Forced Induction Turbo, Supercharger, Methanol, Nitrous |
02-05-2018, 10:34 PM | #1 |
Drives: Panda FR-S
Atmospheric Pressure Sensor
Does anyone know where this is? When I log, I'm getting really low readings, like 74kpa and the car runs like crap. I wan't to try to replace it to see if it remedies the issue.
I'm on the Vortech kit.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
02-06-2018, 03:29 AM | #2 |
Drives: UK GT86
If memory serve correctly, the USDM cars use the CPC sensor to monitor atmo pressure. If you've repurposed the CPC sensor in EcuTek then the atmo pressure is derived from the MAP sensor I believe.
.: Stealth 86 :.
02-07-2018, 01:10 AM | #3 | |
Drives: Panda FR-S
If the atmospheric pressure is derived from the MAP, then that would mean I may have a faulty MAP if the atm pressure is off?
02-07-2018, 03:01 AM | #4 |
Drives: Toyota GTS 86
Are you sure there an atmospheric pressure sensor at all? I thought there is just the MAP in the inlet manifold.
The MAP also has inlet air temp and there is a outside air temp (but this only makes it as far as the dash - probably gets CAN'd across the the ECU from there). |
02-07-2018, 05:12 AM | #5 | ||
Drives: UK GT86
Also, the MAP does not have Intake Air Temp. That's on the MAF sensor.
.: Stealth 86 :.
02-07-2018, 05:25 AM | #6 |
I stand corrected. Thank you. I knew there was a reason the MAF was still installed but didn’t recall what it was (I have a speed density tune and the ariflow part of the MAF is no longer connected).
01-10-2022, 10:03 PM | #7 |
Where are these terminal blocks. I can' seem to find them and these instructions from Delicious Tuning don't give you much detail! |
01-11-2022, 11:18 AM | #8 |
LMGTFY
Drives: 13 FRS, 91 Miata
Similar Threads | ||||
Which oil pressure sensor, and which method of mounting? | johnmk | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 07-20-2016 12:01 PM |
Broken Oil pressure sensor? | Dream20b | Issues | Warranty | Recalls / TSB | 38 | 01-01-2016 06:02 PM |
Where BRZ ATM pressure sensor?? | silviahrc | Engine, Exhaust, Transmission | 3 | 12-12-2015 03:28 AM |
Oil pressure and Oil Temp sensor - where did you mount them and how | philooo | Engine, Exhaust, Transmission | 11 | 05-29-2015 02:41 AM |
DI pressure sensor calibration? - standalone | ElectronSpeed | Engine, Exhaust, Transmission | 0 | 02-27-2013 11:38 PM |
