Old 08-04-2015, 01:06 PM   #1
rbatyko
Drives: 2014 DGM BRZ 6MT
BRZ with TRD Lowering Springs
Hi all--
Have a '14 BRZ and am strongly considering TRD lowering springs (a la my dealership, just to avoid any headache). The reviews seem strong, anyone have these springs on a BRZ? Would love to see how they look with the Subie's lines.
Also, if anyone has had them put on by their dealership, mind sharing approx. how much labor was? Just curious.
Thanks!
rbatyko is offline   Reply With Quote
Old 08-04-2015, 01:16 PM   #2
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
full thread on them
http://www.ft86club.com/forums/showt...=41348&page=18
Old 08-04-2015, 01:58 PM   #3
Createddeleted
Drives: 2014 BRZ - 2004 GLI
At the dealer, it will vary from $400-600 to put them on. (Including alignment)
Createddeleted is offline   Reply With Quote
Old 03-13-2020, 07:49 PM   #4
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Originally Posted by WhiteFRS69 View Post
This is what is destroying this website. It's real easy to just answer the question, and THEN sharing the link. Now here I am in the same situation and you've made this thread useless to the topic, and now pointed to take a loop around an old thread Cheers!
Instagram: 86_Maul
ShadowReaper is offline   Reply With Quote
The Following User Says Thank You to ShadowReaper For This Useful Post:
Plumbus (06-13-2020)
Old 03-13-2020, 09:25 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Originally Posted by rbatyko View Post
Hi all--
Thanks!
Welcome,
Google could have saved you all this time waiting for a response.
99.9% of BRZ and frs/86 parts are interchangeable.
Any idiot with a wrench can install lowering springs. Seriously just YouTube it. All the info is out there. Hell if you don't have tools, rent them at most auto part stores.
Given the proper work space, it's a 3-4 hour job with a buddy and a beer in one hand.
Old 03-13-2020, 09:38 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Idiot with wrench won't be able to do proper alignment, which is needed after such work on suspension taking struts out to change springs and also due toe & camber changes from lowering. While DIY alignment is possible, still extra tools for that are needed, outside just wrench scope, and it's major PITA and takes lot of time (even more so if done for first time), making it sense to do alignment in shop with proper alignment rig. And if so, maybe it's simpler/quicker to do spring change there too. Though i'd probably would go for good reputation suspension shop then to dealership, to save on costs and possibly have better quality work (especially if i want non-OE alignment and have non-OE other suspension parts).
Old 03-13-2020, 10:21 PM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
tolerances are very tight unless you have a fucked up car, geometry change up front will be negligible, rear will add some negative camber and toe in, neither will be problematic, I wouldn't hesitate to slap lowering springs onto this chassis as a monkey and let it ride
~I've disassembled and reassembled my suspension probably 20 times on this car, mark any adjustable parts on the car if you're touching them, put them back where they came from (protip; factory stock you don't have anything adjustable to change on you)
Edit: applause to mr.ac, yelling at a post from 5 years ago, go get 'em champ
ineedyourdiddly
Old 03-16-2020, 01:53 PM   #8
FeRS
bruh
FeRS's Avatar
Drives: Raven 2015 FRS
FWIW I'd recommend RCE Yellows. They match the stock dampers better than any other lowering spring I've seen. You can take them to a shop if you don't want to put them in yourself.
FeRS is offline   Reply With Quote
brz, fr-s, lowering springs, trd
TRD lowering springs LordTaikun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 68 01-29-2017 12:03 PM
which lowering springs should I get? abling2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-22-2013 02:27 PM
For those with lowering springs. wawro569 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 03-10-2013 01:36 PM
RS*R Lowering Springs Soon to be out! tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 02:39 PM
Lowering springs? Jeff Lange Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-10-2012 11:36 PM
