03-05-2021, 04:40 PM | #29 | |
Drives: 2013 FR-S Argento
Yup tons of other things obviously make a difference - just saying that it's one thing that front bias can help with vs. rear bias, and might actually be part of the design considerations. Tons of other factors outside of weight distribution (50/50 or otherwise) cumulatively can make a much bigger difference overall. |
03-05-2021, 06:12 PM | #30 | |
Drives: '23 BRZ
The Following 2 Users Say Thank You to ZDan For This Useful Post: | bfrank1972 (03-05-2021), Hoahao (03-06-2021) |
03-05-2021, 06:15 PM | #31 |
Drives: Q5 + BRZ + M796
Here is my photoshop using a weak photoshop-like tool, but I elongated the hood and smoothed out some lines.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | WolfpackS2k (03-08-2021), ZDan (03-05-2021) |
03-05-2021, 06:33 PM | #32 | |
Drives: '23 BRZ
For *me*, I'd rather have the shorter wheelbase than the longer hood. However, if a 500hp powerplant is going in, this ^^^ is the way to go... |
The Following 2 Users Say Thank You to ZDan For This Useful Post: | Irace86.2.0 (03-07-2021), soundman98 (03-05-2021) |
03-05-2021, 06:41 PM | #33 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
start saving up for a f-type?
03-05-2021, 06:53 PM | #34 |
Drives: '23 BRZ
The Following User Says Thank You to ZDan For This Useful Post: | Irace86.2.0 (03-05-2021) |
03-05-2021, 08:05 PM | #35 |
I’m more a fan of the looks more than the reliability and interior. Weight and no manual at all anymore and no manual on the V8. This ties into what I was saying in the other thread about the manual transmissions going:
https://carbuzz.com/news/now-is-the-...-jaguar-f-type
03-07-2021, 08:06 AM | #36 | ||
Drives: '23 BRZ
For sure if you just move the rear wheels forward 10" with no other changes, the car will be more responsive and less understeery. Shorter wheelbase, lower polar moment, more turn rate for given steering angle, front tires less overloaded. I don't think that would make the car unstable, but for sure it would make it more *responsive*, which could be perceived as twitchiness. This could be mitigated with a slower steering rack to give same rate of turn per steering wheel input. The AP1 S2000 has plenty quick steering with a 13.9:1 rack, vs. FT86 13:1. If you ratio by wheelbase they should have the same turn rate per steering wheel input. Leaving spring rates and sway bar rates the same (front-stiffness biased for 55/45) for the 50/50 2-seater would "correct" to some degree the change in under/oversteer balance at the limit from the improved weight distribution. Could also go with some tire stagger. Keeping the same average 215 tire width they could go with AP1 stagger at 205F/225R. IMO not necessary but it's another knob to tweak if desired. Anyway, I've never found *responsiveness* to be an issue with lightweight/low-polar-moment cars as long as the suspension geometry is good (AP1 shortcoming). The best-handling car I've ever driven was a tiny 600-lb. Formula 440 at Road Atlanta years ago. I had only a few track events in my 240Z under my belt at the time, and I found the F440 to be *sweet* to drive. Very pointable, but also very easy to recover. Starting to think maybe I buy a 2nd-gen in a couple of years and do some cutting and welding on the '17 PP... Last edited by ZDan; 03-07-2021 at 08:34 AM. |
03-07-2021, 12:09 PM | #37 | |
Drives: 2017 Toyota 86 (860 SE)
I love those 'chops, btw. I don't mind the 2+2, but I would adore a true 2-seater. Especially if it had a fastback and a liftgate like my dad's old Mustang... We can dream, right? |
The Following User Says Thank You to Cephas For This Useful Post: | ZDan (03-07-2021) |
03-07-2021, 01:02 PM | #38 |
Drives: Dodge Patitas
I say it looks cute AF. Don't have much use for the rear seats other than cargo room, so I guess Z-car interior proportions would be fine by me.
The Following User Says Thank You to sato For This Useful Post: | ZDan (03-07-2021) |
03-08-2021, 07:24 AM | #39 |
In some states you'd get dinged pretty good on insurance rates for a two seater. The shorter wheelbase on a car this light would probably make the ride suck for a daily driver. I agree with the F Type sentiment, that car is so damned hot...
The Following User Says Thank You to gravitylover For This Useful Post: | Dadhawk (03-08-2021) |
03-08-2021, 09:00 AM | #40 |
With the understanding that this whole topic is based upon theories and wishes there was probably no way they could make the rear much shorter even if it was only a two seater. North American crash standards have a minimum crumple distance for both front and rear which can be difficult to meet. Sure they can pull it off with the right platform but there are probably very good reasons that this platform just couldn't do it without a full redesign. A full new design will just mean compromises elsewhere which would end up with a car that has totally difference characteristics than the 2+2. The changes could be good or they could be really really bad.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (03-08-2021), ichitaka05 (03-08-2021) |
03-08-2021, 09:51 AM | #41 |
Senior Citizen Member
The Following 2 Users Say Thank You to LimitedSlip For This Useful Post: | gravitylover (03-08-2021), Tcoat (03-08-2021) |
03-08-2021, 10:12 AM | #42 |
I for one would not have bought if a two seater. The rear seats may not be great but at least they are there when needed.
The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (03-08-2021) |
Similar Threads | ||||
Is The Crossover The New Sports Car? FT86 Vs. BMW X7 M50i Vs. Supra & 8 | rennlistuser3 | FR-S / BRZ vs.... | 45 | 08-08-2020 11:22 AM |
[||•]=(FT86)=[•||] SWITCHBACKS | LED DOMELIGHT | MORE LEDS --> [||•]=(FT86)=[•||] | 86SPEED | Interior Parts (Incl. Lighting) | 10 | 10-25-2018 03:13 PM |
Evasive FT86 Service & Maintenance Thread Discount Labor for FT86 Members | Evasive Motorsports | Southern California | 423 | 10-01-2018 12:49 PM |
Has the FT86 changed the sports car industry? | husker741 | Scion FR-S / Toyota 86 GT86 General Forum | 112 | 10-24-2013 09:15 AM |
GTS owners... difference between 'sports' abd 'vsc sports' button? | UnLeasHer | AUSTRALIA | 5 | 07-26-2012 03:22 AM |
