Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-12-2021, 07:35 PM | #1 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Torsional Vibration Damper - FA20
Engine Labs article on the development of the Fluidampr for the FA20.
It has in interesting comparison between the various alternative designs of crank pulleys using a twin as a test mule. https://www.enginelabs.com/news/gues...rzwrx-dampers/
Slow is smooth, and smooth is fast
The Following 4 Users Say Thank You to Capt Spaulding For This Useful Post: |
05-13-2021, 09:03 AM | #2 |
Be Kind
Drives: 2020 86
Six year old article... I wonder if anyone is running this?
05-13-2021, 09:08 AM | #3 |
Drives: '15 BRZ RA
It looks to be an old article. Do they want to sell the old stock?
05-13-2021, 09:25 AM | #4 |
Be Kind
Drives: 2020 86
For anyone who wants to dig a little deeper: https://www.ft86club.com/forums/show....php?p=3302739
05-13-2021, 09:41 AM | #5 |
Rust bucket enthusiast
I knew I had seen this data somewhere. Still, a nice re-read
The Following User Says Thank You to DarkPira7e For This Useful Post: | Wally86 (05-13-2021) |
05-13-2021, 10:06 AM | #6 | |
LMGTFY
Drives: 13 FRS, 91 Miata
The Fluidamper made more power than the OEM and the lightweight lost power. Then of course there is no way to verify said dyno sheet. |
05-13-2021, 10:28 AM | #7 | |
Be Kind
Drives: 2020 86
On the plus side, if a shop wanted too, they could easily replicate this experiment.
05-13-2021, 10:47 AM | #8 |
Drives: 17 Asphalt 86
Interesting. What I took from this is when/if I ever lighten the flywheel I will add this to parts list.
05-13-2021, 10:59 AM | #9 | |
I'm looking for perceived engine roughness, and noise mostly. Still not sure if I'll make the effort just yet but I'll post it I do. My build is a long ways out still do don't expect anything soon
05-13-2021, 12:51 PM | #10 |
Drives: _
OEMs spend a lot of time and resources to tune the whole accessory drive system - rotational inertias, damping coeffs, and frequencies. Unless you tune the whole system including flywheel and all accessories on the belt, it's not wise to change one pulley or flywheel and leave the rest stock. Sometimes torsional dampers work better, some other times having a higher polar inertia work better to tune out the firing order vibrations (2nd in our case).
Higher the inertia, lower the "shock loading". That's why heavier flywheels give smoother ramp ups and ramp downs. |
05-13-2021, 02:02 PM | #11 |
Persona Non Grata
Thanks for the insights guys. Sorry if it's old hat to most of you. I noticed the article is a bit long in the tooth (as am I). I ran across it reading up on harmonic balancers/torsional dampers which led me to Fluidampr's site. As a non-engineer what I found most interesting was the theory regarding what's happening. For the mechanical engineering unwashed such as myself Fluidampr's website has some interesting reading material - including a link to another old article about torsional vibration issues with Cosworth's old CA F1 engine (an NA 20,000 rpm, 2.4L V8).
For me anyway, it put to rest the "high performance lightweight crank pulley" fable.
The Following User Says Thank You to Capt Spaulding For This Useful Post: | Wally86 (05-13-2021) |
05-13-2021, 03:15 PM | #12 |
Drives: Scion FRS 10 series
I have run the Fluidampr for 2 years as a daily, the engine powerband feels smoother than stock, no issues at all. It's not a power adder, it will help the engine in the long run. Here is another article from Motoiq https://motoiq.com/fluidampr-the-independent-test/
The Following 4 Users Say Thank You to Project_1796 For This Useful Post: | Capt Spaulding (05-13-2021), DarkPira7e (05-13-2021), Wally86 (05-13-2021), whataboutbob (05-14-2021) |
05-13-2021, 05:16 PM | #13 |
There's absolutely nothing wrong with sharing good, helpful, nonspeculative information I'd rather see an article like this pop up twice a month than shenanigans about the next gen BRZ that people are guessing about
The Following User Says Thank You to DarkPira7e For This Useful Post: | Capt Spaulding (05-13-2021) |
05-13-2021, 06:26 PM | #14 | |
Be Kind
Drives: 2020 86
If this helps make the motor sound less like a diesel, I'm all for it
The Following User Says Thank You to Wally86 For This Useful Post: | Capt Spaulding (05-13-2021) |
Similar Threads | ||||
Performing FA20 swap with new FA20 | Ctoner2653 | Engine Swaps | 8 | 09-24-2021 08:40 AM |
Blown 2016 FA20 swap 2017 FA20 | HRLQN | Engine Swaps | 11 | 10-15-2019 07:17 AM |
FRS VS BRZ Damper (strut) | kilohercas | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 09-24-2015 03:11 PM |
Damper crosstalk | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-01-2013 02:21 AM |
