Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-26-2017, 12:33 AM | #1 |
trex
Drives: brz
brake calliper painting
I was wondering if I could just paint the calliper with it still on instead of taking the calliper off to paint it. I am just worried that there might be stuff happening if I accidentally get paint into some parts. Is that possible or do I really have to take the whole calliper off in order to paint it? I tried looking for videos on how to take the callipers off. The only thing about that is that I am just scared that I'm going to mess up while putting it back on.
03-26-2017, 12:59 AM | #2 |
Drives: brz 2017 hksv2
just do it, I did this yesterday, with the calipers on
03-26-2017, 12:59 AM | #3 |
義理チョコ
Learning how to properly (remove, disassemble, reassemble, install, bleed) your calipers is way more important than painting them.
A clean set of OEM calipers is much classier than painting them in a vain attempt at disguising them. Everybody knows. At best it looks immature and cheap. It goes downhill from there.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (03-26-2017) |
03-26-2017, 03:05 AM | #4 |
trex
Drives: brz
03-26-2017, 03:05 AM | #5 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
Sure looks easy to me.
The brake caliper support (metal bracket) can be painted off the car...just two bolts to remove. Brake caliper itself can be painted, loose, but still with brake hose attached, on car. You just don't want paint on the brake pads, brake caliper piston area, or any rubber parts. If you want paint to stick, must wash, scrub, and rinse, dry all metal parts before any paint application. Reinstalling calipers over brake pads may require pinching slightly (retracting) caliper piston with large channel lock pliers, or similar tool. Rear brake piston must be twisted clockwise to get it to retract. Generic pics here: https://www.google.com/search?site=&...akes&*&imgrc=_ Worth any and all effort, as you'll certainly learn in the process. Caliper and Caliper support >how to< removal here: [ame="https://www.youtube.com/watch?v=s8P5TSadb_w"]How to replace front brake pads and disc rotors on SCION FRS FR-S SUBARU BRZ - YouTube[/ame] Last edited by ToySub1946; 03-26-2017 at 03:36 AM. |
03-26-2017, 04:26 AM | #6 |
03-26-2017, 05:49 AM | #7 | |
Drives: Grrrr
Oh dear... |
03-26-2017, 07:19 AM | #8 |
Huge E85 fan!
Drives: 2016 Scion FRS
It's not a problem painting them on the car. You don't have to remove them or anything. If you spray paint them, tape everything off. I used a kit with a brush so I had to do very little taping. If you get any paint on your rotor, it'll get scrubbed off after your first drive.
03-26-2017, 10:05 AM | #9 | |
Besides the stock brakes are pretty good anyway. |
03-26-2017, 10:31 AM | #11 |
Drives: WRB 2017 BRZ Limited w/ PP
Painting stock calipers just reinforces you have typical calipers. But hey it's your car, do what you want.
The Following User Says Thank You to Last Lemming Alive For This Useful Post: | JD001 (03-26-2017) |
03-26-2017, 11:00 AM | #12 | |
Drives: MY17 Asphalt 86
If you want the big brake look without doing it right you might as well just go ahead and go all the way. Why stop at paintinting? Just get you some of these.... Brembo Covers |
03-26-2017, 03:05 PM | #13 |
Drives: 2019 Mazda Miata RF
Who said the op was trying to make it look like the car has a big brake kit?
You can't just make something look better anymore? and the owners opinion of what looks better, is the only one that matters. |
The Following 5 Users Say Thank You to Gunman For This Useful Post: | FT86Z (05-08-2018), guybo (03-26-2017), Is Always Angry (03-26-2017), Keenercarguy (06-10-2017), stevesnj (08-12-2017) |
03-26-2017, 03:29 PM | #14 |
You are right, however if you stick it up for public viewing you have to accept the fact that people will voice their opinion - rightly or wrongly.
Tags |
callipers, diy, paint |
Similar Threads | ||||
DIY Brake Caliper Painting | post_break | DIY (Do-It-Yourself) Guides | 18 | 07-20-2018 12:54 PM |
Brake Caliper Painting | Frishkorn | DIY (Do-It-Yourself) Guides | 4 | 09-29-2014 06:50 PM |
Autobody Shop/Painting Near Me ? Issue with Painting Carbon Fiber Hood? | ScionFR-S | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 11-08-2013 01:51 PM |
Painting the Brake Calipers | Wasta | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-26-2013 08:12 AM |
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
