BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
07-04-2020, 12:33 AM | #15 |
Drives: '13 Subaru BRZ Crystal Black Silica
So I think that's normal from assembly. It happens. What if i told you there are GM cars out there that have a piece of plastic plug chilling in your oil pan? Lol its because during assembly, the plug is pushed out and it just sit there. I forget where the location of the plug is, but its just a place holder to prevent FOD. It is actually a good think the oil pick up is there; it did its job. Yes, it is preventing flow slightly, but its not crazy in my opinion.
From factory in an unopened engine, there is actually a crap ton of RTV. You can actually see this in my photo when I fixed my timing cover leak. Its so much that you could consider that it could have clogged the oil pickup long ago. If the assembly line is too quick and the RTV is not cured properly, or there are too many loose ends, it can be picked up by the hot oil. To be honest too, the amount of RTV around the cover is actually a generous amount. The only parts where it needs to be thinner is where the oil passages are close to RTV bead.
IG: setgo.moto
The Following 3 Users Say Thank You to Setgo For This Useful Post: |
07-04-2020, 12:41 AM | #16 | |
In regards to rod knock, could be. I think a majority of rod knock that we see documented are individuals that are redlining the crap out of the car, boosting it beyond the FA20's capabilities, or just straight beating on it which would make the rods bend. Rod knock is mainly the integrity of the rod itself. If anything, it would cause a piston to seize up from lack of oil to the oil ring. But if that were to happen, you would know, like immediately. With a hole in your block lol.
IG: setgo.moto
The Following 2 Users Say Thank You to Setgo For This Useful Post: | 1234eher (07-04-2020), soundman98 (07-04-2020) |
07-04-2020, 12:57 AM | #17 |
Also, SO MUCH CRINGE AND A TERRIBLE WAY OF REMOVING THE OIL PAN in the damn video, what the actual F*. And then using the screwdriver to pry the pan off? LAWD HAVE MERCY! Not the right way of doing it.
IG: setgo.moto
The Following 2 Users Say Thank You to Setgo For This Useful Post: | DarkPira7e (07-04-2020), soundman98 (07-04-2020) |
07-04-2020, 01:05 AM | #18 | |
Drives: 2014 FRS
07-04-2020, 01:05 AM | #19 |
Drives: 2014 FRS
07-04-2020, 01:07 AM | #20 |
Drives: 2014 FRS
07-04-2020, 01:26 AM | #21 | |
I mean those are all possibilities with the RTV. But mind you, this could happen to literally any car. Some spots to put RTV on in the FA20 are: timing cover, valve cover, cam covers and where the case halves mate. In almost all modern cars today use RTV as part of the assembly so hopefully that gives you a little peace of mind. Lol but i can really freak you up if i told you that you would find metal in your oil during your initial oil changes lol. And those stuck chunks in the screen would probably stay there for eternity lol. ALSO IMPORTANT NOTE: The engineers are not dumb. Look at the design of the pick up tube. It would sit in a bath of oil and suck up the oil through the mesh screen, into the engine. Anything sucked up in the tube will hit the mesh right? Now consider when the car is turned off. The running oil going through the screen, going into the oil pan, and settling at the bottom. And then you do your oil change and then what? The RTV comes out with the oil because of the design of the oil pick up. *mic drop*
IG: setgo.moto
The Following User Says Thank You to Setgo For This Useful Post: | 1234eher (07-04-2020) |
07-04-2020, 01:49 AM | #22 | |
Drives: 2014 FRS
What's your tips for preventative maintenance and prolonging engine life? I do my oil changes every 5K-7K km. In all, I'm guessing this isn't something to be too worried about? |
07-04-2020, 01:50 AM | #23 |
Drives: 2014 FRS
I just don't want to lose oil pressure because of some stupid loose rtv and spin a bearing
07-04-2020, 02:00 AM | #24 | |
If you haven't already, replace your cam plate because the OE plate is just a plate with RTV. That will leak oil right onto your overpipe. Overall, do what your doing, and replace as you approach the maintenance schedules. And lastly, there are many mods out there, not all mods benefit the platform. Some are too race car, and some are the right amount for street cars, but it all comes down to opinion. Do your research beforehand and understand the FA20 before just slapping something on. Just because its made, doesn't mean it should be installed.( I'M TALKING TO YOU LIGHTWEIGHT CRANK PULLEYS GANG)
IG: setgo.moto
07-04-2020, 02:11 AM | #25 | |
Drives: 2014 FRS
What oil do you use? I rotate between Royal purple and Mobil1 |
07-04-2020, 02:16 AM | #26 |
Drives: 2014 FRS
Also, what do you think of engine flushes? Needed? Good? Or harmful?
Toyota Canada provides these but I'm almost certain it's not made by Toyota |
07-04-2020, 02:40 AM | #27 | |
That toyota stuff, i mean if they do it and something goes wrong, its on them. but i dont think it matters if you are doing routine maintenance.
IG: setgo.moto
07-04-2020, 10:21 AM | #28 | |
ProCrastinationConsultant
Tags |
maintanence, oil change, oil change engine damage, sealant |
Similar Threads | ||||
FS: Stock brake lines, stock clutch line, stock motor mounts | Agent_D | Brakes, Suspension, Chassis | 4 | 08-22-2017 12:24 PM |
AIMGAIN FB/RB/SS Kit - In Stock -- Immediate Shipping / Pick Up | RavSpec | Exterior Parts - The Rest | 6 | 06-11-2015 05:09 PM |
Time to build a motor, what options have others found? | Cross | Forced Induction | 188 | 11-25-2014 10:10 AM |
TOM's LED Tailight For FRS/BRZ ---- In Stock (Pick up or ship) | RavSpec | Exterior Parts - Lighting | 86 | 07-23-2014 12:49 PM |
