11-03-2022, 09:01 AM | #1023 |
Drives: 2022 BRZ sport-tech
Have you tested this in conjunction with any baffle? Can they coexist? One of the concerns i have is if the material with break down with time/heat cycles.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
11-03-2022, 02:37 PM | #1024 | |
Will this material break down? No. It's the same family of plastic as what the OEM oil pickup is made from |
The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post: |
11-03-2022, 08:54 PM | #1025 |
Drives: Crapcan
Assuming it is nylon, no worries there. You would basically have to burn it with a torch or hit it with something to get it to fail. Just don't do those two things and you will be fine.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | KillerBMotorsport (11-04-2022), Petah78 (11-03-2022), soundman98 (11-03-2022), Tcoat (11-04-2022), Ultramaroon (11-06-2022) |
11-06-2022, 11:30 AM | #1026 | |
Drives: Toyota 86 GT
11-09-2022, 03:54 PM | #1027 |
FT86Club Official Vendor
Drives: 2023 BRZ
Here's a little preview of what we're working on. We'll have some pans ready in a couple weeks. We've modified stock pans with a low profile bung to allow for cleaning of the pickup during oil changes. As you can see, it's accessible just by dropping the oil change cover. The pan is gold because it's coated in Cerakote Glacier, a ceramic coating that provides a thermal barrier. Included in the package is the baffle and a tool which will make clearing out the pickup a 1 minute job. More details to come soon.
11-09-2022, 04:01 PM | #1028 |
Drives: 2023 BRZ
Well that's interesting. Looking forward to hearing users' experience with it.
What is the benefit of the oil pan having a thermal barrier?
Director of Rocky Mountain 86CUP
11-09-2022, 04:31 PM | #1029 |
Drives: '22 BRZ
Not a huge fan of that baffle, but otherwise cool
The Following User Says Thank You to DocWalt For This Useful Post: | KillerBMotorsport (11-16-2022) |
11-09-2022, 04:53 PM | #1030 |
Drives: 2023 BRZ
@Pat The idea behind the having the thermal barrier is to limit the heat transfer from the header to the oil pan to the oil via convection and radiation.
11-14-2022, 08:44 PM | #1031 |
btr.life
Drives: 2022 GR86
Second inspection of my oil pickup is done. 3400 miles on the oil (7200 on the engine), including 3 time trial track days, 3 autocross events, and a couple canyon runs. Only found a handful of tiny bits of RTV. I really had to look hard and poke around with the tool to find them (you can see one bit in the upper right, other bits were in upper left corner).
Last photo was my first inspection where I pulled out a lot more RTV chunks (at 3800 miles).
11-17-2022, 02:55 PM | #1032 |
Drives: 2023 BRZ
Our kit is now available in limited quantities at first. Please have a look at our classified thread.
https://www.ft86club.com/forums/show...55#post3556955 |
11-30-2022, 04:35 PM | #1033 |
Drives: 2022 GR86
anyone have an up to date count on how many engine failures?
The Following User Says Thank You to Rustyoid For This Useful Post: | gcmak (12-01-2022) |
12-14-2022, 06:06 PM | #1034 |
Toyota/Lexus master.
Drives: fr-s in pieces
This is what happens when toyota dealerships use the wrong guy.
Sure, he turns big hours and then someone else has to fix his come-backs. |
12-14-2022, 10:56 PM | #1035 |
Drives: Crapcan
This thread is pretty much all new factory assembled engines. Not dealer fixes.
12-14-2022, 11:33 PM | #1036 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
While there may well be some relevance to the track driving the would stand up in court (though its debatable even then IMO and worth a challenge), for just driving it hard I do wonder if they have a leg to stand on when they are the ones that set the rev limit and control the load via the ECU. So long as you don't do a money shift (and have OEM spec parts and fluids) I cannot see how driving the car hard every day of the year (and sticking to a increased service schedule as per the manual) would be grounds for dismissing a warranty. |
The Following User Says Thank You to Blighty For This Useful Post: | VoltsFRS2013 (12-18-2022) |
Tags |
oh no not again |
Similar Threads | ||||
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 01:15 AM |
Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 04:18 PM |
Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 02:33 AM |
Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 11:11 AM |
