Clash0901
Old 08-20-2020, 12:59 PM   #155
solidsnake11
Drives: brz
Originally Posted by Clash0901 View Post
Engine is out... It's no huge feat considering only 2 bolts were holding it in after the trans came out.
I bought those spot weld drill bits on amazon everybody was using and they are total trash. I paid $20 thinking they wouldn't be bad but each one was wobbling and did not cut straight. One of them broke 2 teeth and I only did like 3 spot welds before I realized it was way more work than it was worth. So I just too a bigger "normal" drill bit and started going to town. I've done about half the spot welds this way and it's way easier than the stupid spot weld removal bit. Seems like a gimmick to me, or maybe $20 wasn't enough to justify a quality product. Who knows... I'll try to take more pics today.
You can take a small drill bit and drill the center of the spot weld to make a indent to locate the harbor freight spot weld cutter whick keeps it on target. They also seem to last longer at lower rpms.
solidsnake11 is offline   Reply With Quote
Old 11-02-2020, 09:24 AM   #156
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Seriously, either nobody here makes real power, or my car is broken because I can't put ANY power to the ground. 275/40r17 NT555R and lexus 3.73 i'm ripping apart 5th gear when rolling into boost. I'm on LOW boost, I don't know what else to do... I hate hate hate widebody or flares so i'm kind of annoyed. I can't get any clean hits for my tuner above 20psi. Please give suggestions from real experience only, with THIS chassis only. Much appreciated <3
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
Old 11-02-2020, 09:33 AM   #157
Ashikabi
Ashikabi's Avatar
I mentioned traction on a Facebook group and someone commented that the NT555s were garbage. They had them on a mustang and had no grip. I have them on my rear right now in a 255 and yeah, no traction. I thought I was upgrading from my 225 Sport Comp 2s but I honestly didn't notice a difference. Still no traction. And I'm not boosted. I do have sick stock diff though. So I guess the take away is to try different tires. Lemme know what you come up with cuz I want a turbo too
Old 11-02-2020, 11:43 AM   #158
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
My buddy is running a 255 R888r on his is300 making more power than me. Granted he's heavier, but same rear end and he hooks up great. All the reviews I read or saw (youtube) online rate the NT555R and R888r pretty close. Which is why I purchased them, and they feel super soft when i dig my nail into them, but they seem to be hot garbage. I would buy the R888r this instant if I knew they would be drastically better. Spinning in 5th on low boost is just fucking frustrating ya know. I wanna run 30+ psi but at this rate it seems impossible.
Old 11-02-2020, 11:50 AM   #159
Ashikabi
Ashikabi's Avatar
I would expect the r888r to be a lot stickier just cuz it's an R compound. All I know is my experience with the nt555 hasn't been great. And apparently some others have had issues too. Definitely sounds like a gamble to try to fix it but I don't see much choice unless you know someone you can swap wheels with for testing
Old 11-02-2020, 11:54 AM   #160
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
The NT555R is actually an R compound tire though. It's a street drag radial according to their website.
Old 11-02-2020, 11:56 AM   #161
Ashikabi
Ashikabi's Avatar
Well that sucks. I don't have a way to keep them from freezing this year...
Old 11-02-2020, 12:00 PM   #162
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
It's like $200-250 locally for oem GT86 wheels and decent tires. Maybe the same for you... just to keep on the car during cold weather. Thats what I do, I throw on some stockies until its warmer out
Old 11-02-2020, 12:03 PM   #163
Ashikabi
Ashikabi's Avatar
I just sold my stock wheels. I wasn't planning on the cold itself being an issue. Well, they didn't grip worth a shit anyways... I suppose freezing can't make them any worse
Old 11-02-2020, 12:11 PM   #164
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Fair enough haha
Old 11-02-2020, 12:18 PM   #165
Ashikabi
Ashikabi's Avatar
Fair enough haha
Ultimately I want a new set of wheels with really nice rubber and I'll put straight up winter tires on these wheels so I can drive when it's cold, but not snowy. I don't want that road salt bullshit all over my car
Old 11-06-2020, 12:27 PM   #166
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Obviously weight is a big factor for traction. I saw a video on The Racing Channel where a guy in a 2JZ S10 pickup, or something small, with like 800-1000hp has three 100lb sand bags in his bed for added traction. Obviously this isn't ideal or something I am suggesting.
People always act like driving a fast car fast is easier than driving a slow car fast, but when traction is limited at even partial throttle, it means it takes a lot more skill to transition on power instead of just going flat footed all the time.
Things you can do to gain traction besides controlling your right foot better, and things you can do to gain grip, so you can put down more power are the following:
--Suspension...any wheel hop, alignment issue or anything like that should be sorted. I don't know what your suspension setup is like or what you have done.
--Weight distribution...move some weight to the rear like a remote battery or get the car corner balanced or reduce weight up front or whatever.
--Remove slop...I don't know if bushings will make it worse or better, but I have placed bushings on the rear, and it helped.
--Remove air from the tires...What psi are you running?
--Downforce...Maybe consider a wing and diffuser for traction at speed.
--Move somewhere warmer with nicer roads...Just kidding.
Old 11-07-2020, 06:49 PM   #167
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
All my bushings and suspension is tight. Rear diff has harder bushings, I don't wheel hop at all when it spins its pretty controlled and smooth. Tire pressure is around 26 in the rear 30 in the front. Might drop fronts to 28 and try to soften up the front rebound. I think in general I may need better coilovers, i'm running some cheap tein coils right now.
Might get a 15" wheel for the rear so I can run more sidewall. 40 on the nt555r is pretty stiff.
The Following User Says Thank You to Clash0901 For This Useful Post:
Irace86.2.0 (11-08-2020)
Old 12-03-2020, 09:57 AM   #168
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I got the car ceramic coated last month and now it's in storage. It's a 5 year coating, i'm not too familiar with how that works but I was told by some friends that it's a good idea to preserve the paint.
Here is a walk around video of the day I picked it up, after ceramic coat was complete which was less than 2 weeks ago.
beltax90 (03-03-2021)
Built Turbo K24 Swap? Calmwhiteguy Engine Swaps 31 02-13-2018 05:07 PM
Custom Grill Duct Backyard Build, Opinions? Doobster Cosmetic Modification (Interior/Exterior/Lighting) 22 08-04-2017 04:20 AM
Giving flat black wheels a dash of bronze? Expert backyard painters want to weigh in? Keenercarguy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 06-02-2017 09:15 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
Rwd-boxer's backyard exhaust fix RWD-boxer Engine, Exhaust, Transmission 9 06-11-2012 06:15 PM
