08-19-2020, 12:40 PM | #2073 |
Drives: TBA
Downloading FS 2020 over a 660 Mb connection took under an hour directly from Xbox. Installation was easy, the app scans your system and sets defaults. My mid-range machine was set to High-End, a step below Ultra, but still stuttered slightly and randomly at 60 fps during night flight into one of their "hand made" airports. It's maybe due to spreading the screen over three monitors, the 7680X1440 resolution limit of my Nvidia 1080FE card. No issues in daylight flight though.
The terrain and urban detail is gorgeous, real time ATC and Wx that can be customized like pretty much everything else is another world. Even the outlying airport detail is far better than either FSX or P3D. It takes about a minute to cycle through the splash screens before the game loads in another minute. And that's loading from an SSD with 24 Gb memory. Running in Medium User Experience is more demanding than expected, partly due to adjusting to a new control setup that isn't fully mapped and trimmed yet. I already spun in twice turning base to final at my home field, destroying "my" Bonanza. My main squawk is that there's no manual included that I know of so I'm discovering features and settings as I go along. It's going to be quite a learning curve but that's fine, everything about FS 2020 meets expectations. Hopefully I won't need to upgrade any hardware but might need to consider a video card if the occasional stuttering resumes after playing with sliders. |
The Following User Says Thank You to Atmo For This Useful Post: | Dadhawk (08-19-2020) |
08-19-2020, 01:32 PM | #2074 | |
1st86 Driver!
I'm looking forward to seeing the multiscreen setup. I'm hoping they retained the old version where you could have multiple windows then move the views around to where you wanted them, rather than having to use the OS functions for screen spanning, although I'm debating whether I will go multi-screen vs wait for VR to be working, which I would actually prefer as it would be more natural, but probably not as "pretty".
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | Atmo (08-19-2020) |
08-19-2020, 02:11 PM | #2075 | |
Drives: TBA
Not sure about the multi window possibility yet. I'm enjoying the screen spanning that looks realistic with no distortion. The view is tremendous with instant continuous fill to the horizon in all directions from altitudes below 5,000'. Tonight I'll be focusing on dialing in the controls before anything else. Then maybe take a jet up to the flight levels and try an ILS approach once I figure out the autopilot. |
08-19-2020, 02:52 PM | #2076 | |
1st86 Driver!
The spanning may be good enough, if there is no distortion, will try it first chance. Past SIMs used only one camera so there was 3D distortion on the left and right. With multiwindow you get multi-camera so when you turn your head it looks right.
08-19-2020, 03:37 PM | #2077 | |
Drives: TBA
08-19-2020, 09:10 PM | #2078 |
1st86 Driver!
Only had a few minutes to play around with it, but the first thing I wanted to do is see how well it rendered the "middle of nowhere" airport I fly out of. It has ALL the buildings in location including the four rows of T hangers, the tiny FBO and even the "dip" at the end of the runway. In fact, the hangars are accurate enough that they have the right number of bays, and most of them have doors in the right places.
Not bad given this is generated from satellite data and not one of their "handdrawn" airports. This is "me" sitting in front of my virtual actual hangar. The attached has a lot of artifacts because I've shrunk it to fit. Also, I'm only running at 1K HD, not 4K, a limitation of my current monitors.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 08-20-2020 at 08:14 AM. |
The Following 3 Users Say Thank You to Dadhawk For This Useful Post: |
08-20-2020, 12:11 AM | #2079 |
Because compromise ®
Drives: Red Herring
*sigh* No hang gliders
It would seem to be an incredible piece of work. Pity as I'm only a little bit tempted. Is it playable via keyboard and mouse?
The Following User Says Thank You to Captain Snooze For This Useful Post: | Dadhawk (08-20-2020) |
08-20-2020, 08:13 AM | #2080 | |
1st86 Driver!
It's very playable with mouse and keyboard, once you get used to it, but that's always been the case with MSFS. It's easy to forget that, like a real airplane, you don't have to constantly put in input to get a plane to turn, and that you have to correct back, not just go to center to straighten so you'll over correct. I flew it last night for about an hour with just keyboard and mouse. I do find it easier to do in 3rd person thought (outside the plane) then in the cockpit. The "flight lessons" will help with that. Another screenshot. This is over the hospital where I work. What's interesting is that the "landscape" is a composite. The right side is accurate, including the "Y" in the back of the hospital. On the left side, the architecture is a combination of about 6 months ago and 18 months ago. 6 months ago the construction area, and the large building just under the left wingtip were exactly at this stage. Even the curbs (white lines) in the dirt are accurate. Continuing on a direct line off the wings you'll see a 3 story building in front of the tree line. That is where I'm sitting right now typing this. The long building running North/South just right of that building was torn down over 18 months ago, and the building in front of it about 8 months ago. There is a large retention pond there now. The short building directly in front of the left wing at the road has been torn down for 24 months. It was torn down before the building underneath the left wing was started and the large construction area existed. The lake in the left background and the large buildings in front of it are the Southwire manufacturing plants. If you live in the US, there is a good chance that some or all of your home wiring came from those plants. Everything is in the approximate right place for when it was there, it's just they didn't all exist at once. Multiple data sources I guess.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 08-20-2020 at 08:49 AM. |
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Atmo (08-20-2020), Captain Snooze (08-20-2020) |
08-20-2020, 04:27 PM | #2081 | |
Drives: TBA
Yeah, I like chase plane camera view too. You get to enjoy the great scenery while navigating. |
The Following User Says Thank You to Atmo For This Useful Post: | Dadhawk (08-20-2020) |
08-21-2020, 08:37 AM | #2082 | |
1st86 Driver!
It wasn't "awful" but there was definitely stretching and distortion on the left and right monitor.
08-21-2020, 07:58 PM | #2083 |
Drives: Red Herring
[rant]
I know it's still early days and there aren't that many games available displaying ray tracing capability but so far I am not convinced. Looking at these clips, especially the Crysis Remastered one, I see an improvement in the visuals but no improvement in the game. Crysis Remastered is still just Crysis. I'm suggesting that the game engine hacks that are available without ray tracing are good enough. I mentioned how much I enjoyed Deus Ex Revision; the game superseded the lack of graphical fidelity. I want a game, not a photo realistic sim. [/rant]
08-21-2020, 09:02 PM | #2084 | |
Drives: TBA
I really like how it automatically loads real time weather and air traffic. Even ATC is semi-realistic but calmer and easier to understand than most controllers. I attempted to hand fly an ILS into PDX last night but strayed far enough off the localizer that ATC told a transport aircraft arriving on the parallel runway to go around! |
08-21-2020, 09:21 PM | #2085 | |
1st86 Driver!
The one exception is flight sim. In that the more detail the better. In the end that really is the big improvement between versions is visual detail. Flight mechanics were, for the most part, nailed early on in those.
The Following User Says Thank You to Dadhawk For This Useful Post: | Captain Snooze (08-21-2020) |
08-21-2020, 09:36 PM | #2086 | |
1st86 Driver!
It also allows you to set up a separate monitor for your instrument panel that sits below your middle monitor in "just" the right position. I've never set it up that way but it would be great if you could the pic here isn't very good (and its about 10 years old) but it is how I had MSFS X set up using multiple windows. the left/right monitor are angled, so when you slide up, they are on your left/right peripheral vision. Ultimately what I want to do is get 3 50" TVS. Those are right at 40" left to right, which is the size of a Cessna 172 cockpit. But before i go to all that trouble I want to see what the VR is like when it is released.
Tags |
pc master race, u no have 3080 |
Similar Threads | ||||
gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 04:32 PM |
GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 06:37 PM |
