Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-11-2021, 05:05 PM | #1 |
Drives: 2013 Subaru brz limited
Weight
I removed my spare, jack, and so forth back when I was n/a now I'm on 265/35/18, and I'm having terrible grip issues would a ts9 Enkei w/ 265/35/18 fit in the spare section? Also, would that somewhat help even out the weight? I have bc racing 8k coil-overs I feel that they are stiff as hell(they work though lol)which may play a part in my grip issue as well watcha think! Btw im supercharged
11-11-2021, 05:20 PM | #2 |
Drives: Crapcan
8K is not helping, little weight transfer. Low profile tire not helping. I'd also look at mca traction mod.
11-11-2021, 05:35 PM | #3 |
Sounds about right! What are your suggestions I'm all ears!! because my current setup just isn’t there for me its great in corners but not enjoyable when giving it the beans.
11-11-2021, 09:37 PM | #4 |
When you say grip issues when is that? If it is off the line straight? If so how much rear camber do you have? What tires do you have? How much HP are you pushing? Softer springs would allow more weight transfer to the rear.
The Following User Says Thank You to Grady For This Useful Post: | ACT86 (11-12-2021) |
11-11-2021, 09:46 PM | #5 | |
Grip issues off the line. The rear camber is flush they set up to stock recommendations I'm running federal rs-pros and hp I'm not quite sure it's very torquey though that first and second is basically useless. Also lowest string rate bc goes to is 8k if im not mistaken. Could I switch springs with a different brand? Sent from my iPhone using Tapatalk |
11-11-2021, 10:02 PM | #6 | |
The Following User Says Thank You to Grady For This Useful Post: | IsaiahW (11-11-2021) |
11-15-2021, 09:23 PM | #7 |
Señor Member
So to me I'd be checking your alignment, looking at 17" wheels instead of 18"s, getting some quality coilovers with lighter springs (probably around 5k or 6K), adding the bits you took out of the trunk back and the MCA traction mod.
Beyond that you can see if your tuner has a performance based traction control they can add to your tune as well as practicing smoother launches and 1st to 2nd shifts. Don't just dump the clutch.
1974 TA22 Celica
2013 86 GT |
Similar Threads | ||||
PP Brembo front rotor weight, lighter-weight alternatives? | ZDan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 02-14-2022 07:03 PM |
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 11:38 AM |
Weight of your brz/frs | NYCsubaruBRZ | NY / NJ / CT / PA | 5 | 02-12-2014 07:11 PM |
Overall weight. | archer | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 12-19-2013 09:52 PM |
Weight..... | icemang17 | Tracking / Autocross / HPDE / Drifting | 2 | 07-02-2012 06:24 PM |
