Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-17-2021, 11:32 AM | #15 |
Drives: 2014 GT86
makinen: interesting video. Except cause for for rocker arm bearing failure over rev was mentioned. Can we blame part for failing then?
06-18-2021, 02:03 PM | #16 |
Drives: 2013 frs base
Does this happen with our FA20s?
06-19-2021, 10:25 AM | #17 |
Drives: 13 White MT FR-S
The Following User Says Thank You to ML For This Useful Post: | blsfrs (06-19-2021) |
06-20-2021, 10:54 AM | #18 | |
Drives: Toyota 86
Over-revving and valve float could be occurred first. But our rocker arms are floating design, therefore it is inevitable to be ejected when not enough force acts on valve stems. If rocker arms have rigid shafts through them like e46 m3 or similar designs, we don't have to worry about time bomb. When I experienced the ejections I was in normal RPM range. The time I actually did over-revving (over the stock red line) was several crankings before.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller HKS GT EL header, 17MY intake manifold */ |
The Following User Says Thank You to makinen For This Useful Post: | blsfrs (06-20-2021) |
06-21-2021, 09:31 PM | #19 |
Here's what we need.
06-30-2021, 12:46 PM | #20 |
Probable cause
#3, where I lost my intake rockers showed signs of something being sucked in to the engine. There was some damage to the piston, cylinder wall, and valve seats. About a month before this started, I installed an oil catch can. I could have possibly introduced a small metal fragment then. Still 3-4 weeks from getting my engine back.
06-30-2021, 03:40 PM | #21 |
Drives: Crapcan
Received a package from Australia. Now waiting on some 1217H. And time, could really use a few more hours in the day.
06-30-2021, 08:18 PM | #22 |
I read a couple of articles talking about oem iron valve guides with stainless steel valve causing galling. Mine had the oem guides but no evidence of problems there. Being rebuild with bronze alloy guides.
07-01-2021, 01:29 PM | #23 |
Drives: Crapcan
I hadn't heard that before. I could see improper reaming creating galling. Or improper heat treat on the SS part would also do it.
07-02-2021, 09:18 AM | #24 |
From Enginebuildersmag.com "
Valve guides can be generally classified into two groups: cast iron and manganese bronze, which covers a wide range of applications. Cast iron guides are used mostly by OEMs due to its wear characteristics that result in longevity for high mileage applications. Cast iron is used with chrome valve stem applications as well. Cast iron cannot be used with stainless steel because of its tendency to gall. That’s why high performance applications do not warrant the use of cast guides due to the fact the material can’t handle the high loads associated with higher spring pressures. Under high stress, cast iron guides tend to crack and fracture, which can result in engine failure altogether. Cast iron is inexpensive and works best with daily drivers and high mileage applications. For any kind of performance application, the choice is manganese bronze. The way to pronounce this correctly is MAN-GA-NESE. I often hear this as magnesium, which is not correct. Manganese bronze is ideal for performance because it is more compatible with titanium and stainless steel. https://www.calverst.com/technical-i...als-and-usage/ Just for reference. |
07-02-2021, 11:29 AM | #25 | |
Drives: Crapcan
We liked to use copper beryllium seats with either bronze or copper guides depending on application for built engines.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (07-02-2021) |
07-09-2021, 04:34 PM | #26 |
Drives: 2013 Scion FRS
07-09-2021, 05:09 PM | #27 |
Drives: Crapcan
Yes they are. Had them in about a week. Sent from my iPhone using Tapatalk
07-09-2021, 05:14 PM | #28 |
Similar Threads | ||||
Rocker arm ticking? | Xman17 | Issues | Warranty | Recalls / TSB | 15 | 10-22-2019 02:56 PM |
Rocker Arm Failure | Worstenemy453 | Issues | Warranty | Recalls / TSB | 65 | 10-12-2019 08:50 AM |
Rocker arm failed | displacedTexan | Issues | Warranty | Recalls / TSB | 77 | 08-22-2018 06:16 PM |
Rocker Panel Damage Repaint Question | kzale1249 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 02-06-2017 02:37 AM |
Rusty Rocker | Nassty | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 1 | 04-01-2014 07:47 PM |
