Tracking / Autocross / HPDE / Drifting What these cars were built for! |
11-19-2021, 01:48 PM | #71 |
Drives: Track preped NA FRS
Temp paint measured on mine, visual only for mine to my friends car comparison.
11-19-2021, 01:50 PM | #72 |
Drives: 2022 GR86
The Following User Says Thank You to timurrrr For This Useful Post: | Goingnowherefast (11-19-2021) |
11-19-2021, 03:09 PM | #73 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Example: Me and my buddy both have BRZ's. I go through pads faster then him. Simple conclusion based on anecdotes? Oh well I must be harder on the brakes or be misdriving them. Conclusion after looking at the data? I'm like 5 seconds faster than him everywhere on track including a way higher V max before each braking zone etc. This. Anecdotal claims are pretty meaningless. Especially with so many variables at play.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
The Following User Says Thank You to Goingnowherefast For This Useful Post: | timurrrr (11-19-2021) |
11-19-2021, 07:38 PM | #74 | |
Drives: 18 Brz (Sold) / 22 BRZ
11-19-2021, 08:21 PM | #75 |
What are you talking about? Tokico? The shock company? Lol
11-19-2021, 09:37 PM | #76 | |
It is not well known in the west, but it is a fairly good brake supplier in Japan. Do you have a different information for the BRZ? I thought that the corner was carry over from Wrx (front) and Legacy (rear), and assumed that was Tokico due to that (did not check) But I see that you’re making pretty bold statements from an area that is not your expertise. You are a powertrain engineer, right? How many yrs of experience? PS: doesn’t matter if it was Tokico (yes makes brakes!), Sumitomo, Akebono or Nissin. They would still run JASO, not SAE. And you could ask you friend about the differences on how oems deals with the balance between dyno and vehicle testing. Ask about K2xx vs K2xx PPV, being both from a major manufacturer in Us |
11-19-2021, 09:39 PM | #77 |
Some pics of Tokico Subaru brakes (Legacy)
11-19-2021, 10:27 PM | #78 | |
The theory should dictate that its the same heat, and ABS or not does not matter, why would I observe such a bias towards ABS generating more heat? Im not bashing for the sake of bashing, just curious as to why and is there some extra energy that is introduced in the system that is not accounted for here (aside from vehicle speed and mass). |
11-20-2021, 12:58 AM | #79 | |
Drives: 2022 GR86
Force over displacement is work, and that work can only go into heat. That's where the additional heat might come from? The absolute amounts of displacement should be minimal (how much do the pads compress?), but given the high frequency (modern ABS operate at 10+ Hz, IIRC?) and massive overall force, this can be a non-trivial total amount. |
The Following User Says Thank You to timurrrr For This Useful Post: | Icecreamtruk (11-21-2021) |
11-20-2021, 10:06 AM | #80 |
Drives: 2013 frs base
The op is going through brake pads much quicker that we would expect. Decent track pads (almost any brand) are designed for track related braking forces. Many of us are running stock calipers and abs without excessive pad wear. Another way to look at this problem might be to ask, hypothetically, what would you have to do to intentionally ruin a set of pads? Too much left foot braking?
The Following User Says Thank You to blsfrs For This Useful Post: | RT-BRZ (11-20-2021) |
11-20-2021, 02:38 PM | #81 |
Drives: 2020 86 Hakone
Well this escalated quickly....
11-25-2021, 02:05 PM | #82 |
Drives: Nevermorange FRS
I don't think it's been covered in the 6 pages here but.. Sometimes being slow can be harder on pads.
Before I was "fast", I had braking issues because I braked early and spent too much time on the brake pedal. As I got faster, even though I was converting more speed into the heat, I was spending much less time on the pedal. Less time on the pedal = less heat soak into the system and pad material and more time dissipating heat.
SCCA T4 - FRS
The Following 9 Users Say Thank You to rice_classic For This Useful Post: | blsfrs (11-26-2021), BRZ Hachi (04-14-2022), downshiftxlr8 (11-29-2021), femaledog (11-28-2021), Goingnowherefast (11-25-2021), RToyo86 (11-26-2021), strat61caster (11-26-2021), villainous_frx (11-25-2021), ZDan (11-26-2021) |
11-26-2021, 10:15 AM | #83 | |
Drives: '23 BRZ
The Following 3 Users Say Thank You to ZDan For This Useful Post: |
11-26-2021, 10:49 AM | #84 |
Drives: '13 Whiteout
When my car understeered more I was trail braking more and pads didn't last as long.
The Following 2 Users Say Thank You to TommyW For This Useful Post: | CSG Mike (11-28-2021), Icecreamtruk (11-29-2021) |
Similar Threads | ||||
Original brake pads lasting forever | B-R-Z | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 09-07-2019 09:30 PM |
Interior Red Stitched Knee Pads Door Pads 2016 brz limited Rear View Mirror | sokol | Interior Parts (Incl. Lighting) | 11 | 12-25-2018 09:37 PM |
Oem shock absorber lasting? | Mars2 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 04-11-2017 12:21 PM |
How long is your winter tires lasting | oppiee | CANADA | 12 | 04-30-2016 04:22 PM |
Tail light condensation lasting weeks sometimes months. | jasonojordan | Issues | Warranty | Recalls / TSB | 4 | 05-13-2015 05:45 PM |
