Old 01-29-2018, 03:57 PM   #183
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Originally Posted by coomojar View Post
Description: TDB is a Tk debugger GUI for the GNU debugger GDB. Network Lookout Net Monitor For Employees Professional V4 9 12 Key. 4 cd no patch quake crackdownload
Lol spam.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-08-2020, 07:44 AM   #184
Zestyfesty
Drives: 2017 BRZ PP
Well I 'performed' the spring removal today; very straightforward. A brief drive was all I needed to know this was the right move for me, although perhaps not for everyone. The most noticeable change for me is the clutch pedal pressure is now linear, not weirdly sprung with different loads at different pedal position, which I found disconcerting, and made it tricky to feel the bite point. Combined with drive-by-wire throttle and I was often fluffing my clutch/throttle calibration. Now I can clearly sense through my foot the friction of the discs biting into the flywheel. The bite point has clarity. It's just another layer of tactility and precision that the spring setup couldn't offer.
Zestyfesty is offline   Reply With Quote
The Following User Says Thank You to Zestyfesty For This Useful Post:
jcw99 (09-12-2020)
Old 09-09-2020, 01:15 AM   #185
Welp, there goes your warranty and resale value - too bad -
jcw99 (09-12-2020)
Old 09-12-2020, 08:34 PM   #186
Plumbus
Seņor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Have you tried the smaller Forester clutch slave cylinder? It makes the pedal feel heavier due to less leverage but also gives better clutch feel.
Plumbus is offline   Reply With Quote
Old 09-16-2020, 12:40 PM   #187
dasting
Drives: 2013 BRZ Limited
Also did this two weeks ago after having my car for a couple months. It took 5 minutes to get the spring out and damn, I was skeptical for the different this would actually make, but it is so much better. Linear and easy to modulate clutch. Yes, slightly heavier when pedal is all the way down, but still lighter than many cars I have owned. I know others have mentioned pedal hang at the top of the throw after doing the mod, but I have no hang, works great. Do recommend.
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
dasting is offline   Reply With Quote
clutch helper spring, helper spring removal
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
