09-24-2014, 06:43 PM | #5363 |
Drives: '13 Raven FR-S
09-24-2014, 07:00 PM | #5364 |
That Guy
Drives: 2013 asphalt FRS MT
The Following 3 Users Say Thank You to Calum For This Useful Post: |
09-25-2014, 12:08 AM | #5365 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
FYI--Here's a brief synopsis of what is the current state of things as we're still getting several inquires a day. We have recently become a dealer for Sprintex USA so we can continue to support the kit as Innovate is no longer the sole distributor in the US.
Sprintex USA is now distributing the kits. The pricing has been adjusted (up) a bit for IC systems. Current SC kits are 3195 non intercooled, 4695 with the laminova IC. IC upgrade kits are 1700 MSRP. This is much more realistic given the cost of the laminova core and heat exchanger. Old IC upgrade kits could never keep in stock and this I think reflects the true cost of things compared to before. 335 kits: SOON! Don't say we didn't warn you, it makes tons of power and 14 psi is about the minimum you will see. That 14 psi will be at the low end of the blower's output, so it will be a cool, dense charge. Sprintex recommends built motors only, but we will test out one of these kits on our car until she pops. I think with e85 we can probably still use the big pulley on this blower and limit power via tune until we're ready for the forged stuff. 210+...don't hold your breath. Official word will come from Sprintex when it is released, but if you're holding off purchase for one, you're going to be disappointed. When it is ready it will offer a measurable gain over the standard 210, but it won't be ground breaking. Otherwise it will actually be quite nice to have Sprintex keep an office here in the US. This means that spare parts, replacement blowers, and whatever else might be needed will be a much quicker repair if needed. |
09-25-2014, 12:33 AM | #5366 |
Drives: ft86
pulled the blower off. aside from the huge amounts of oil, I didn't find anything unusual.
The Following User Says Thank You to blown For This Useful Post: | Calum (09-25-2014) |
09-25-2014, 09:27 AM | #5367 | |
Drives: 2013 FR-S Argento
Aren't there turbo kits out there making 350-400 rwhp on stock internals? How is this different? I realize it's pushing things but people are doing it with success I think- not sure how this is different (maybe torque output)? Sent from my iPhone using Tapatalk |
09-25-2014, 09:46 AM | #5368 | |
That Guy
The power used to turn a super charger comes from the crank shaft, that power could otherwise be used for accelerating the car. The power to turn a turbo comes from the exhaust which would mostly be wasted out of the tail pipe anyway, so that doesn't decrease the engines power output. Of course the net gain from a superchager is still positive. But when comparing two indentical engines being fed the same volume of air one from a SC the other from a TC, the TCed car will have more power going to the drivetrain. |
09-25-2014, 10:56 AM | #5369 | |
Any early predictions on numbers we'll see from the 335? |
09-25-2014, 11:40 AM | #5370 | |
So elite I'm 1338
Drives: WRB Subaru BRZ
This is misleading. The way @Calum words this makes it sound like Turbos do not have parasitic loss. Which is incorrect. Turbos restrict exhaust flow, which is a parastic loss. The parastic loss is just generated differently.
-Jack Burton |
09-25-2014, 12:55 PM | #5371 | |
09-25-2014, 03:54 PM | #5372 |
Drives: t
anyone consider rerouting the throttle body coolant lines?
09-25-2014, 08:00 PM | #5373 |
Drives: 2017 Camaro 1SS
09-26-2014, 12:20 AM | #5374 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
About 100km cruising engine blew. 2 Pistons where finished hole and melted. Don't mess around pull the motor and replace parts before you do more damage, could save yourself good couple of $$ if you have not damage the bore. |
09-26-2014, 12:35 AM | #5375 | |
Drives: Raven FR-S
What do you think caused this failure?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
09-26-2014, 09:46 AM | #5376 | |
Drives: ft86
first failure? there was another failure? |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
