Old 11-29-2019, 08:20 AM   #281
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
https://www.facebook.com/SwapYour86/...0814113471737/
Pure Automotive is offline   Reply With Quote
The Following 4 Users Say Thank You to Pure Automotive For This Useful Post:
pgranberg11 (12-12-2019), solidsnake11 (12-15-2019), Sportsguy83 (12-02-2019), wparsons (12-13-2019)
Old 12-12-2019, 10:35 AM   #282
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
oooooooo man. this swap is about to fuck up the competition.
pgranberg11 is offline   Reply With Quote
Old 12-12-2019, 11:21 AM   #283
Icecreamtruk
Drives: Track preped NA FRS
Yes, this is the swap to have. My engine just need to last a bit longer!
Old 01-13-2020, 09:49 PM   #284
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by solidsnake11 View Post
Yeah, an AWD transplant with an inline 4-cylinder would be terrible. Those pics are also a good reference for anyone saying they should do a K-swap with the stock transmission; without moving the engine back, the motor will be 3-4” beyond the FA20–maybe more.
Old 01-13-2020, 10:08 PM   #285
Irace86.2.0
k24 is 100lbs lighter. Put the extra 100lbs in the trunk same weight in the end with more on the rear.
Yeah, that could offset the shift up and forward.
Edit: And in the case of AWD with a 4-cylinder, the extra weight of the AWD front diff and axles would offset some of that weight loss.
Old 01-14-2020, 11:09 PM   #286
Irace86.2.0
The k24 is ~2 1/2 inches longer than the fa20.
Still terrible for AWD. More acceptable by 0.5-1.5” than previously estimated if adapted to the BRZ’s tranny, that’s assuming there is no adapter plate that adds thickness between the tranny and engine of course.
And are you talking about the block length or engine length? Any links to dimensions? How about the height difference?
Old 01-14-2020, 11:26 PM   #287
solidsnake11
Drives: brz
crank bolt to bellhousing face. if your going awd just swap the cr-v transaxle and the wagon coupling.
solidsnake11 is offline   Reply With Quote
Old 01-14-2020, 11:52 PM   #288
Irace86.2.0
K24 + AWD might be a bad idea...
https://engineswapdepot.com/?p=18106
Old 01-14-2020, 11:56 PM   #289
Irace86.2.0
Huh?
Old 01-15-2020, 02:15 AM   #290
Irace86.2.0
The same way the honda guys make awd civics.
So are you suggesting someone transplant a transverse k24 into the BRZ because if not then I don’t understand how those components would work longitudinally?
Just saying: AWD isn’t exactly better, except in certain conditions, so the idea seems to be without merit. I would think the Civic Type R would have proved that.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
DustinS (01-15-2020)
Old 01-15-2020, 05:24 PM   #291
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Then the issue is you now have all the weight from engine and transmission up front, with a primarily FWD twin. I think I would rather an EVO drivetrain swap if I am going that route. (maybe k24 to evo trans adapter?)
My suggestion for someone wanting awd swap (which I REALLY want to do, and will eventually), is either an r34 sequential with custom bellhousing (kind of like Rob Dahms awd rx7), the t56 with transfer case that is available (less than ideal as the driveshaft is on driver side and will have issues with steering shaft), or GR6 transaxle from a R35 mounted in the back. (My favorite as it moves a lot of the weight to the rear and is a DCT). All of which will require a ton of money/fabrication to make work. The swap will also cut into the cabin for the extra driveshaft and transfer case. You also have to take into consideration front subframe in relation to the driveshafts and front diff, front diff and axles in relation to an engine that can't move up any, and a driveshaft that that realistically needs to be on the passenger side, and trying to fit an exhaust at the same (unless hood dump is your fancy)
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
Irace86.2.0 (01-18-2020)
Old 01-15-2020, 05:53 PM   #292
Ashikabi
Ashikabi's Avatar
That all sounds like an incredible amount of shit to stuff under this car.
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
Calum (01-17-2020), gtengr (01-16-2020)
Old 01-15-2020, 05:56 PM   #293
DustinS
DustinS's Avatar
Yes. Which makes it not worth it for about 99.8% of people.
Old 01-15-2020, 06:02 PM   #294
Ashikabi
Ashikabi's Avatar
I'll bet it's fewer than that. Honestly fitting the LS in here was pretty hard. It's not possible to get AWD components in here without SIGNIFICANT modifications to the belly of the car. You're well beyond an engine swap and deep into one off gimmick project territory. But of course you understand this and want to do it anyways
The Following User Says Thank You to Ashikabi For This Useful Post:
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! Pure Automotive Engine Swaps 29 01-10-2018 01:20 AM
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap Pure Automotive Engine Swap 0 12-01-2017 11:57 AM
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:49 AM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:23 AM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 06:33 PM
