Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
11-15-2018, 12:06 AM | #43 |
Drives: FRS
I'm in the same boat. It gets cold here but is often dry. When it snows I'll drive my truck.
In the warm months I don't track my car or take too many risks on spirited back road drives. Feeling like UHP AS tires will be ideal for me. It's not like the Primacys are Pilot Super Sports anyway. I expect to lose some steering response and otherwise not even notice the difference in ultimate grip. If that trade-off opens up a few more months of driving the FRS rather then it's well worth it. |
11-15-2018, 11:50 AM | #44 | |
Sittin' Sideways
Drives: 2016 Toyota FR-S
Since the winter of the PNW isn't what most of the rest of the country deals with for winter, it can be difficult to place one's self in a situation where winter is barely there (but it sounds pretty nice). I can understand being in a position of inconvenience with your living situation, but that would have been good info to put out there up front for people's consideration. Without it, folks will assume you have the ability and/or are willing to do a swap of tires, and that's what they'll suggest because it is the most ideal (but also least convenient). I think the Primacy is ever so slightly more forgiving than a full blown summer tire, but it is still very compromised when the temp drops and the ground isn't dry, so people aren't going to overall recommend you drive on them in those conditions. A UHP All-Season is about as good a tire as you're going to get for something that will not totally neuter this car but also won't send you flying off into a guardrail at 10mph that you can use year-round. Now, ice is ice, and no tire can really save you from it, but if your winters really are that mild they'll get the job done as long as you don't get too excited when the temp is low or there's snow on the ground. Just understand that they're only likely to get you maybe 25-30,000 miles, at best, before they're totally shot (the usual sacrifice of lifespan for grip), and you don't want to be caught in anything but dry weather when they're close to the end of their life. I recommend the Bridgestone Potenza RE970AS Pole Position. Mouthful, but a great tire. Seems to be on its way out, though, so better pick em up while you can. There also appears to be an RE980AS out now (cheaper than the 970s, too), and it looks like they got rid of the directional tread design, so you may get a little more life out of them with rotating the tires if that is the case. I don't know if I'd use the stock tires for any tracking, but the fellas of Everyday Driver did drive a LeMons car on track with those tires because of their lifespan, so I suppose it's doable. Someone out there will want them, just find someone into drifting, they're always looking for crap tires to destroy on the cheap.
-O/D
2016 FR-S, Hot Lava |
11-15-2018, 12:20 PM | #45 |
Drives: 2018 BRZ Limited Perf Pack
The Primacy HPs were not that good in sub 40°F temps for me. Fun, kind of entertaining, but not good. They were ok in general wet stuff, but cold wet was just a recipe for unintended wheelspin.
Get a winter-lite setup like Conti DWS (if available?). You will thank yourself.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon |
11-16-2018, 08:39 PM | #46 | |
Drives: 16 FR-S Raven
Sent from my Pixel XL using Tapatalk |
11-18-2018, 04:31 PM | #47 | |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Last year my Cherokee broke for a while and I had to drive my 86 with the stock summer tires. It was the scariest ride ever. Everyone else was at least able to cruise straight ahead. I was by far the slowest car on the road and everytime I would tap the gas the tail would step out. This year I put some all season Hankooks on that have light snow ability. I would suggest the same to you
12-06-2018, 09:49 AM | #48 |
Drives: '15 GT86 & '22 GR86
Primacys turn to plastic below 7C/45F. Fun and sketchy all rolled into one, the lose their progressiveness which isn't pleasant. They are perfectly usable you just need to tip toe the car around a lot more.
12-28-2018, 10:14 PM | #49 |
Drives: 2022 BRZ Ltd, 2019 Ascent
I just looked up the climate data for my little corner of the Pacific Northwest and it really looks like the Primacy HP tires would have me parked in the garage for eight of the 12 months, that is, if I want to be safe. My 2017 BRZ LTD/Auto. is just an indulgence for the street and not the track. I don't want to mess with swapping wheels; I want to keep it simple. It's cold and wet here much of the year, so it looks like the Michelin Pilot Sport A/S 3+ is a good match for my type of driving. The OEM tires just seem to be at the lower end of temperature range. We have a Subaru Ascent for when it gets cold and frozen, although I think Subaru could have done better than the Falken tires that came fitted from the factory. Traction B? Really? They don't handle that great either. The rest of the Ascent is marvelous, so new tires for that is on the back burner. I remember what it was like to drive in the winter back in the sixties. I was always swapping ends on the turnpike in my Austin Healey. Tire tech was nothing like it is today. The Pilots are available at Costco for a good cost and I am thinking this is a good idea even thought the OEM tires are practically new.
