08-12-2012, 03:34 PM | #43 |
Drives: Asphalt FRS
WTF? I didn't know I purchased an XB! Thanks for the info!
08-22-2012, 10:32 AM | #44 |
Drives: 2013 Ultramarine FR-S
More Confused than before
So my Pioneer base head unit doesn't have an option to select "FR-S". I went online to the Scion live chat thing and this was the conversation:
Clayton: Hi, my name is Clayton. How may I help you? Kurt Anderson: Hi Clayton. I have a question about the Pioneer base audio unit in my 2013 FR-S Clayton: Thank you for contacting Scion. How can I further assist you today? Kurt Anderson: In the audio manual, it tells you how to set the audio preset to the correct Scion model type (i.e. xB, iQ, tC, FR-S) Kurt Anderson: however, on my audio system, I can select the preset for any current Scion model except the FR-S, there is no FR-S to select, just xB, xD, iQ, and tC. Kurt Anderson: do you know why this would be? Clayton: I can certainly look into that for you. Kurt Anderson: thanks Clayton: Please standby while I research that for you. Kurt Anderson: ok thanks Kurt Anderson: not sure if this helps - but I've been on some forums with this question, and someone replied that I should check the part # of the Pioneer head unit. He said that TOYOTA PART NO. PT546-00120 does not have the FR-S preset but TOYOTA PART NO. PT546-00130 does have it. I can't know if that's accurate or not, but may be helpful if the part #s he references are actual Toyota/Scion parts. Clayton: Thank you for your patience, I apologize for the delay. Clayton: I was looking through a copy of the manual and was only able to find the tC, xB, xD and iQ settings for the standard audio system. Clayton: The BeSpoke premium audio system has an FR-S mode but not the standard Pioneer unit. Kurt Anderson: ok Clayton: Is there anything else I can assist you with today? Kurt Anderson: no that was it Clayton: Thank you for contacting Scion. Have a great day! So my question is - does anyone here (from the U.S./Canada) with the Pioneer base audio have the same issue as I have? (no FR-S option to select). It seems that most do/some don't - and then the Scion customer service rep says there is NO FR-S selection on the Pioneer base head unit. /Frustrated. |
08-24-2012, 06:07 PM | #45 | |
Drives: Firestorm FR-S 6MT
The base audio manual on Scion’s web site is old. If you look at the online manual (http://www.scion.com/assets/pdf/audio/2012_Pioneer_Audio.pdf), the cover says PT546-00120, and the FR-S mode does not show up in p.52. However, if you look at your own manual, the cover should say PT546-00130, and the FR-S mode should be in the p.52 (at least in mine).
http://www.ft86club.com/forums/showthread.php?t=10048
2013 Scion Firestorm FR-S MT
08-26-2012, 09:30 PM | #46 |
Az to Nm to Az
Pg. 52 of my manual talks about power mirrors. Regardless, I was able to set my stereo to the appropriate vehicle of choice. I have had an Xb since 2008 when the big body style came out...wonder if I should finally look at those settings...lol.
"The FR-S stock stereo system is terrible, but this is why I drive with the windows down and the pedal to the floor."
It's a sleeper...I launch, it feels like it's asleep.
08-26-2012, 09:57 PM | #47 | |
08-29-2012, 04:43 PM | #48 |
Drives: 2018 Camry XSE V6
If anyone is using an ipod or mp3, and you are finding the sound lacks mid-range sound, there is an option in the sound settings called ASR and when activated it boosts the mid-range for a much better overall experience. As a side note, I also tune it to feel for more bass.
09-14-2012, 03:24 PM | #49 |
Does this also hold true for the BRZ Limited? Haven't had time to check my radio.
09-17-2012, 02:38 AM | #50 |
Drives: 2013 Raven Black FRS
Mine was set to Tc as well... and I changed the OPENING to now say "DARTH RAVEN".... so whenever I turn the car on the first thing shown on the radio display says that... pretty damn cool!
The Following 2 Users Say Thank You to ravenblackfrs For This Useful Post: | RMStringer (01-05-2013), VictorKassil (05-09-2013) |
10-02-2012, 12:34 AM | #51 |
SoCal Asphalt FR-S Owner
Drives: 13' Asphalt FR-S
Mine was also set to TC. What a difference when switching to FR-S!! WOW!
10-29-2012, 09:38 PM | #52 |
The salesman at the Toyota/Scion dealership was pretty into the FR-S and mentioned that he set my stereo to 'FR-S' from 'Tc'.
When I reset my ECU during an intake swap - the stero went back to 'Tc' Thus 'Tc' must be some sort of default on the base Panisonic stero units. |
11-06-2012, 08:48 PM | #53 | |
Drives: FR-S Firestorm 6MT
My Canadian FRS radio is the upgraded unit ("Premium"), similar to the Bespoke unit in the US. I also don't have a FRS setting, and it has been over 3 months with no news fromthe dealer on how to fix this. My rep is apparently waiting for a new FRS to arrive so he can swap out the Premium out of it and put it in mine. I suggested that he order a new one from parts and said it is not available, only as a port-installed option prior to delivery. Frustrated as well. |
12-17-2012, 07:53 PM | #54 |
Drives: 2013 Scion FRS
Thank you! Mine wasn't set correctly either.
12-21-2012, 05:29 PM | #55 |
Drives: Argento FR-S
Well figures. Mine was also set up as TC
01-05-2013, 07:07 PM | #56 | |
Opening Radio!
How did you do that?? Please tell me!
Similar Threads | ||||
Wrong Fuel | Hawx | AUSTRALIA | 22 | 12-11-2011 06:08 PM |
16 inch wheels for the base model!!! | Blokatos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-07-2011 11:17 AM |
Base BRZ exterior pictures? | mines13 | BRZ First-Gen (2012+) -- General Topics | 15 | 12-05-2011 02:11 PM |
Feds find majority of Toyota unintended acceleration cases were people hitting wrong | ichitaka05 | Other Vehicles & General Automotive Discussions | 15 | 03-16-2011 01:19 AM |
Could this be the base FT-86 boxer engine? | iff2mastamatt | Engine, Exhaust, Transmission | 2 | 02-10-2011 10:55 PM |
