Old 02-04-2019, 08:21 PM   #29
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Originally Posted by Merc View Post
OEM 86 sensor correct? Where did you add yours in. Mrs said they don't have a unit for an ls1 unfortunately but trying to find an alternative. I would attempt adruino but I need a new home computer or laptop so i would be dropping a few hundred either way.
No, factory LS sensor, to the factory GM ECU. MRS Canbus translating the temp signal to gauges from GM ecu.
spitsnaugle is offline   Reply With Quote
Old 02-04-2019, 08:26 PM   #30
Ashikabi
Ashikabi's Avatar
What are you trying to accomplish? Operate the factory temp gauge or an aftermarket gauge that will show exact numbers?
Old 02-04-2019, 08:53 PM   #31
Merc
Drives: Subaru brz 2013 LS1 swap
Aftermarket for better numbers and stock sensor to trigger fans. I'm using OEM relays. Unless I'm looking at it wrong.
Merc is offline   Reply With Quote
Old 02-04-2019, 09:03 PM   #32
Ashikabi
Ashikabi's Avatar
Aftermarket, just get a port in there somewhere and plug that shit in. No sweat. For OEM gauge, just use whichever works with your computer choice. Probably the stock LS sensor
The Following User Says Thank You to Ashikabi For This Useful Post:
Merc (02-04-2019)
Old 02-04-2019, 09:13 PM   #33
Merc
Thanks I have a way of over complicating in my head sometimes.
Old 02-04-2019, 09:17 PM   #34
Ashikabi
Ashikabi's Avatar
Same. If you check the classifieds you might find some gauges for a good price
Old 01-29-2022, 02:55 AM   #35
chewbacca
Drives: Frs-t
Fuel pump controller bypass wiring setup
Hello, I am in the process in getting the Radium's dual pump hanger with their two relays kit. I'm dubious on how to connect all this correct.
Can any of you guys could help wire the signal wires and the power wires?
I doubt that saying that a standalone is installed but, if it does then it is.
Thank you
chewbacca is offline   Reply With Quote
Old 01-29-2022, 06:18 AM   #36
Ashikabi
Ashikabi's Avatar
Thank you
Not sure on if your computer is switching positive or negative. Let's assume it's positive: signal+goes to computer, ground is ground, load1 should go to a power source like the battery or distribution block, load 2 goes to the pump, then the pump needs grounded. Or you could run +straight to the pump and break the ground with the relay. If it's not clear which pin is which on the relay, look online for a diagram with that many pins. Relay numbering should be standard. These aren't Radium specific relays
Tail light wiring question andrew_l_s Cosmetic Modification (Interior/Exterior/Lighting) 0 08-14-2015 10:13 PM
DRL Wiring Question afoust50 Cosmetic Modification (Interior/Exterior/Lighting) 6 08-14-2014 04:25 PM
headlight wiring question Lydin Cosmetic Modification (Interior/Exterior/Lighting) 0 04-11-2014 10:02 PM
Wiring Harness Question Sigh-on-Rice Electronics | Audio | NAV | Infotainment 0 08-10-2013 10:46 PM
New Head Unit Wiring Question sikest Electronics | Audio | NAV | Infotainment 2 01-17-2013 05:15 PM
