Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
06-24-2017, 10:28 AM | #1 |
Drives: DGM 15' BRZ Limited
Which interior fuse slot to install led interior lighting in?
I got the Opt7 Aura led strips. Which of the fuse numbers in the interior fuse box can I use to have it have power only when the car is on? Also, would it be better if I install it in the hood fuse box instead or does it not matter.
Thanks |
06-27-2017, 01:28 PM | #2 |
kind of weird no one responded to this... o well i think i found a video tutorial showing how to install interior lighting. and yes i was aware theres an interior lighting thread but theres a lot of pages in it and i didn't see an actual post about how to actually install it
06-27-2017, 01:43 PM | #3 |
Drives: 2014 BRZ Limited
Poke the blank slots (if there are any, I haven't looked at my fuse box yet) with a test light and see if there are any that come on when the car turns on and use it. If you have issues I can go check mine and see what I come up with, but it should be super easy.
06-27-2017, 02:09 PM | #4 |
Drives: FRS
I used the heated seats circuit(s)
The Following User Says Thank You to Chimera For This Useful Post: | btan219 (06-27-2017) |
06-27-2017, 08:14 PM | #5 |
What are the chances a bunch of fuse slots don't work? I plugged it into all the empty slots in the red column but none lit up. When I plugged them into the empty green slots they worked. The green column seems to be the ones on even without the ignition.
So at least I know it's not the product since they work on the slots for always on power. Also one of the FT86SpeedFactory tutorials used one of the slots in the red column. Any ideas for a fix? |
06-27-2017, 08:17 PM | #6 |
Drives: Grrrr
Pick up and splice into a switched live wire?
From the radio? |
06-27-2017, 08:19 PM | #7 |
hm I want to leave having to splice as a later resort. Are all those fuse slots that didn't work really busted?
06-27-2017, 08:24 PM | #8 |
Drives: Grrrr
Just not wired I'd suspect. If there not working, there not working.
Two second job to splice using a scotchlok. Temporary too so you can remove it when you want to. |
The Following User Says Thank You to Scrappydoo For This Useful Post: | btan219 (06-27-2017) |
06-27-2017, 08:49 PM | #9 |
It all depends, some things will only come on with headlights and the like. Other blank slots may be just that.
The Following User Says Thank You to shadow_772 For This Useful Post: | btan219 (06-27-2017) |
06-27-2017, 08:54 PM | #10 |
Is it normal though for all those blank fuses to not work? It is what it is I suppose
06-27-2017, 10:39 PM | #11 |
Drives: FRS
Yes it is normal
06-27-2017, 10:43 PM | #12 |
Similar Threads | ||||
GCS interior lighting | FR-Sky | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 10-10-2019 05:55 PM |
brz interior fuse cover | shaynek | Want-To-Buy Requests | 3 | 03-01-2016 05:03 PM |
Interior Lighting ... | REAV3R | Hawaii | 0 | 02-16-2015 03:33 AM |
LED interior lighting for BRZ | cslntuee | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-06-2013 02:43 PM |
interior lighting? | fistpoint | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 05-09-2012 01:52 AM |
