03-11-2020, 12:59 PM | #21617 | |
The Following User Says Thank You to Tcoat For This Useful Post: | wolffbite (03-11-2020) |
03-11-2020, 05:23 PM | #21619 |
Drives: 2016 Steel AT FRS
Switched over to E85... Hope it starts today! 43F out right now. I looked at the tune in RR and there are 4 more tables than all the tutorials show, plus it's in C not F, so I was hesitant to change anything yet.
The Following User Says Thank You to Weigaldo For This Useful Post: | SuperTom (03-11-2020) |
03-11-2020, 09:08 PM | #21620 |
Weight Weenie
Drives: 15 FR-S
Cleaning the engine bay. I have a bunch of parts removed and cleaned and did the timing cover so far.
Somoniz aluminum wheel cleaner works great but smells like horrible!! I'll mask up next time. |
03-12-2020, 01:10 PM | #21621 |
Drives: Scion FR-S Series 10 #2462
The Following User Says Thank You to MJones_RB For This Useful Post: | new2subaru (03-12-2020) |
03-12-2020, 09:13 PM | #21622 |
Weight Weenie
Drives: 15 FR-S
It doesn't really take much to clean it. I like taking things apart to see what's what.
I'm also doing so polishing while I'm in there and may do some wiring tucking. It'll give me an idea on what I want to do next winter. The combined engine/body harness drives me crazy... |
The Following User Says Thank You to new2subaru For This Useful Post: | MJones_RB (03-13-2020) |
03-14-2020, 01:06 PM | #21623 |
Meow
Drives: GT86, Volvo 996
Put some sound deadening in the trunk - I was chasing a rattle coming from the rear and started removing elements to eliminate them as potential sources. Didn't find the rattle (think it's coming from the outside ), but thought I might as well put some insulation before putting everything back together.
03-14-2020, 01:09 PM | #21624 | |
2013 Series 10 FRS #553
03-14-2020, 08:44 PM | #21625 |
Drives: 2017 BRZ w/PP
Installed a perrin 22mm front sway bar, racerx endlinks, and spc camber bolts
[ame]https://www.youtube.com/watch?v=VoF0-OTiojw[/ame] |
The Following User Says Thank You to Breadman For This Useful Post: | MJones_RB (03-16-2020) |
03-15-2020, 09:55 PM | #21626 |
Drives: FR-S 10 Series
Drove from Long Island NY to Delaware and back yesterday (nothing more fun than a long road trip in the FR-S). Take a quick trip today then on the way back upon turning on the ignition I get CEL and Slip lights (never had that before). After inconclusive OBD scanning (P0018 & C1201) and research I dis/reconnected the battery to see if it comes back.
Car is completely stock and 44k mi. Fingers crossed. Inconclusive because the P0018 is indicative of a crankshaft problem and C1201 ECS malfunction. On this site I've read threads about this and changing out the ECS (which didn't work), engine work, slip sensor replacement, and etc. I don't want to spend $150 for a Toyota tech's best guess. |
The Following User Says Thank You to dnieves For This Useful Post: | humfrz (03-16-2020) |
03-16-2020, 07:12 PM | #21627 |
Blacked out all of the silver painted trim.
The Following 4 Users Say Thank You to MJones_RB For This Useful Post: | beltax90 (03-16-2020), humfrz (03-16-2020), RToyo86 (03-19-2020), StraightOuttaCanadaEh (03-16-2020) |
03-16-2020, 09:30 PM | #21628 | |
humfrz |
03-16-2020, 09:33 PM | #21629 |
The Following User Says Thank You to humfrz For This Useful Post: | MJones_RB (03-17-2020) |
03-16-2020, 10:44 PM | #21630 | |
From what I read here that's what the Toyota techs do: change the crankshaft position sensor then the error may/may not go away. Then when it returns they change the ECU. Then after that they take your camshaft apart charging you $$ every step along the way until you get a $6k bill at the end. What a pain, this car has been trouble free (minus crickets/condensation in the tail lights/leaky cam plate) but being babied and with so few miles I didn't expect a CEL that keeps coming back. With zero warranty left would I have better luck at a Subaru dealership? These engines aren't the servicing nightmare of a rotary but I don't want to finance guesses. |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
