Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-28-2020, 02:12 PM | #1 |
Brake pad goop
Hi all,
Did a track day with my new DTC-30 brake pads yesterday. After my first session I noticed a liquid goop on the pad backing plate. I don’t use any grease since these are race pads, but I’m wondering if this goop is residual from my oem pads which I took out this past Saturday. I know I should’ve gone with the DTC-60s, but I’m wondering what this is and if it’s safe to run these still. This picture was taken today so the goop has solidified. TIA Passenger side: Last edited by norcalpb; 07-28-2020 at 02:36 PM. |
07-28-2020, 02:39 PM | #2 |
Wheels for Brains
Might have been the protective coat/original cosmetic finish on the pads themselves?
07-28-2020, 02:43 PM | #3 | |
I used to track with Yellowstuffs and Carbotech AX6 which absolutely sucked on the track, but they never fell apart on me. |
07-28-2020, 03:32 PM | #4 |
Looks like the paint bubbling off. I would not worry about it.
The Following 5 Users Say Thank You to Grady For This Useful Post: | new2subaru (07-28-2020), norcalpb (07-28-2020), RToyo86 (07-29-2020), spike021 (07-29-2020), strat61caster (07-29-2020) |
07-28-2020, 09:05 PM | #6 |
Weight Weenie
Drives: 15 FR-S
Just to give you an idea they will look like this after it's all burned off. These are DTC 30
The Following User Says Thank You to new2subaru For This Useful Post: | norcalpb (07-28-2020) |
07-28-2020, 11:37 PM | #7 | |
Proud of BOXER
Drives: Subaru Boxer
Maybe this is what @HueyLooie actually meant when he said "your dadda's hot goopey goop"?
07-29-2020, 01:42 AM | #8 | |
I'm guessing you just got enough heat in them for that. You could always double-check the spec for the acceptable temperature range, but I dunno how you'd test how hot they got after the fact.
Instagram: @spike.brz
The Following User Says Thank You to spike021 For This Useful Post: | norcalpb (07-29-2020) |
07-29-2020, 12:19 PM | #9 |
Drives: 2005 Toyota Camry
that's entirely paint.
my E39 540i valve cover looks like that, but it's taken years for the paint to bubble. |
The Following User Says Thank You to mav1178 For This Useful Post: | norcalpb (07-29-2020) |
Similar Threads | ||||
FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings | fc3s_johnny | Brakes, Suspension, Chassis | 11 | 10-05-2020 10:26 AM |
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
