Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission
Old 12-07-2020, 02:25 PM   #15
86TOYO2k17
Drives: 2017 toyota 86
+1 Main reason it should not be used with AN fittings. ...in this application, at least.
If you light some candles, dim the lights, turn on some smooth jazz, poor some champagne, and give your AN fitting a bath in thread sealant you might have a problem.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Jdmjunkie (12-07-2020)
Old 12-07-2020, 02:32 PM   #16
boost schmoost
It's all upstream of the filter but janky work is janky.
Old 12-07-2020, 04:14 PM   #17
Ashikabi
Ashikabi's Avatar
It's upstream until you have a different application with a remote filter. Then you're just an underpaid toyota technician trying to rebuild boxer motors lol
Sent from my ONEPLUS A5010 using Tapatalk
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
Ohio Enthusiast (12-07-2020), Ultramaroon (12-07-2020)
Old 12-07-2020, 08:40 PM   #18
boost schmoost
You have me there. That's just sad.
Old 12-08-2020, 09:00 PM   #19
Gloonge
Drives: 2013 frs raven
how did you pressure test the lines? air? water? oil, cold/hot?
where are the lines leaking? you mention crimping, is it leaking at the hose but before the connection, or at the threaded connection point?
what sealing methods have you attempted so far?
Was not getting notifications for this, sorry. Pressurized the lines and the core as an assembly with about 200psi of air. Outdoor temp was around 80 I would guess. And I dunked them into a tank of water, no bubbles to be seen.
And they are leaking around the nut side, at the top where the nut articulates.
Gloonge is offline   Reply With Quote
Old 12-08-2020, 09:02 PM   #20
Gloonge
These gaskets are a godsend. I keep extras on hand.
I actually have these installed, and I am still having issues with one fitting. Might have to bite the bullet and buy yet another fitting and seal.
Old 12-08-2020, 09:04 PM   #21
Gloonge
Originally Posted by DarkPira7e View Post
Whenever I've used AN fitting, I don't tighten them much. If you're putting any force into tightening it, it is more prone to leaking in my experience.
Do not use PTFE tape
Just make them a little snug and allow the system to put pressure to them. After a few warm/cool cycles, make them a little more snug. I've even gotten Mishimoto AN fittings to hold this way
I have tried everything from just past snug, to way tighter than they should ever be and I get the same seeping every damn time.
Old 12-08-2020, 09:23 PM   #22
DarkPira7e
No, my car doesn't run
DarkPira7e's Avatar
I'd just replace the fittings. I use Phenix fittings for my stuff and don't have issues
Old 12-08-2020, 09:23 PM   #23
boost schmoost
In my case, the female side of the 12-AN fitting was bent together ever so slightly into an oval. I don't know if they are dropped in a step of the manufacturing process, piled together too deeply in a bin, or whatever. It's disappointing that it is so common. I'd gladly pay a premium for better quality control.
Phenix? Hmmm.... They sure are pretty. I'd have gone with them had I known.
Old 12-10-2020, 07:27 PM   #24
Grady
Grady's Avatar
Drives: BRZ Yellow, 2019 Ranger
No dope or tape on AN fittings period. I have built hundreds and installed thousands of AN fitting hoses. If torqued correct they almost never leak. Yes on troublesome ones the conical seals help.
The Following User Says Thank You to Grady For This Useful Post:
Ultramaroon (12-10-2020)
Jackson Racing Dual Radiator/Oil Cooler + SS Lines tyler_win_photo Engine, Exhaust, Bolt-Ons 3 08-26-2018 10:42 PM
Perrin oil cooler lines Joesurf79 Engine, Exhaust, Bolt-Ons 2 07-24-2018 08:33 AM
Oil cooler, lenght of your lines? trdric Engine, Exhaust, Transmission 2 07-09-2015 03:23 AM
Removing dirty oil from oil cooler and lines jdp530 Engine, Exhaust, Transmission 31 04-07-2015 05:49 PM
Copyright ©2000 - 2021, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
