Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
02-16-2013, 09:17 PM | #1 |
Drives: Scion Fr-s Argento
How do I use my paddle shifters?
I'm scared to use my paddle shifters because I have little knowledge of manual shifting of any sort... Please explain!
02-16-2013, 11:02 PM | #2 |
I have to ask. Are you seriously asking how to use your paddle shifters? How about this. What do you not understand?
02-16-2013, 11:08 PM | #3 |
Drives: MY00 Impreza 2.5RS
Right paddle goes up a gear, left paddle goes down a gear.
Here's the really important part. There is a big white gauge in front of you in the middle. It has a little stick that moves around in a sweeping left to right motion. Don't let the stick sweep into the red zone or bad things can happen. |
The Following User Says Thank You to TOMIMOTO For This Useful Post: | whataboutbob (02-16-2013) |
02-16-2013, 11:31 PM | #4 |
AutoX-10/10ths every run
Be nice, this could be a genuine question. Everyone had to learn once.
To the OP, do a bit of Googling and read up. Then try and find a forum local with an AT and have them take you for a ride.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
02-16-2013, 11:36 PM | #5 |
Drives: Subaru BRZ Limited
You know there is an owners manual that explains it quite well.
The Following User Says Thank You to Burrcold For This Useful Post: | bestwheelbase (02-17-2013) |
02-16-2013, 11:40 PM | #6 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Most importantly spend some time with your owners manual. For relaxed, around town driving keep your rpm's between 2000 and 3000. When you get above 3000 shift up a gear and when you get below 2000 shift down a gear. The more you drive and gain experience the more it will all start to come together for you.
02-16-2013, 11:45 PM | #7 |
ZC6A2B82KC7J
Drives: 2002 WRX
If you want to go faster, pull the left paddle once. If you want to really go faster, pull the left paddle twice. When you get to the redline on the tach (the big round gauge in the middle), pull the right paddle. Enjoy!
The Following User Says Thank You to Spaceywilly For This Useful Post: | davesrave (02-17-2013) |
02-16-2013, 11:57 PM | #8 |
Drives: Whiteout FR-S
There are up and down arrows in the cluster when you are in manual mode.
02-17-2013, 12:12 AM | #9 |
X Rated
Drives: 2017 BRZ Series.Yellow
Just to specify, if the original poster is talking about an FR-S/BRZ, then the right paddle, pulled toward you, goes up one gear. The left paddle, puddled toward you, goes down one gear.
If you don't know what gear to be in, don't worry, the system is pretty smart and wont let you do anything that will damage your car. Just play around with it and see how it all works. Just had to specify because some automatics with paddles do not do the "up on the right, down on the left" setup. My parents Malibu is pull toward you on either paddle to go up, push forward to go down.
02-17-2013, 12:14 AM | #10 |
02-17-2013, 01:18 AM | #11 | |
02-17-2013, 01:21 AM | #12 |
02-17-2013, 07:03 PM | #13 |
Drives: FRS
[QUOTE=nerb;739770]Sorry I didn't specify, I was mainly asking for when I should shift up or down based on rpm levels not just based on sound.[/QUOT
you should take some more drivers ed
02-17-2013, 07:10 PM | #14 |
Tags |
automatic, paddle-shifters |
Similar Threads | ||||
Paddle Shifters | Atticus808 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 10-01-2012 08:34 PM |
paddle shifters | Sasquachulator | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 08-28-2012 10:15 PM |
Paddle Shifting | switchkick | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 08-14-2012 03:29 PM |
Can you manually shift automatic version w/out the paddle shifters? | maxeveland | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 02-01-2012 11:51 AM |
Paddle-Shifters | Buggy51 | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 09-14-2011 12:20 AM |
