Old 04-17-2016, 04:13 PM   #2535
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Did you guys use any sealant on the fittings that go into the sandwich plate from the oil cooler?
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 04-17-2016, 05:45 PM   #2536
Northwest86
Drives: Velocity Orange 86 GT
Only 567 loctite. Shes good for 10000 psi now there. Shame about the oring design
Northwest86 is offline   Reply With Quote
Old 04-17-2016, 08:08 PM   #2537
mashal
DADA
mashal's Avatar
Drives: 2013
Anyone have a picture of what is attached to the bottom of the oil catch can? is there a plug on the drain bung? The shop emptied line last time and now the bung is just open
mashal is offline   Reply With Quote
Old 04-18-2016, 01:32 PM   #2538
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by FRS Johnny View Post
YES! I have the same issues. And I can't seem to get it to stop leaking. I've emailed FBM a few months back but nothing really helped. I called FBM and they said that was the first time they heard this issue when I called this month. I don't know what to do about it either...
They're sending me out 2 new orings so I can replace both. Originally I didn't put any sealant on and it was good for about 2 years including heavy track days in hot Florida. I'll probably put a thin layer of toyogoop on this time around. I dont plan on replacing the cooler so I'll probably loctite it as well.
My issue was the oring split. So this should fix it.
Ironsquid is offline   Reply With Quote
Old 04-18-2016, 01:48 PM   #2539
FRS Johnny
FRS Johnny's Avatar
I see. Mine kept leaking from the oil cooler fitting lines, so I bought new fittings, so hopefully it fixes the issue! Keep it updated on the fix!
Old 04-18-2016, 01:52 PM   #2540
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Originally Posted by Northwest86 View Post
I've given up on my sandwich plate. We've got single piece (no spacer block) units for the 86 coming in the next few weeks.
If the new oring doesnt seal well, I'll probably think about welding it on. Probably a pita, but so is broken seals at the track.
Old 04-18-2016, 06:19 PM   #2541
Northwest86
Mine arent broken they just seal badly. Hence why our tuner who also tracks his car heavily has got the single piece sandwich plate. Hes seen alot of products and frequently will get something made for the local people when no decent solution exists
Old 04-18-2016, 06:21 PM   #2542
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
Is yours an early model? Supposedly the early models had leaks at the fittings that's why the newer versions have crimped fittings. Also prices were increased because of the new fittings I think.
xDBOYx is offline   Reply With Quote
Old 04-18-2016, 08:51 PM   #2543
FRS Johnny
FRS Johnny's Avatar
I bought mine in Nov of 2015. Don't think they have updated it since then, but I haven't really been keeping up to date on new parts and revisions. Going to be changing the fittings tomorrow as well as installing a trd sandwich plate to hook up the oil temp/pressure gauges.
Old 04-18-2016, 08:55 PM   #2544
xDBOYx
xDBOYx's Avatar
Hmm I definately bought mine way before that and I had crimp fittings.
Old 04-18-2016, 09:20 PM   #2545
FRS Johnny
FRS Johnny's Avatar
Maybe the issue is that the 45 degree fittings are angled a way so you can't 100% fully tighten them? Just a thought but what do I know.. lol
Old 04-19-2016, 09:15 AM   #2546
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Fakk View Post
Are you? If yes, I'll make sure to get some sweet cell phone quality pictures of you ripping it up. Maybe a video or two.
The current plan is that my car will be there, but I won't be driving it. I am lending it to another S2000 owner because his new turbo S2000 beast is still on the west coast.
The Following User Says Thank You to King Tut For This Useful Post:
Fakk (04-21-2016)
Old 05-08-2016, 12:47 AM   #2547
mashal
DADA
mashal's Avatar
Drives: 2013
So car broke down and trying to figure out what's wrong, until the shop looks at it Monday.
I was just cruising on 5th and all of a sudden loss power drop gears and as I went down in gear I lost more power.. Tried to pull in to the next parking lot and car started shaking and choked out. Tried firing it back up and it starts but shakes aggressively and then chokes out again. I had an oil leak a couple days ago from my oil cooler so that's the first thing I checked and it was low, I topped it up but didn't need much, about a quart. Tried starting again and same thing.. Looked at every hose and they are all attached, I do not get any codes or nothing. Car has fuel.
I did pressure washer the engine Bay earlier and the car was running fine all day until I drove it later in the evening.
I managed to get it pulled into the lot with some help and its parked there until it gets towed.
Any ideas?
Old 05-08-2016, 01:15 AM   #2548
mashal
DADA
mashal's Avatar
Drives: 2013
Could it be spark plug?
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
