Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-11-2020, 07:46 PM | #1 |
Drives: 2013 frs raven
Worth trying to rebuild?
Younger buddy of mine neglected to keep an eye on his oil level after I mentioned a valve cover leak to him and he developed a pretty loud knock above 3k rpms.
I'm sure he spun a rod bearing or two. My question is, with the cost of used Motors for these things is it worth tearing a part and cleaning and replacing (oversized) after machining or is the result a similar price for just a chance? We would do the work ourselves (other than the machining.) |
12-11-2020, 07:52 PM | #2 | |
Also, valve cover leak probably didn't cause motor to take a shit Sent from my ONEPLUS A5010 using Tapatalk |
The Following User Says Thank You to Ashikabi For This Useful Post: | Lantanafrs2 (12-12-2020) |
12-11-2020, 08:00 PM | #3 | |
Are the really that bad to repair? I'm not experienced with boxers but I do rebuild engines from time to time. |
12-11-2020, 08:56 PM | #4 | |
Those motors have a lot of parts. Tolerances are very tight. Shit Toyota technicians can't even do it right. That said, it's totally possible to do. But when you can get a motor for a few grand and have it pulled and installed in a day... I LS swapped mine instead of rebuilding Sent from my ONEPLUS A5010 using Tapatalk |
12-11-2020, 09:03 PM | #5 |
Site Moderator
Drives: Stuff
They are more of a pain in the ass. If you pay someone make sure they know what they hell they are doing..
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
12-11-2020, 09:09 PM | #6 |
ProCrastinationConsultant
do you think you're better at repairing a motor than a toyota tech?
https://www.thedrive.com/news/26848/...-their-engines because i don't think i am.
12-11-2020, 09:53 PM | #7 | |
義理チョコ
Manuals in my sig line and I'm sure the recall procedure is here somewhere. I'd do it in a heartbeat but I have old fart experience.
12-12-2020, 07:45 AM | #8 |
I enjoyed rebuilding mine with the exception of cleaning the original packing seal off. All total I probably have 24 hours simply scraping off packing. The rest of the engine is easy to work on. It’s crazy east to pull. Being a boxer it’s perfectly balanced on an engine stand. You can flip it upside down, right side up or any side without the stand trying to flip.
Applying the packing isn’t even hard, you just have to take it seriously. Too much is bad, too little is bad and in the wrong place is bad. The illustrations in the service manual (linked in post above) are vague but the instructions for the valve spring recall are very detailed. I rebuilt mine before the recall so I had to go off the service manual and mine came out fine. I had 87k miles when I rebuilt and today I have 121k. I drive my car like I stole it. It’s red lined ~10 times per day (literally). I also take several rarely used high gload off ramps in my daily commute which I probably run near 1g at higher RPMs. I also autox the car. Long story short, if I did a bad job it would probably have taken a dump by now. Most of the recalled engines that failed made it less than 20k before spinning a bearing. I don’t think the Toyota techs are less skilled, they just don’t take it as serious as an owner would. They also weren’t allotted enough time for the job personally so they are forced to rush the job. They also aren’t doing a full rebuild so if any packing drops into the engine while cleaning there is no way to get it out. On a full rebuild you can flush the crap out of the engine with water after cleaning. BTW, I am a software developer with no on the job experience rebuilding engines. I’ve rebuilt several engines and manual transmissions, just not as a profession and no official training. I also debated replacing the whole engine VS a rebuild. All total I had about $2500 in the rebuild but I know what I have. I know I have a brand new short block. This engine has a history of bad packing from the factory (at least early builds did) so I felt like the odds of blowing up another used engine was higher than rebuilding with a brand new short block. So I rebuilt and don’t regret it one bit. |
The Following 5 Users Say Thank You to ermax For This Useful Post: | bcj (12-12-2020), gravitylover (12-28-2020), NoHaveMSG (12-21-2020), Spuds (12-27-2020), Ultramaroon (12-12-2020) |
12-12-2020, 08:48 AM | #9 | |
12-12-2020, 10:57 AM | #10 | |
My time is worth more than that too but my goal wasn’t to save money. It was to have a car I felt confident in driving the shit out of. I also enjoy projects like this. Not so much the scraping part but the rest was fun. |
The Following 3 Users Say Thank You to ermax For This Useful Post: |
12-12-2020, 11:25 AM | #11 | |
12-12-2020, 01:16 PM | #12 | |
義理チョコ
process > end goal = happiness
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | ermax (12-12-2020), soundman98 (12-12-2020) |
12-20-2020, 08:03 PM | #13 | |
Drives: 2017 Toyota 86
12-21-2020, 11:13 AM | #14 |
If you like projects and enjoy then rebuild yourself. If you just want the car running again, just go the easier albeit more expensive way and get someone knowledgeable to do it. Overtime the money you spend will be forgotten, so many other things in life will require money that once it’s gone it’s gone.
I just put $800 into my 04 WRX to fix rust issues on the rear body where the suspension bolts to the body. I was hours away from the shock going through it. It sucked to payout 800 just to have the same car I had before. But 2 months later, all is well and I don’t even think about it, I just enjoy the car. My Indian friends have some saying like “pay a lot you cry once, try to cheap out you cry over and over”. Similar to you get what you pay for. If you think you can do a better job and have the skill and time then do it. |
The Following 2 Users Say Thank You to Ernest72 For This Useful Post: | Spuds (12-27-2020), Ultramaroon (12-21-2020) |
Similar Threads | ||||
Engine rebuild | Locost7 | Engine, Exhaust, Transmission | 2 | 09-14-2020 12:50 PM |
Shifter rebuild kit? | radroach | Engine, Exhaust, Transmission | 5 | 10-15-2018 12:16 PM |
Can RSR coilovers be rebuild? | ysr50guy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-19-2017 12:34 PM |
Vortech rebuild | 86gt? | Forced Induction | 7 | 03-28-2016 03:33 PM |
BRZ Rebuild (Mulekr1) | mulekr1 | Member's Car Journals | 3 | 11-15-2015 10:53 AM |
