rocky
Drives: FRS
That’s amazing you made it work!!
Evil Rocky is offline   Reply With Quote
The Following User Says Thank You to Evil Rocky For This Useful Post:
solidsnake11 (04-04-2020)
Old 04-05-2020, 03:45 AM   #40
mkodama
86Drive Challenge
Drives: 2017 BRZ PP
mkodama is offline   Reply With Quote
The Following User Says Thank You to mkodama For This Useful Post:
solidsnake11 (04-05-2020)
Old 04-06-2020, 10:10 AM   #41
Zer0
Drives: 2015 frs
Is there anybody that could help me with arduino to run a bwm electric water pump I bought the hardware. I just want it to run the water pump doesn't need the lcd or flow meters.
https://www.oudevolvo.nl/en/blog/201...o-successfull/
I have used a pwm controller with a knob to control the speed of DC pumps before. I haven't tried an arduino setup though.
Zer0 is offline   Reply With Quote
The Following User Says Thank You to Zer0 For This Useful Post:
solidsnake11 (04-06-2020)
Old 04-12-2020, 03:10 AM   #42
Zer0
Drives: 2015 frs
Nice can't wait to see your progress once you get a new pump. Excellent work!
solidsnake11 (04-13-2020)
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* JDis3 Cosmetic Modification (Interior/Exterior/Lighting) 31 04-12-2015 05:31 PM
ADVAN GT 18" Concave Face ** Actual Wheels Pics and Weight Pics RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-20-2014 11:16 PM
Release Series 1.0 FR-S & FT-1 Pics from NYIAS (Warning: iPhone Pics) TM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 04-30-2014 03:31 PM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-11-2012 11:29 PM
