GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
05-17-2023, 01:57 PM | #1 |
Drives:
Running different oil weights for summer season (AutoX/Track)
Looks like it’s pretty well understood 0W-20 (the recommended oil) gets thin at high temps based on its viscosity.
Spoke with a gen 1 owner who mentioned only in the summer when doing track and autocross days he switches to 5w30 in stead of 0w20. Anyone doing the same by chance? His cars at 100k+ of beating the hell out of it. Sent from my iPhone using Tapatalk |
05-17-2023, 08:56 PM | #2 | |
Drives: 2018 Subaru BRZ Limited with PP
My main use has currently been daily driving my BRZ, so I haven't bothered switching to a higher weight oil. I tried it one summer, noticed basically no difference in oil temps, and decided to go back to 0W-20 and have stuck there since. |
05-17-2023, 09:54 PM | #3 |
Drives: 2018 BRZ
Higher viscosity oil won't do anything to the oil temp, but it should keep the oil pressure higher in higher temps. Sadly there is no OEM oil pressure sensor (only a switch) so without adding an external sensor and gauge you can't really verify the benefit of higher viscosity oil.
05-17-2023, 10:45 PM | #4 | |
05-18-2023, 12:53 PM | #5 |
I’ve always ran 0w20 + an oil cooler
05-21-2023, 08:14 AM | #6 |
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
I've owned my GR for a year now. It gets super hot here in the summer plus Autox. I'm thinking of switching out of the OEM weight. The Manual does say 5w-20 can be used.
Also, based on this video. This Engine loves to be hot. I noticed this last summer while driving under heavy loads. I felt the car get quicker. It happened again last weekend. Or I'm going completely insane and my brain thinks it's happening.
05-21-2023, 10:43 AM | #7 |
Drives: '23 BRZ
If you're tracking the car, IMO good high-HTHS (high-temp/high-shear) 5w30 is a must. I ran Redline 5w30 in the '17 and will run that in the new '23 for track season as well. They advertise HTHS of 3.7 mPa-s, where 5w30 is 3.0 minimum, and 0w20 can be as low as 2.6 (I think these #s are correct but going off top of head here...)
You don't have to "verify" anything with oil pressure readings, 0w20 have a known specified viscosity and HTHS range, any 5w30 will definitely have greater viscosity and greater film strength at higher operational temps. |
05-22-2023, 09:42 AM | #8 | |
Drives: '23 BRZ Limited
Don't ever move south of the Mason-Dixon line, you'll melt.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
05-28-2023, 11:14 PM | #9 |
Drives: 2022' GR86 Premium 6MT
5W-20 is the way to go. A few folks on another GR forum I can't write on here otherwise it wont let me post had a thread, and one of the folks who was chiming in is a pretty credible source of information as he works in that industry.
The TLDR is that with 5w-20, engine happy and better protected at full temp and during spirited driving without sacrificing anything but a few MPG's during your first 15 mins or so while it's warming up and that running super thick oils just for the hell of it isn't a great idea.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
The Following User Says Thank You to VoltsFRS2013 For This Useful Post: | autosenses (05-29-2023) |
05-29-2023, 08:09 AM | #10 | |
05-29-2023, 12:00 PM | #11 | |
Drives: 2017 BRZ PP, 2004 WRX
I've run 0w-20 in my 2017 the last 3 seasons. This past Saturday, we did 12 (yes, 12) back to back runs at the Starting Line School on a ~35 second course. My oil temp gauge stayed around 235 and I'm surprised it didn't go much above that considering 12 runs with about ~1 minute in between each is a lot. At normal events, it rarely gets above about 220 by the end of a run and cools down to ~200 before the next. I do recommend a "better" oil if you are autocrossing though. I run Motul, but Redline, etc... IE, an oil you're probably going to pay a bit more for, but might resist wear over the longer term better than OEM. Track days are when you need to start looking at 5w-30's. From what I can tell through my testing, you won't get the oil hot enough during even repeated autocross runs to warrant any pressure benefits from the 5w-30.
05-29-2023, 02:31 PM | #12 |
5W20 isnt that far off your OEM weight, and it's already in the manual in gray area fine print that you can run that weight anyways lol. That being said, I'd be changing your oil after every event if you're doing some hard hard driving.
05-29-2023, 03:10 PM | #13 |
ProCrastinationConsultant
just be warned, 5w-30 is not listed as an allowable engine oil formulation in the owners manual, so if you're concerned about maintaining the factory warranty, don't run anything outside of 0w-20.
06-01-2023, 03:53 PM | #14 |
Drives: '13 FRS - STX
My FA20 spun a bearing on 5w-30 during an autox, 117k miles, the last 40k miles were on 5w-20, first 75k we’re on 0w-20, sticking with 0W-20 for the second build. ymmv
Similar Threads | ||||
All season vs Summer Tires | Mrt1990 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 90 | 11-13-2020 01:50 AM |
AutoX season is upon us! (2018) | SoloIIscoob | NY / NJ / CT / PA | 22 | 04-27-2018 09:47 PM |
Summer or All season? | Flame9020 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 02-04-2017 09:00 PM |
Oil weights for summer | Whats that smell? | Arizona | 24 | 05-06-2016 01:14 PM |
Summer preformance VS All season performance | ScionFamily | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 02-06-2013 08:11 PM |