12-28-2018, 10:32 PM | #50 | |
Sent from my Pixel XL using Tapatalk Last edited by Audio; 12-28-2018 at 10:40 PM. Reason: I got a/s 3+ now and they are a bit stiff. Still to early to review so... |
12-29-2018, 03:05 PM | #51 |
[QUOTE=Audio;3167591]A/s premier. Great tire, have a/s 3+ now and it's a bit stiff. But still good in the rain. Snow= tbd
If you are recommending Michelin Premier A/S for the BRZ, I think I will pass. I put them on our 2014 Forester to replace the original Yokohama Geolander tires that barely lasted 25,000 mile and wore unevenly. The Michelin Premier outperformed the Yokohama in every respect, but it appears that it won't be a high milage tire. It does not start out with much tread depth and it got annoying when it goes in for service the service advisor tells us the tires are worn out. "No, did you look at the wear indicator bars?", I say. One thing the Michelin tires do is that they wear evenly across the tire tread unlike the Yokos. My daughter has the Forester now and I would recommend the Premier as replacement when it's time. The Pilots are a compromise in some respects, but getting an automatic BRZ was a compromise to my driving situation, so I don't think I will lose much sleep over tires. I did get out in the wet and low 40's the other day and if that is the way it's going to be, papa got to get new shoes. |
12-29-2018, 03:22 PM | #52 |
ProCrastinationConsultant
i measure my tire wear in years. if i get 2 years out a set of tires, i'm happy.
my brz just passed 30k mi, and i have a sticky note to order it's 3rd set of tires come summer this year...
The Following 2 Users Say Thank You to soundman98 For This Useful Post: | atomicalex (01-09-2019), Audio (12-30-2018) |
12-30-2018, 02:59 PM | #53 |
Any comments on the Bridgestone Potenza RE980AS? I reviewed the tests that compare to the Michelin Pilot Sport A/S 3+, the Pirelli and the Continental tires and they all seem to be comparable. I saw them at Costco and the cost is about the same as the Michelin after the $70 rebate.
01-09-2019, 07:41 AM | #54 |
Just fitted Michelin Pilot Sport A/S 3+. Much improved at 35-55 deg. on wet roads. I do see that on this car it is more of a 3 season tire.
Comments after driving around town: I feel that the new tires are better suited for road conditions when it's cold out, but I notice that the handling is not a precise as with the Primacy HP. Has anyone played with tire pressure? Last edited by Flarpswitch; 01-09-2019 at 06:42 PM. |
01-15-2019, 09:36 PM | #55 |
Drives: 2018 BRZ
Quick update... I got so many mixed opinions about switching out the stock tires that I was 50-50 on it... I finally took the car to Discount Tire in late November and asked them to put on some all-seasons. The guy came out and looked at the Primacies and asked why in the world I would want to swap them, and was convinced that all-seasons wouldn't actually be any safer in the cold... now, I know that some 20 year old working at Discount Tire isn't necessarily an expert, but since I was already 50-50 on it, that was enough to sway me to keep the tires.
Since then it has been down in the high-30s, low-40s a bunch of times and the car drives just fine, wet or dry. I've tested the limits several times just to make sure, stepping the back out on purpose (when it's safe obviously), and it doesn't seem to take that much less effort than when the temperatures were in the 50s. I'm pretty sure I have at least as much traction as any "regular" car on the road at those temperatures. Probably more. A week or two ago it snowed a bit (very lightly, for like 2 hours, at night). The temperature was ~33 degrees and it all turned to slush immediately. So with a very small amount of slush on the road, I waited until late at night and drove the car gingerly to a nearby empty parking lot to see if it was a rolling deathtrap in such conditions. I slid it around for a while and was frankly astonished by the amount of grip it had. Vastly more grip than my old BMW that was fitted with all-season tires (which WAS a rolling deathtrap in such conditions). So I'm just going to keep the tires for this winter (and probably next winter) and avoid driving when there's any snow or ice on the road. For everybody who posted horror stories about the Primacies in the cold, I'm not sure how to explain our vastly different experiences. Maybe when the tires get worn down a bit more they will lose whatever cold-weather traction they have now. Or maybe you guys are much more aggressive drivers than I am? Dunno. But right now they tires seem actually pretty good to me. |
01-16-2019, 03:54 AM | #56 |
Drives: 2014 GT86
What? Tire shop guy, that tells that all-seasons won't be better then summer tires in cold? Who hired him?
As for aggressiveness .. there is a bit that one has to drive just fast enough to drive with the flow. For others to not need extra overtakes, to be able to merge in traffic and such. And then there is driving culture, that may differ. Eg. keeping due lacking grip long enough intervals between cars will mean someone will try to cut in all the time. And then bit of "unexpected". Some mistake or willing breaking of rules done by others, something you couldn't expect/plan out before due simply not seeing that due blind corner, hard to notice patch of black ice, critters, pets, kids .. and yes, including skidding out or not able to brake others still on summer tires . There is always need for some safety margin, if unexpected need for emergency braking/maneuvering arise. |
Similar Threads | ||||
Stock Primacy in "winter" temperatures? | Brink | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 12-06-2017 03:57 AM |
winter tires "perform better" | dtrop | BRZ First-Gen (2012+) -- General Topics | 13 | 12-24-2016 08:02 PM |
WTB: 16" Winter tires | brzcu | Canada Classifieds | 0 | 10-23-2016 09:46 PM |
WORK Meister S1R - 17"/18"/19" Any Spec --- Winter Promotion - end 10/31/13 !!!!! | RavSpec | Wheels and Tires | 1 | 10-28-2013 11:31 PM |
Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
