Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Old 09-15-2020, 08:23 PM   #15
Racecomp Engineering
Originally Posted by gtpvette View Post
Andrew,,, any chance you post the correct numbers?? These are the numbers (42.8 and 38.1) I see in most post. I recall seeing a post where a guy had a picture of the pistons with the digital caliper on it,, dam if I can find it today.
In post #10:
Front:
Hitachi CL25VD Caliper with Dual 40.4mm Pistons (1.591 in.) x 2
FA300 Pad Material with 48.3 cm^2 pad area (7.487 in.^2)
294.0 mm x 24.0 mm Ventilated Rotors (11.575 in. x 0.945 in.)
Rear:
Hitachi CLA12V Caliper with Single 40.46mm Piston (1.593 in.)
FN360 Pad Material with 23.0 cm^2 pad area (3.565 in.^2)
290.0 mm x 18.0 mm Ventilated Rotors (11.417 in. x 0.709 in.)
- Andrew
buy RCE direct at: www.racecompengineering.com
RCE IG: @racecompengineering
Tech articles IG: @theapexfiles
Old 09-16-2020, 08:36 AM   #16
gtpvette
Drives: 2015 FRS - FFR GTM
Originally Posted by 86league View Post
I measured a stock 2016 piston as 40.4mm (granted with a cheap HF caliper, but it's been pretty accurate). Didn't measure the rear (only rebuilt the fronts), but the subaru parts catalog shows the rear caliper using the same part # for the piston as the front -- just 1 rear vs 2 front...
https://www.ft86club.com/forums/show...1&postcount=16
That was the picture I was looking for,, thanks!!!
In post #10:
Front:
Rear:
- Andrew
Thanks you sir!
GTM - Still under construction - 2015 FR-S - 2016 Vette Z51
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
Racecomp Engineering (09-16-2020)
Brembo BM-4 caliper Randoman5 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 Yesterday 05:23 PM
GRB Brembo caliper on BRZ RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 11-15-2016 02:50 PM
WTB OEM caliper brackets troek Brakes, Suspension, Chassis 0 01-27-2014 10:32 PM
MGP caliper Covers USMC -FRS Cosmetic Modification (Interior/Exterior/Lighting) 9 02-06-2013 10:15 PM
Would you get these?...Caliper covers mckobus Cosmetic Modification (Interior/Exterior/Lighting) 35 01-28-2013 09:27 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
