07-30-2020, 12:07 AM | #141 |
Drives: '24 GR86
Lol
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post: | Elliotw (08-02-2020), Irace86.2.0 (07-31-2020) |
07-31-2020, 03:03 AM | #142 | |
Drives: Q5 + BRZ + M796
I also said this was the first time I used a TIG welder ever, and the local welding shop and Home Depot only had thick gauge welding rod, so there was a conflict of using that with the heat required from thin gauge steel. Also, the guy I bought the used welds off of had already had a crack on one of Ace's welds, which he got repaired, but I wanted to reinforce it. Again, check the ego man. All I originally said in your original comment was that suggesting to others that they should weld straight through a ceramic coating without sanding it off is a bad idea. I'm sorry your ego couldn't take the truth, but again, it didn't surprise me because I recalled that you took short cuts with your welds when you are capable of better welds. Let me know if you need your ego stroked some more, and I'll try to come up with some more novice welds for you to compare to. In the meantime, your lazy welds look about as bad as my novice welds, so
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | solidsnake11 (07-31-2020) |
07-31-2020, 07:05 AM | #143 |
Drives: brz
This was not what I was talking about when I said get some hands on. Lazy? My whole car is DIY. There is zero parts on my k24 swap that was bought for a K24 swap. ZERO. It is all hand made by me. Engine was also built and tuned by me using the stock brz ecu. :belly roll: Last edited by solidsnake11; 07-31-2020 at 03:59 PM. |
The Following 3 Users Say Thank You to solidsnake11 For This Useful Post: |
08-01-2020, 01:25 AM | #144 |
Drives: 2017 86 860 Special Edition
The Following 4 Users Say Thank You to RayRay88 For This Useful Post: | Elliotw (08-02-2020), Irace86.2.0 (08-01-2020), solidsnake11 (08-01-2020), TylerLieberman (08-01-2020) |
08-01-2020, 01:48 AM | #145 | |
08-01-2020, 06:50 AM | #146 |
Drives: brz
Its usually easier to burn through paint than it is to weld thinned out medal from sanding the paint off, when its as thin as an oil pan.
08-01-2020, 01:28 PM | #147 | |
08-01-2020, 09:46 PM | #148 |
Drives: brz
Stripper might work if you don't wind up creating a poisonous gas when you weld it. The media blaster might work also but it may warp it. Not sure if walnuts would cut the coated pan.
You have very little hands on, until you have your own experiences you need to lay off, you have no idea what your talking about. You do have some experience with warped flanges now. |
The Following 2 Users Say Thank You to solidsnake11 For This Useful Post: | Elliotw (08-02-2020), TylerLieberman (08-01-2020) |
08-01-2020, 10:22 PM | #149 | |
Drives: '24 GR86
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post: | Elliotw (08-02-2020), solidsnake11 (08-01-2020) |
08-01-2020, 10:26 PM | #150 |
Drives: '24 GR86
The Following 3 Users Say Thank You to TylerLieberman For This Useful Post: |
08-02-2020, 02:19 AM | #151 | |
I used paint stripper before. It works well. Just needs good prep. I have bead blasted parts too. Actually fun.
08-02-2020, 02:20 AM | #152 |
You should see me in my car if you think that was bad
08-02-2020, 02:39 AM | #153 |
On a separate note, I got the Michelin Pilot Sport 4S tires in and the ARP studs and wheel spacers. I think I am going to canyon, hoon and donut the rest of the treads off the old tires before throwing these on, but I plan on installing the spacers and studs tomorrow. I'll try to get some before and after shots.
08-03-2020, 04:13 PM | #154 | |
Drives: brz
The Following 2 Users Say Thank You to solidsnake11 For This Useful Post: | DarkPira7e (08-03-2020), TylerLieberman (08-03-2020) |
Similar Threads | ||||
Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
[B is for Build] BRZ resurrection build | im_topher | Member's Car Journals | 49 | 03-05-2018 09:41 AM |
HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions | Corradooo | Engine, Exhaust, Transmission | 2 | 11-25-2017 07:16 PM |
IRACE86's Build | Irace86 | Member's Car Journals | 25 | 01-10-2017 04:35 PM |
No build date on passenger side sticker, how to determine build date? | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 01-20-2015 10:14 PM |
