12-20-2020, 09:37 PM | #1 |
Software Hobbiest
Drives: 2015 FRS
high fuel trims
Back 3 months ago I zeroed out all of my fuel trims buy adjusting the MAF sensor and they stayed zero. Now 3 months later I have all positive fuel trims some up to 9%. The only thing that has changed is the air filter and the temperature. Do you think that could be the variable that changed or is it a sign of something else.
Ex. the combined fuel trim at 600rpm 0.15 engine load is at +8.1% |
12-20-2020, 09:46 PM | #2 | |
The Dictater
Drives: '13 Red Scion FRS
12-21-2020, 03:57 AM | #4 |
Drives: FT86
fuel trims at idle can vary quote a bit with large variations in intake air temperature.
Add 4% to maf scale in that low end area then 2% to thexarea jist above to smooth it in |
The Following User Says Thank You to steve99 For This Useful Post: | dholloway543 (12-22-2020) |
Similar Threads | ||||
Possible vacuum leak? (Running lean and high fuel trims) | nickw14 | Engine, Exhaust, Transmission | 6 | 02-10-2023 10:56 AM |
Help needed please, High negative short term fuel trims | Kris86 | Issues | Warranty | Recalls / TSB | 11 | 11-26-2020 05:39 AM |
What would make fuel trims high when engine is cold but OK after warmed up? | kev0 | Issues | Warranty | Recalls / TSB | 11 | 01-06-2020 02:44 PM |
short term fuel trims high at idle and and partial throttle | Minidude147 | Software Tuning | 5 | 03-28-2019 05:53 AM |
Sudden high fuel trims - help please! | cawith | Issues | Warranty | Recalls / TSB | 13 | 10-15-2015 04:30 PM |
