ACE Headers
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission
Old 12-08-2018, 04:28 PM   #1
86league
Drives: '13 BRZ Limited
Transmission removal
Preparing for a TOB/clutch job.
Have read how to remove the trans - searching and reading threads here, etc. To save time vs. the book method of removing trim and going in from the top of the shifter to detach the shift linkage, I've seen some recommend just detaching the shifter from below, but that sounds like it involves cutting the rubber dust boot over this connection.
Looking at images online before I start removing stuff... Any reason you couldn't remove the linkage from the forward point on the linkage vs. the aft one? Talking about the one just under the blue "miles" in this picture :
Looks like the same sort of connection, but wouldn't involve cutting the boot or going in from the top (trim removal/etc). Enough room to disconnect then re-connect? I'll probably give it a try once I have the exhaust/driveshaft off -- just wondered if anyone had done this.
Thanks.
86league is offline   Reply With Quote
Old 12-08-2018, 05:34 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
I think getting your hands in there is going to be harder... and am not sure there's room to clear the pin even if you manage.
You don't need to cut the boot, and don't need to work from the top. I did it all in freezing temps from under the car when I installed my Kartboy. I did end up heating up the boot with a heat gun just in case...
Old 12-08-2018, 06:16 PM   #3
n0thing
Drives: Subaru BRZ
you can rotate and slide out the two pins that connect the shifter carrier to transmission, lower the transmission, and remove the cotter pin (below "blue miles") at the shifter rod.
https://www.ft86club.com/forums/showthread.php?t=117270
n0thing is offline   Reply With Quote
Old 12-08-2018, 08:20 PM   #4
86league
Good info - Thanks to you both.
DIY ECU removal Hawaiian DIY (Do-It-Yourself) Guides 14 11-04-2017 12:54 PM
Bug removal Jarrid'sBRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 06-23-2017 04:12 PM
ABS removal Zer0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-11-2016 05:39 PM
Transmission selector shaft removal Nigelr32 DIY (Do-It-Yourself) Guides 0 12-29-2014 05:34 AM
topspeed difference between manual transmission and automatic transmission torquemada Subaru BRZ General Forum 51 05-04-2012 07:54 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
