Old 07-28-2020, 10:03 PM   #225
solidsnake11
Drives: brz
I am not for sure you posted it or used one but the old Chevrolets had shims, to shim the starter. Sometimes if the shims were left out they would bind up, cause them to drag and eat teeth.
solidsnake11 is offline   Reply With Quote
Old 07-28-2020, 10:08 PM   #226
Ashikabi
Ashikabi's Avatar
Originally Posted by solidsnake11 View Post
I am not for sure you posted it or used one but the old Chevrolets had shims, to shim the starter. Sometimes if the shims were left out they would bind up, cause them to turn slow and eat teeth.
My teeth got ripped off because the motor kept kicking. Since I fixed my timing issue I haven't had a single bad start. I don't recall if I posted it but if you run wasted spark then your timing is doubled on a timing light. Once I figured that out it was GGEZ.
This time my pilot bearing failed but my clutch and flywheel survived
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
solidsnake11 (07-28-2020)
Old 07-28-2020, 10:34 PM   #227
solidsnake11
Drives: brz
It was just for info on chevy starters.
Glad you got it fixed.
Old 07-28-2020, 10:38 PM   #228
Ashikabi
Ashikabi's Avatar
All good. Mine didn't come with or seem to need shims. I could only shim it one way (down) anyways. I had a stock starter and now a big aftermarket unit. Both mount the same
Old 07-29-2020, 11:16 AM   #229
solidsnake11
Drives: brz
Old 07-29-2020, 11:20 AM   #230
Ashikabi
Ashikabi's Avatar
Guess I just got lucky
Old 08-05-2020, 09:08 PM   #231
Ashikabi
Ashikabi's Avatar
Ram throwout review: install wasn't hard. Unit felt really solid, looked good. I had to use one of my normal LS slave spacers on top of every included spacer with the Ram slave. Pedal feel is significantly stiffer. Engagement is good. I'm satisfied with the unit. And it can be rebuilt
Old 10-08-2020, 07:07 PM   #232
Ashikabi
Ashikabi's Avatar
Alright, the update I've been teasing for a long time now: air conditioning.
I don't have many pics simply because of how hard it is to get good images and I don't have any from the install. I wanted to run this kit for a while to make sure everything was good, and life got in the way. Excuses, excuses, I know. Anyways, I have the demo "premium" kit from SAVAGE! Autoworks. The premium kit was never made available due to cost concerns but the budget kit is available and is using the same proprietary parts. You can find the kits at savageautoworks.shop . Don't mind the rust, I have a vented hood and my fitting sits right under the vents
Kit requires the customer to assemble their own hoses, but provides all necessary components to connect your GM compressor to the Subaru condenser and firewall. The hardline with the pressure sensor is retained and just needs bent a little to fit.
I'm also running the SAVAGE! fuel starvation door. It's a little more affordable than some of the other options on the market.
Old 10-09-2020, 11:55 AM   #233
gtpvette
Drives: 2015 FRS - FFR GTM
Like the braided hoses!! Have a question,, been thinking about it a bit. When putting together a system with new and used parts,, how do you handle oil in the system?? I've got used compressor, new condenser, new lines, used evaporator. Not sure how oil is handled..
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 10-09-2020, 12:18 PM   #234
Ashikabi
Ashikabi's Avatar
Honestly... I dunno. What little oil that stayed in the evaporator just stays there I guess. I was pondering that last night actually.
Old 12-05-2020, 02:43 PM   #235
Ashikabi
Ashikabi's Avatar
Decided to modify my intake manifold. I don't have the room between the manifold and hood too fit a new manifold so I chopped the snout off of my LS1 manifold and grafted on an aluminum one I built. JB weld to attach it and bondo to make it look smooth. Will get repainted blue. My purpose was to increase the inlet size and direct mount my 4 bolt throttle body. Only half of the inlet could be enlarged though because of the front most runner. But size was gained
Old 11-07-2021, 11:06 AM   #236
Ashikabi
Ashikabi's Avatar
So I forgot to update this: intake manifold didn't hold. Don't bother, just buy an aftermarket
Old 11-15-2021, 10:53 AM   #237
all4spl
I have a lead on an intake that fits with no problems with sikky kit which is very close to the CX kit.
all4spl is offline   Reply With Quote
