Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-26-2022, 03:58 AM | #1 |
Drives: 2007 Acura CSX Type S
Valve Adjustment interval
From what I understand, the FA20 has a shim and bucket valve train, which doesn't automatically adjust valve lash by itself. On my Honda, the service interval for valve adjustments is 100,000 miles (160,000km).
Has anybody had to adjust their valves just from normal wear and tear? What mileage interval does it take for this to become a problem? I've only seen posts of people having to do this fairly early on, due to manufacture defect. |
01-26-2022, 08:32 AM | #2 |
I would not pull this engine just to check/adjust valve clearance. If it is not broke do not fix it.
The Following User Says Thank You to Grady For This Useful Post: | humfrz (01-28-2022) |
01-26-2022, 09:21 AM | #3 |
Sarcastic SOB
After almost 10 years in the market, a simple web search should turn up information on the frequency of occurrence. I'd say it is very low.
Similar Threads | ||||
Valve clearance adjustment issue | bobel | Engine, Exhaust, Transmission | 35 | 02-29-2020 02:52 PM |
2017 M/T, 29k miles, requiring valve adjustment | Mr. Kurtz | Issues | Warranty | Recalls / TSB | 19 | 03-06-2019 01:08 PM |
Valve Adjustment @ 22miles | Mizu | Issues | Warranty | Recalls / TSB | 11 | 11-24-2018 03:42 AM |
PCV Valve maintenance interval | radroach | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 07-05-2017 01:29 AM |
Valve adjustment | GsxrMe | Engine, Exhaust, Transmission | 11 | 01-14-2017 06:07 PM |
