Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 01-29-2017, 03:14 PM   #1
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
First accident with the BRZ :(
Hey Guys - Just wanted to get some input of that could have been wrong with my BRZ.
Last Thursday i was driving and hit a big pothole, it was dark so i did not see it on the road. I heard a big boom from the front driver side wheel area (which is the area where it took the hit) and i thought i broke something. I step out of the car and it seemed fine at that time. I check the tire pressure and it was good, not TPMS light came on or any other warning light on the dash.
I kept driving the car as normal but i felt like the steering wheel was pulling to the left so i had to firm grip the steering to keep driving. At that time, i thought it was because of the road surface so did not pay much attention.
The next day (which was yesterday) i was driving and while entering a tight shoulder to merge into the highway i lost control of the car and hit the curve hard. It was a hard hit but my girl and i were ok and no person or other car was hurt.
From what i can tell the rear and front driving wheels are damage, the sti side skirt is damage and sti lip is damage and the lower part of the bumper will likely need to be re-painted.
Also, after the accident, i was not able to turn my wheels. I turn the steering wheel in any direction but the front wheels do not move or turn anymore. I believe that likely the front axles/shaft are broken.
The car had to be towed to a impound until monday were my insurance Geico will take the car to the auto body shop that i requested. The car insurance is full cover so i just need to pay my deductive.
Good thing that no one was hurt, only the car is damage
Now im wondering..
Could that hit with the pothole weak some suspension part that cause the part to give up/break while i was entering the corner?
I was running Blizzak WS80 tires so those tires do not have the best grip in the dry road. These are not performance tires to my knowledge.
Geico will inspect the car tomorrow with the body shop and will give me a list of all the parts that needs to be repair and fixed.
Not sure how long they will take
Jfheisenberg is offline   Reply With Quote
Old 01-29-2017, 03:26 PM   #2
gtengr
Drives: 2017 BRZ
Yes, sounds like that initial hit may have damaged a tie rod and threw the alignment off. Then the tie rod eventually broke.
gtengr is offline   Reply With Quote
Old 01-29-2017, 08:04 PM   #3
~el~jefe~
Drives: 2019 MX-5 RF
sucks
~el~jefe~ is offline   Reply With Quote
Old 01-29-2017, 08:57 PM   #4
softgrip
Drives: 2017 BRZ - Dark Grey Metallic
There is no mechanical steering - so it could be something else like the steering electrics coming loose.
softgrip is offline   Reply With Quote
Old 01-29-2017, 11:37 PM   #5
nico_rsx
Drives: BRZ 2017 Pure Red, MT
There is a mechanical steering. The electric power steering is just there for assist.
Maybe a broken tie-rod like someone said. But I broke a tie-rod once, and was still able to turn the other wheel. The car was going nowhere though (wheels not pointing in the same direction).
nico_rsx is offline   Reply With Quote
The Following 2 Users Say Thank You to nico_rsx For This Useful Post:
PandaSPUR (02-01-2017), Psilox (02-01-2017)
Old 01-30-2017, 02:44 AM   #6
softgrip
My bad :\
Old 01-30-2017, 08:35 AM   #7
jasonojordan
Drives: 2013 satin white brz limited
Little hindsight but if you could feel the car pulling hard to the left aft the initial pot hole incident why did you not take it in to the shop and get it checked out??
Likely as others have stated your tie rod was damaged and then subsequently failed after not getting it checked out.
jasonojordan is offline   Reply With Quote
Old 01-30-2017, 09:26 AM   #8
Jfheisenberg
Because the pot hole incident was a day before (11AM thrusday) and the accident happened at 1PM Friday.
Old 01-30-2017, 09:27 AM   #9
jasonojordan
sooooo then you don't drive the car again till you get it checked out?
The Following User Says Thank You to jasonojordan For This Useful Post:
finch1750 (02-01-2017)
Old 01-30-2017, 09:34 AM   #10
My guess is a bent steering linkage (black arrow). It jammed and now the wheels won't move.
Jfheisenberg (01-30-2017)
Old 01-30-2017, 09:35 AM   #11
Jfheisenberg
Thanks, so one steering linkage could prevent both front wheels not to move?
Old 01-30-2017, 09:41 AM   #12
If it jammed it probably snapped something further up the line. The fact that you can turn the wheel means that the force isn't even reaching the wheels or linkage anymore. I couldn't find a picture inside the electric assist but I bet there is a simple worm gear on the motor and that has been sheared off. Could be one of the U joints though.
Old 01-30-2017, 09:50 AM   #13
Jfheisenberg
Could be, Body shop will inspect the car today, we'll see what they find.
Old 01-30-2017, 09:54 AM   #14
Could also be the gear inside the rack it self.
I am interested to know. Pot holes are one of my biggest concerns since I have had two cats steering taken out by them in the past.
My accident :( afsefo Cosmetic Modification (Interior/Exterior/Lighting) 16 02-12-2014 12:08 PM
Got into an accident Toadal Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 11-16-2013 04:18 PM
First accident in FR-S Xinshadow Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 08-02-2013 02:35 PM
accident #2 Linniea Scion FR-S / Toyota 86 GT86 General Forum 60 03-25-2013 01:09 PM
