BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
11-20-2019, 03:57 PM | #1 |
brz no crank and no power to starter
my 2013 brz push button wont crank everything in and out of the car works (gauges,lights etc) also the starter,battery key fob,ecu,fuel pump and clutch switch are all working or have been replaced.
ive visually checked all the fuses and relays and switched some around with ones that i know worked but still have no power to my starter any ideas what is could be? mods: header back exhaust tail lights led fog lights sub woofer oft tuner rocket bunny rear diffuser |
11-20-2019, 04:18 PM | #2 |
Site Moderator
Drives: Stuff
Did you check for codes? Direct wire the starter with the ign on to test the starter?
Check live data in obd2 if it shows clutch switch, etc. I never checked on these cars for that..
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
11-20-2019, 04:34 PM | #3 |
Senior gif poster
Drives: 2013 Asphalt FRS
could it be the security immobilizer, check the info in this thread to rule that out:
http://www.ft86club.com/forums/showthread.php?t=120838 |
11-21-2019, 01:19 AM | #4 |
No codes like engine lights or anything but the dealer said I had fault codes in my ecu (probably from the starter circuit) but I got a used ecu for 100$ and got it flashed into the car and still the same thing is happening.
And where is the immobilizer located and how would I trouble shoot it? |
11-21-2019, 04:58 PM | #5 | |
Senior gif poster
I gave you a super handy link to the forum thread that should be able to answer most of your questions regarding the immobilizer, the member who posted had a very similar issue that you describe, check out the link below: http://www.ft86club.com/forums/showthread.php?t=120838 |
11-23-2019, 08:08 PM | #6 |
update
i just want to point out i had the exact same issue 4/5 months ago the only difference was if i kept pushing the push button the car would eventually start and when it did i got a engine light with a P0512 code (i dont think its my push butto cause it cycles on accessory and off no problem) i didn't mention this before cause i couldn't remember what code came up cause i cleared it and never had the issue again. but it was for sure P0512 i dont have an engine light this time around but i think thats cause i haven't got it to start yet.
Tags |
brz, no crank, no start, push button start |
Similar Threads | ||||
Car clicks but won't crank. Battery or Starter? | JERM^ | Issues | Warranty | Recalls / TSB | 93 | 09-14-2019 10:11 AM |
Agency Power Crank Pulley | Chillz | Engine, Exhaust, Bolt-Ons | 6 | 05-23-2013 08:25 PM |
PURE POWER PACK- The Perfect Starter Kit For Your 86!! | Pure Automotive | Engine, Exhaust, Bolt-Ons | 22 | 03-19-2013 06:58 PM |
Agency Power Crank Pulley | JDMrolla | Engine, Exhaust, Bolt-Ons | 6 | 02-23-2013 07:23 AM |
Agency Power Crank Pulley | Chillz | Engine, Exhaust, Bolt-Ons | 2 | 11-30-2012 03:45 AM |
