Old 12-11-2014, 11:27 PM   #15
Racecomp Engineering
Originally Posted by Wepeel View Post
Delicious.
Are the default spring rates the same as the T2 (400/400)?
Any particular reason for the 1 year warranty vs. the typical lifetime KW?
Can you elaborate a little about tuning high speed compression vs low speed compression? I understand the low speed=handling high speed=bumps correlation, but from a practical tuning symptom/resolution standpoint.
And what would one expect coming from a set of V3's?
KW does NOT offer ANY warranty on their CLUBSPORTS at all. So a 1 year is generous for ANY damper thats designed and intended to be tracked. As mentioned prior, we see the most aggressively tracked T2's and T zero's last 4-5 years. If there is a defect of some kind in a damper it will normally show up within the first year or 4-5k miles. So a year allows one to take it thru its paces and if there is an issue its covered.
I am thinking of 450/450 for the 3 ways as a default rate.
Coming from a V3 you could expect a more noticeable difference from click to click and more low speed damping and the ability to tune high speed compression. Each click is pronounced so you know what the change affected. Right now your high speed compression is fixed, so you would gain that ability and you can tune the chassis for a wider range of situations.
Hope that helps.
Mw
EDIT: noticed Andy answered those questions !
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
rallysrt (02-04-2016), Wepeel (12-12-2014)
Old 12-11-2014, 11:56 PM   #16
FRSCanuck
Drives: Scion FRS
Originally Posted by cjd View Post
Oof. CSG spec SRC or these... Though I am unsure if I'd actually be able to tune a 3 way well in the near term...
Choices are an awesome thing to have.
+1, I was deadset on CRG SRC's now I'm back at square one.
FRSCanuck is offline   Reply With Quote
Search this Thread:
Advanced Search
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 589 11-21-2021 04:13 PM
Racecomp Engineering Tarmac Springs forwallblakmail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 03-25-2017 11:40 AM
The RaceComp Engineering BRZ "Clubsport" Build Racecomp Engineering Member's Car Journals 100 12-18-2014 02:18 PM
RaceComp Engineering Tarmac Zero coilovers jack43 Brakes, Suspension, Chassis 5 10-03-2014 04:17 PM
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-16-2013 11:02 PM
